Vieux 15/10/2011, 23h14   #1
Aimadfm
Avatar de Aimadfm
Aimadfm will become famous soon enough
Par défaut ECU Reader for VW, AUDI, SKODA and Jetta
CETTE appareil realise reellement la lecture du pin sur l ecu pour psa ou c est du bleuf ? ECU Reader
Compatible vehicle list:
VW group(including VW, AUDI, SKODA and Jetta):
all diesel engines with EDC15 - original car odometer/mileage reading and programming from motor ECU, immobiliser PIN code reading and programming from motor ECU, immobiliser disable function, EEPROM read/write - everything by OBDII connector.
AUDI EDC15P:
A2 1.4 TDI 80CV
A3 1.9 TDI 101CV
A3 1.9 TDI 130CV
A4 1.9 TDI 101CV
A4 1.9 TDI 115CV
A4 1.9 TDI 130CV
A6 1.9 TDI 101CV
A6 1.9 TDI 130CV
AUDI/VW/SKODA SEAT EDC15P
A3 1.9 TDI 101CV
A3 1.9 TDI 130CV
A4 1.9 TDI 101CV
A4 1.9 TDI 115CV
A4 1.9 TDI 130CV
A6 1.9 TDI 101CV
A6 1.9 TDI 130CV
Bora 1.9 PD
Golf4 1.9 PD
Lupo 1.2 / 1.4 PD
New Beeatle 1.9 PD
Passat 1.9 PD
Polo 1.4/1.9 PD
Sharan 1.9 PD
AUDI/VW/SKODA EDC15VP40_29F400
A4 2.5 TDI V6 BOSCH 150 / 180CV E3
A6 2.5 TDI V6 BOSCH 150 / 180CV E3
A8 2.5 TDI V6 BOSCH 150 / 180CV E3
AUDI/VW EDC15VP40_29F800
A4 2.5 TDI V6 BOSCH 163 / 180CV E4
A6 2.5 TDI V6 BOSCH 163 / 180CV E4
A8 2.5 TDI V6 BOSCH 163 / 180CV E4
Passat 2.5 V6 155CV
A3 1.9 TDI 90CV
A3 1.9 TDI 110CV
A4 1.9 TDI 90CV
A4 1.9 TDI 110CV
A6 1.9 TDI 110CV
AUDI/VW EDC15Pa
A2 1.4 TDI 75CV
Peugeot,Citroen (PSA):
diesel engines with EDC15C2 computer - PIN code reading/programming,EEPROMread/write, original odometer km reading/erasing from motor ECU - everything by OBDII connector ;
Opel:
benzin engines with Delco ECU (Motorola HC11F1) - PIN code reading/programming, EEPROM read/write from motor ECU - everything by OBDII connector ;
benzin engines with Delco ECU (HSFI-2.1 Hybrid) - PIN code reading from motor ECU - everything by OBDII connec
Dernière modification par Aimadfm ; 15/10/2011 à 23h16.
Aimadfm est déconnecté   Réponse avec citation
Vieux 16/10/2011, 00h18   #2
solution auto
Avatar de solution auto
pas tout tester mais oui il en fait pas mal !! y compris psa !!
cest une option du carprog
The Following User Says Thank You to solution auto For This Useful Post:
Aimadfm (16/10/2011)
Vieux 16/10/2011, 01h39   #3
Aimadfm
Avatar de Aimadfm
et bien je vais l achete
Vieux 16/10/2011, 01h46   #4
solution auto
attend peut etre confirmation d autre membre voir meme si y connaisse pas une equivalance un peu plus performante ??
Aimadfm (17/10/2011)
vas pc v17 Fr Audi vw Skoda Seat Lamborghini Bentley dichar VAS5054, VCDS, ODIS 11 15/06/2011 08h40
Code reader RGS programmation & synchronisation de clé 0 07/07/2010 23h58
Key reader pro sXr programmation & synchronisation de clé 0 11/06/2009 12h48
Fuseau horaire GMT +1. Il est actuellement 02h34.
