Vieux 03/02/2016, 14h39   #1
mecanodiag93
Avatar de mecanodiag93
mecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant future
Par défaut VCDS 15.7.1 china FR
si vous cherchez VCDS 15.7.1 chinois en version française
un thanks ca fait toujours plaisirs
Type de fichier : rar VCDS 15.7.1 fr chinoi.rar (185 octets, 466 affichages)
ne fais pas à autrui ce que tu n'aimerais pas qu'on te fasse !!
mecanodiag93 est déconnecté   Réponse avec citation
The Following 18 Users Say Thank You to mecanodiag93 For This Useful Post:
aghilas (30/04/2016), Alessiapia14 (30/11/2019), autodiagauto (29/03/2019), bladi (18/04/2021), dart (23/04/2019), david7100 (29/02/2020), marco84 (13/12/2019), medmine (29/11/2021), MEGA (27/05/2020), mikano213 (17/06/2026), neoamtrixe (16/04/2019), Portugal330D (28/02/2020), PROG (16/10/2016), sahnoun363 (19/07/2017), samii1955 (26/07/2019), tayeb32 (25/05/2020), terminator (14/09/2017), youssef el issati (03/04/2019)
Vieux 03/02/2016, 22h52   #2
Bollide
Avatar de Bollide
Bollide is a glorious beacon of lightBollide is a glorious beacon of lightBollide is a glorious beacon of lightBollide is a glorious beacon of lightBollide is a glorious beacon of lightBollide is a glorious beacon of light
MERCI Mr pour le lien, donc il fonctionne biens avec les versions clones Chinoises que l'on peut trouvé sur le Net ;-))
Bollide est connecté maintenant   Réponse avec citation
Vieux 04/02/2016, 02h10   #3
kdo75
Avatar de kdo75
kdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud of
fonctionne t' il avec le cable 12.12 fr ??
kdo75 est déconnecté   Réponse avec citation
Vieux 04/02/2016, 03h20   #4
pouettedu76
Avatar de pouettedu76
Pouvoir de réputation: 77
Envoyé par kdo75 Voir le message
Bonjour logiquement non il ne fonctionne qu'avec l'originale ou avec le câble clone vendus avec mes pas avec la v-12.12fr celle ne fonctionne qu'avec son câble car si tu essaye tu pourra bloquer ta sonde et la rendre inutilisable .
Ps: Si tu tente le coup et que sa fonctionne ou pas pourra tu nous faire un retour cordialement .
Mes tu a été prévenus
Bonne nuit a tous les autres
Vieux 11/02/2016, 15h29   #5
biskra
Avatar de biskra
biskra is on a distinguished road
Envoyé par lazelec Voir le message
est ce que quelqu'un l'a essayé avec la 12.12.1fr
testé sur mon pc la tête n'est pas reconnue.
biskra est déconnecté   Réponse avec citation
Vieux 29/04/2016, 14h46   #6
passemoi
Avatar de passemoi
passemoi has a spectacular aura aboutpassemoi has a spectacular aura aboutpassemoi has a spectacular aura about
Salut tous le monde!!
Donc si je comprend bien on peut faire fonctionner ton soft avec une interface clone chinoise qui à la base est prévu pour la version 15.7.1 mais en anglais/allemand?
Merci d'avance pour ta réponse.
Et merci pour ce partage.
passemoi est déconnecté   Réponse avec citation
Vieux 04/06/2016, 16h29   #7
Scred
Avatar de Scred
Scred is an unknown quantity at this point
Envoyé par passemoi Voir le message
Très bonne question , cette version fonctionne t'inquiete elle avec le cable clone Version 15.7.1 version anglais ou 15.7.1 version allemand ???
Scred est déconnecté   Réponse avec citation
The Following User Says Thank You to Scred For This Useful Post:
passemoi (08/06/2016)
Vieux 08/06/2016, 09h00   #8
passemoi
Avatar de passemoi
je devrait bientôt recevoir mon diag VCDS avec un sotf anglais. J'essayerai et je vous teindrai au courant.
The Following User Says Thank You to passemoi For This Useful Post:
Scred (08/06/2016)
Vieux 08/06/2016, 11h21   #9
Scred
Avatar de Scred
J'ai vu quil y en avais en version Fr sur internet mais le prix est x3
donc si j'attend ton retour pour commander le cable english/deutch.
Vieux 08/06/2016, 11h24   #10
Scred
Avatar de Scred
Envoyé par biskra Voir le message
Ne faut il brancher le câble a la prise ODB pour qu'il soit éventuellement reconnu?
Vieux 08/06/2016, 13h16   #11
thierry du58
Avatar de thierry du58
Si s est comme pour les anciennes version made in china 1 soft 1 cordon
un thanks sa peu aider
Vieux 11/07/2016, 17h01   #12
passemoi
Avatar de passemoi
Bon et bin voila j'ai la réponse. Ce soft ne fonctionne pas avec les clone qui ont un soft en anglais. interface HS!!!
Il me semble avoir vu une procédure pour réinitialiser l'interface? si quelqu'un peut me donner un lien je suis preneur
Merci d'avance.
Vieux 12/07/2016, 10h51   #13
Seiven38
Avatar de Seiven38
Seiven38 is on a distinguished road
Salut passemoi,
Les interfaces VCDS clones premiers prix ne sont pas conçues pour l'utilisation du soft VCDS dans une autre version ou une autre langue que ce qui est fourni avec l'interface.
En ne respectant pas cela en faisant ton essai, tu as dût faire sauter la programmation du composant principal de ton interface contenant la licence. Il faudrait sans doute le reprogrammer (il faut ouvrir l'interface et intervenir directement sur le composant principal avec un programmateur). Différents programmateurs se trouvent à acheter sur le Net et le soft pour faire la reprogrammation est gratuit ça ce n'est pas un problème, par contre le problème c'est qu'il faut aussi avoir le contenu à injecter dans ce composant et c'est là que ça va coincer. Ce contenu ne se trouve pas librement sur le Net pour toutes les versions et toutes les langues du soft VCDS. Sur le Net, on peut trouver librement ce contenu pour la version 11.11.0 US, celui pour la version 11.11.5 US et celui pour la version 12.12.0 US, mais c'est tout et encore la version 12.12.0 US que l'on trouve librement sur le Net ne marche qu'à moitié.
Quand tu parles d'une procédure pour réinitialiser l'interface, si tu parles de la reprogrammation du composant qui gère l'USB (reprogrammation qui ne nécessite pas d'ouvrir l'interface, ni de programmateur), cela peut aider dans le cas où l'interface n'est plus reconnue comme il faut dans le Gestionnaire de périphériques de Windows, mais ça ne réparera pas le contenu du composant principale de l'interface, donc c'est très limité.
J'ai bien peur que tu sois obligé de racheter une autre interface VCDS, soit en rachetant le même genre d'interface clone premier prix (mais cette fois sans refaire d'essais risqués pour la santé de ce genre d'interface), soit en achetant une interface clone plus chère (à une centaine d'euros) qui marche par exemple avec les dernières versions FR et US (15.7.4 FR et US) du soft VCDS et avec les mises à jour aussi.
Seiven38 est déconnecté   Réponse avec citation
Vieux 12/07/2016, 21h48   #14
passemoi
Avatar de passemoi
Salut Seiven 38,
merci beaucoup pour tes explications. En fait j’aurais du faire un dump du composant principal avant de faire l'essai. On va dire que c'est pas très grave.
Es que tu pourrais m'indiquer ou acheter un clone sur lequel on peut faire les mises a jour?
Merci d'avance.
Vieux 12/07/2016, 22h10   #15
pouettedu76
Salut contacte Direkside il en vend de bonne qualiter et qui accepte toutes les uses a jours c'est une vcds HQ je ne sais pas si j'ai bien écris son pseudo mes cherche le tu le trouvera il est connus dans plusieurs fofo @+ et tu arraisonne du comme lire le message #4 peut être que tu n'aurais pas essayée y'a moins les autres membres seront avertis @+
Galletto V54 china - installation ?? diagnosis29 Programmateur de composant (flasher) 36 24/01/2017 14h17
Vw rcd 300 china model verbatime Autoradio et Navigateur GPS 0 31/07/2015 10h20
china obg2 yousfi Logiciel & autres documentations général 0 29/09/2013 04h29
Fuseau horaire GMT +1. Il est actuellement 21h49.
