Vieux 30/07/2015, 02h34   #196
said auto-technology
Avatar de said auto-technology
said auto-technology will become famous soon enough
merci , bon travail
said auto-technology est déconnecté   Réponse avec citation
Vieux 25/09/2015, 22h40   #197
lechat
Avatar de lechat
lechat is an unknown quantity at this point
bonjour a tous
faut il modifier le l interface pour mestre a jour 7xx et 8
ou simplement flasher
et ou trouver le référence des composent a remplacer
grand mercis
lechat est déconnecté   Réponse avec citation
Vieux 25/09/2015, 22h42   #198
lechat
Avatar de lechat
bonjour a tous
grand mercis
Vieux 26/09/2015, 18h20   #199
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
You are fine, that's what it should be (Multi-Instance) for 32 bit Windows.
Simple est déconnecté   Réponse avec citation
Vieux 05/10/2015, 21h25   #200
Simple
Avatar de Simple
I cannot answer about NLC, but you can PM him... However, some posted the firmware and the flasher in one of the posts.. You can do it if your device has the optocouplers..
The firmware 4.3.3 is flashed when you start DiagBox v7.62 or above..
DiagBox v7.02 => Lexia Softwae Version= 500.46 & Lexia Interface Firmware = 4.3.0
DiagBox v7.57 => Lexia Softwae Version= 500.66 & Lexia Interface Firmware = 4.3.2
DiagBox v7.58 => Lexia Softwae Version= 500.66 & Lexia Interface Firmware = 4.3.2
DiagBox v7.62 => Lexia Softwae Version= 500.68 & Lexia Interface Firmware = 4.3.3
DiagBox v7.66 => Lexia Softwae Version= 500.68 & Lexia Interface Firmware = 4.3.3 (.NET 3.5 is needed)
DiagBox v7.74 => Lexia Softwae Version= 500.70 & Lexia Interface Firmware = 4.3.3 (.NET 3.5 is needed, run as Administrator or XP compatibility)
DiagBox v7.76 => Lexia Softwae Version= 500.71 & Lexia Interface Firmware = 4.3.3 (.NET 3.5 is needed, run as Administrator or XP compatibility)
DiagBox v7.77 => Lexia Softwae Version= 500.71 & Lexia Interface Firmware = 4.3.3 (.NET 3.5 is needed, run as Administrator or XP compatibility)
Vieux 05/10/2015, 21h34   #201
Simple
Avatar de Simple
@mariol56, why do you have the UMDF driver? You should have the multi-instance..
devildante007 may be correct and you have a hardware problem..
But try uninstalling the UMDF driver and check the delete box, and re-install the Multi-Instance driver.
Vieux 17/10/2015, 12h54   #202
electro_bordeaux1
Avatar de electro_bordeaux1
je lui ai envoye un mp avec les coordonnees est toujours pas encore reçu le flash
l union fait la force
Vieux 16/11/2015, 15h18   #203
freefred93
Avatar de freefred93
freefred93 is on a distinguished road
bonjour nlc,
parcourant ce site et voyant les nombreux post positifs à ton sujet, je viens a mon tour te demander ton aide, pour le flashage de mon interface diagbox.
en effet, t'ayant envoyer un MP je suis en attente de ta réponse
cordialement,
freefred93 est déconnecté   Réponse avec citation
Vieux 22/11/2015, 16h44   #204
freefred93
Par défaut flashage diagbox
bonjour nlc,
comme promis je reviens vers toi, pour te remercier pour ton excellent travail
le flashage de mon interface diagbox c'est très bien dérouler.
je vais te faire parvenir un don pour te remercier de ta réponse rapide et, pour t'encourager a continuer de tous nous aider
cordialement,
Vieux 07/12/2015, 09h48   #205
cooperbritax
Avatar de cooperbritax
cooperbritax is an unknown quantity at this point
Un Grand MERCI à NLC
J'ai bien reçu et appliqué son "patch"
L'interface a bien été mise a jour en 4.3.3 par diagbox 7.65
par contre j'ai un probleme de com avec ma 208 phase 2 (fonctionne sur vielle 206)mais je pense que c'est un probleme hardware de ma sonde, je cherche...
cooperbritax est déconnecté   Réponse avec citation
Vieux 30/12/2015, 22h21   #206
nico207rc
Avatar de nico207rc
nico207rc is an unknown quantity at this point
bonjour à vous,
Depuis que j'ai flashé l'interface depuis les début de Nlc sur le forum RAS tout se passe bien.
Encore merci l'ami et n’hésitez pas à lui faire un don pour son taf !
nico207rc est déconnecté   Réponse avec citation
Vieux 06/01/2016, 22h31   #207
ballajunior
Avatar de ballajunior
ballajunior is on a distinguished road
Envoyé par Simple Voir le message
Hello Simple,
me again ;-) What about Firmware 4.3.4? Is it from v7.82 up?
Thanks in advance for your feedback.
ballajunior est déconnecté   Réponse avec citation
Vieux 06/01/2016, 22h40   #208
ballajunior
Bonsoir nlc,
Pour ma part aussi, un grand merci pour le temps et les efforts que vous avez consacré à la mise au point de ce mode de flashage d'interface.
Je l'ai flashé il y a déjà 1-2 mois et tout c'est très bien passé.
Cordialement,
Vieux 07/01/2016, 00h52   #209
Simple
Avatar de Simple
Envoyé par ballajunior Voir le message
Hello Simple,
DiagBox v8.03 introduced Appli.com v4.3.4; (Attached).
DiagBox v8.18 => Firmware = 4.3.4 > PP2000 = 600.76 & Lexia = 500.72 (.NET 3.5 is needed, run as Administrator or XP compatibility).
But since we are at it:
History versions of vci_updater.com :
V1.0.0 (30/03/2013)
- First working version
- Update bootloader to switch the interface to Evolution
- Clear the sector 5 of MCU flash, to erase all traces of the old bootloader
- Erase external SPI EEPROM, and reprogram a random serial number with recognition Peugeot (ACTIA/963830 C/42-07/nnnnnn)
V1.0.1 (31/03/2013)
- On some interfaces SPI EEPROM is not a Winbond but a Spansion, which only supports the delete command 0xC7 against 0xC7 or 0x60 for Winbond -> Using the command 0xC7 instead of 0x60 to be compatible on the two models.
V1.0.2 (31/03/2013)
- The serial number is no longer generated randomly by the firmware but during the firmware customization. So if you share your custom firmware on Internet and it becomes public, the serial number will be quickly blacklisted and your interface will work not anymore with future DiagBox versions
V1.0.3 (13/04/2013)
- Before the upgrade, check if the SPI EEPROM is readable to determine if the interface is compatible or if it's an incompatible interface with simplified hardware. No upgrade occurs in this case to not brick the interface
Type de fichier : rar appli-4.3.4.rar (80,8 Ko, 105 affichages)
The Following 2 Users Say Thank You to Simple For This Useful Post:
djalil (01/06/2021), mustaphcl (05/05/2020)
Vieux 07/01/2016, 01h42   #210
Simple
Avatar de Simple
I am sorry, there is a typo in my previous post, I meant Appli_4.3.4.com comes with DiagBox v8.02 not v8.03.
Redémarrer Windows sans redémarrer votre PC focus66 Informatique 3 30/06/2013 12h30
mise a jour Diagbox sans internet ramaz PSA Group Peugeot, Citroën 2 04/12/2010 22h26
mise a jour pps et lexia sans internet ramaz PSA Group Peugeot, Citroën 0 18/10/2010 16h35
Pour ceux qui n'ont pas la diagbox nouvelle mise ajour pps et lexia ramaz PSA Group Peugeot, Citroën 0 14/10/2010 11h36
Fuseau horaire GMT +1. Il est actuellement 04h26.
