| Section for english users English talking about cars, problems and solutions ... |
Hi to all,
I have an ecu (5nr2.ci2) ,ecu is damaged, I want to make a Clone ecu from original.. can I just desolder 95160 (from original) and solder to donor ecu ? or it is not enough? second option : donor ecu virgin making please tell me how can I do it ? |
I've 2 pieces 5nr2.ci2 , I have read today both ecus ( 95160). dump of original ecu is OK no problem, but the dump file of donor ECU is very strange, file size are same ( 2 KB ) but dump op donor is full with " 0 "
would anyone want to check it please ? I doubt now donor ecu is also damaged . |
Fondateur
![]() Date d'inscription: novembre 2008
Pouvoir de réputation: 1335 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
swap eprom.
🚀 MOD-FILES.COM Service de fichiers Chiptuning Haute Performance Stage 1, 2, 3 | FlexFuel - DPF - EGR - AdBlue - Pop&Bang CLIQUEZ ICI POUR ACCÉDER AU SERVICE 24/7 |
Thank you , I swapped eproms ( 95160) original eprom soldered to second donor ecu , no problem with car key and immo, but car dont have now ignition ! I thought swap was enough..
this ecu 5nr2.c2 is only used in clio or in others cars too ? I doubt now whether this ecu of is another car or other engine model . someone has idea about reason ? |
Pouvoir de réputation: 89 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
5nr2.c2 = twingo 1.2 16s / clio 1.2 16s
ci joint dump clear |
imo automatic synchronization for this blank file
| immo off twingo 16V magneti marelli IAW 5NR2 | bbert90 | Immobilizer dumps/solutions | 19 | 07/12/2020 19h36 |
| clio 1.2 16v iaww 5nr2.c2 immo off | obdcarkey | Immobilizer dumps/solutions | 10 | 24/04/2018 11h57 |
| Cherche immo-off IAW 5NR2.T3 renault | leraj | Immobilizer dumps/solutions | 5 | 26/01/2017 18h14 |
| Immo Off iaw 5NR2 T3 | Sly59 | Immobilizer dumps/solutions | 1 | 28/02/2015 22h46 |
| Immo off sur 95160 IAW 5NR2.T3 | loloda | Immobilizer dumps/solutions | 0 | 23/01/2014 14h37 |
