Vieux 27/05/2015, 22h14   #31
atlon2
Avatar de atlon2
atlon2 is just really niceatlon2 is just really niceatlon2 is just really niceatlon2 is just really nice
donc non la cullasse a pas ete rectifier,comme ca je suis fixer.je suis deg.
atlon2 est déconnecté   Réponse avec citation
Vieux 27/05/2015, 22h28   #32
MecaTech
Banned
Avatar de MecaTech
MecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond reputeMecaTech has a reputation beyond repute
MecaTech est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to MecaTech For This Useful Post:
atlon2 (27/05/2015), obdauto2 (07/06/2015)
Vieux 27/05/2015, 22h37   #33
mysterauto
Avatar de mysterauto
mysterauto is a jewel in the roughmysterauto is a jewel in the roughmysterauto is a jewel in the roughmysterauto is a jewel in the rough
- un joint plus épais fait descendre la compression
- une culasse rectifiée fait monter la compression
mysterauto est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to mysterauto For This Useful Post:
atlon2 (27/05/2015), MecaTech (27/05/2015)
Vieux 27/05/2015, 23h01   #34
atlon2
Avatar de atlon2
je te remercie beaucoup.
Vieux 27/05/2015, 23h20   #35
Ecomouv
Avatar de Ecomouv
Ecomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud ofEcomouv has much to be proud of
Envoyé par mysterauto Voir le message
salut sur une injection direct et sur les X17DTL, la culasse est plate . Alors rectifiée ou pas ca ne change rien , le seule risque a rectifier , c'est les soupapes qui se rapprochent des pistons. Par contre oui , un JC épais fais baisser la compression. Il faut toujour metre le meme joint que d'origine sur ce moteur (rectifiée ou pas ). Ou alors encore mieux >messurer ses depassement de piston . Bonne soiréehttp://www.frontrunner2000.fr/index....d=2107&lang=fr
Dernière modification par Ecomouv ; 28/05/2015 à 07h43.
Ecomouv est déconnecté   Réponse avec citation
The Following User Says Thank You to Ecomouv For This Useful Post:
atlon2 (28/05/2015)
Vieux 28/05/2015, 08h20   #36
mysterauto
tout à fait ecomouv, contrairement au moteur essence, ca ne change pas grand chose sur la plupart des diesel car la culasse est plate. (j'avais zappé que nous parlions de diesel)
sinon, on peut rajouter que rectifier la culasse modifie légèrement la distribution:
- cela décale un peu l'épure de distribution
- il y a un risque que le tendeur de courroie arrive en butée et la courroie ne soit pas assez tendue
The Following User Says Thank You to mysterauto For This Useful Post:
atlon2 (28/05/2015)
Vieux 28/05/2015, 12h07   #37
atlon2
Avatar de atlon2
salut. merci a tous.bon ben vu avec le gars changement du joint de culasse par un d origine.savez vous comment je peu savoir ce qui et monter comme épaisseur d origine.
Vieux 28/05/2015, 13h17   #38
Ecomouv
Avatar de Ecomouv
salut , tu ne peus pas savoir ce qu'il y avait en ori . Ca dépend des dépassement de piston . A+
atlon2 (28/05/2015)
Vieux 28/05/2015, 13h36   #39
atlon2
Avatar de atlon2
tu peut m expliquer un peu la marche a suivre.stp
The Following User Says Thank You to atlon2 For This Useful Post:
billka (28/05/2015)
Vieux 28/05/2015, 13h44   #40
billka
Avatar de billka
billka will become famous soon enoughbillka will become famous soon enough
salut,je viens de regarder ce qui ce fait en jc sur x17dtl:3 cote possible:1)cote origine 1.3mm 2)cote reparation 1.4mm 3)cote reparation 1.5mm(en fonction de la rectif ci il y a lieu)bonne journee
________________________________
un petit thank's ca fait toujours plaisir.....
billka est déconnecté   Réponse avec citation
The Following User Says Thank You to billka For This Useful Post:
atlon2 (28/05/2015)
Vieux 28/05/2015, 18h16   #41
atlon2
Avatar de atlon2
salut billka désoler mais c est un td que j ai et non un dti.mais je te remercie quand même de t être pencher sur mon problème.
Vieux 28/05/2015, 18h20   #42
Ecomouv
Avatar de Ecomouv
Envoyé par atlon2 Voir le message
C'est pas x17dti c'est x17TDL.
The Following 2 Users Say Thank You to Ecomouv For This Useful Post:
atlon2 (28/05/2015), MecaTech (28/05/2015)
Vieux 28/05/2015, 18h36   #43
atlon2
Avatar de atlon2
désoler.j avais mal lu.
billka (28/05/2015)
Vieux 28/05/2015, 19h30   #44
MecaTech
Banned
Avatar de MecaTech
► Prise de mesure au comparateur + support pour avoir la bonne épaisseur à choisir du nouveau joint de culasse (voir le tuto PDF)
Dernière modification par MecaTech ; 09/09/2025 à 15h13.
The Following 6 Users Say Thank You to MecaTech For This Useful Post:
atlon2 (28/05/2015), autodiagauto (07/06/2015), Ecomouv (28/05/2015), garageducentre (29/05/2015), mysterauto (28/05/2015), obdauto2 (07/06/2015)
Vieux 29/05/2015, 01h31   #45
atlon2
Avatar de atlon2
merci mecatech tes un chef comme dab.
MecaTech (29/05/2015)
calage distribution 2,0L TDI 140cv tonio5766 Mécanique générale 37 16/09/2018 08h27
calage distribution peugeot 301 zouaoui mohamed PSA Group Peugeot, Citroën 10 26/08/2015 05h04
schéma de calage distribution ! neiji PSA Group Peugeot, Citroën 7 02/08/2013 14h30
Calage Distribution Laguna II 1.9 DCI bangreno Mécanique générale 19 25/01/2013 11h59
Fuseau horaire GMT +1. Il est actuellement 22h53.
