Vieux 12/03/2013, 08h45   #1
skikdi13
Avatar de skikdi13
skikdi13 is a name known to allskikdi13 is a name known to allskikdi13 is a name known to allskikdi13 is a name known to allskikdi13 is a name known to allskikdi13 is a name known to all
Par défaut trouver le pin sur une twingo
Salut, j'aimerai apprendre comment trouver le pin sur une renault, quel matériel faut il, quel logiciel, c'est quoi le lump etc...je suis débutant lol
Merci beaucoup
skikdi13 est déconnecté   Réponse avec citation
Vieux 31/07/2014, 19h28   #2
stephane
Avatar de stephane
Pouvoir de réputation: 121
c est quoi comme Twingo ?
Vieux 31/07/2014, 19h34   #3
@ stephane, regarde les dates des post! et dit bonjour avant
diagnosis29 (31/07/2014)
Vieux 31/07/2014, 19h52   #4
stephane
Avatar de stephane
Oups !!!!!! Désolé
The Following User Says Thank You to stephane For This Useful Post:
television (31/07/2014)
Vieux 31/07/2014, 20h47   #5
television
Avatar de television
television has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond reputetelevision has a reputation beyond repute
il avait une bonne attention !! stephane ,mais un peut tard
television est déconnecté   Réponse avec citation
Vieux 31/07/2014, 21h06   #6
Verdun
Avatar de Verdun
Verdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud of
twingo ouvre ta cle il y a un code rentre le dans RPE et il te donnera le code de l antidémarrage.
Verdun est déconnecté   Réponse avec citation
The Following User Says Thank You to Verdun For This Useful Post:
COTECH00 (19/10/2014)
Vieux 31/07/2014, 22h06   #7
amrougafsa
Avatar de amrougafsa
Pouvoir de réputation: 51
Envoyé par Verdun Voir le message
Bonsoir il dit qu'il est encore débutant alors il va pas comprendre le mot (Rpe) .
écoute frère Stéphane RPE c'est (RENAULT PIN EXTRACTOR 2) un soft qui peut extraire le pin code Renault a partir du code écrit dans le clé comme il a dit Verdun aussi a partir du dump si tu es équipe d'un programmeur d'eeprom .
alors tu es besoin du soft le voila et un programmeur comme X-PROG ou Labtoul etc...
j'ai déjà posté un exemple tu peut le rejoindre par ici
http://www.tlemcen-electronic.com/fo...ad.php?t=29750
et je te conseil de faire un peut d’effort a chercher sur le forum tu apprendras plein de nouvelles
consulter ta boite et bonne chance .
Type de fichier : rar RENAULT PIN EXTRACTOR 2.rar (49,6 Ko, 39 affichages)
The Following 5 Users Say Thank You to amrougafsa For This Useful Post:
ajfleclerc (29/04/2015), diagnosis29 (31/07/2014), television (31/07/2014), thiam58 (04/08/2014)
Vieux 31/07/2014, 22h14   #8
stephane
Avatar de stephane
Oulas.... mon grand j ais rient dit moi , juste désolé de ne pas avoir vue la date du message et de ne pas avoir dit bonsoir alors que je pensais pouvoir l aider c est tout ne te trompe pas de personne
Cordialement
Stephane
amrougafsa (03/06/2018)
Vieux 18/04/2015, 23h28   #9
touftouf78
Avatar de touftouf78
touftouf78 is an unknown quantity at this point
j'ai deux clés sur une Twingo 16v de 12/2002 et je n'ai pas trouver d'étiquette a l'intérieur pour avoir le numéro de celle ci
touftouf78 est déconnecté   Réponse avec citation
Vieux 18/04/2015, 23h59   #10
Meziane93
Avatar de Meziane93
J aime voir ce metier mourir a petit feu bien vu
Vieux 19/04/2015, 00h32   #11
touftouf78
Envoyé par Meziane93 Voir le message
ton post est pour moi frere ?si oui je suis tout nouveau dans ce forum et dans ce domaine, si non autant pour moi
br
ou trouver nyo4 mustauto Tableau de bord (Dashboard) 7 27/09/2015 00h48
trouver les code des fichier rar beonce Informatique 16 30/12/2012 04h19
Ou trouver les logiciels originaux??? eCU25 Automobile en général 6 17/11/2012 02h50
trouver code clé kmol programmation & synchronisation de clé 2 07/02/2012 03h27
Trouver L'eprom diagautoprog Airbag 5 08/09/2011 16h06
Fuseau horaire GMT +1. Il est actuellement 12h28.
