Précédent   Tlemcen Car electronics > Outils & Diag > Diagnostic automobile > Autres marques
Discussion fermée
Vieux 11/11/2010, 00h40   #1
sidj
Avatar de sidj
sidj is a jewel in the roughsidj is a jewel in the roughsidj is a jewel in the roughsidj is a jewel in the rough
Par défaut kia carens
bonsoir a tous
sur une kia carens de 2005 moteur crdi
quand la personne roule avec un maintien d'accélération la voiture s'arrete d'un coup
au diag 2 défaut
P1188 et P1189
aucune indication sur ces défauts
en attente de vos réponses
sidj
sidj est déconnecté
Vieux 11/11/2010, 06h25   #2
ricards99
Avatar de ricards99
essai de voir ici: mais c'est les codes standardisés, pour les codes specifiques constructeur si je trouve quelque chose je te tiens au courant
http://www.eobd.fr/fault_codes/P11xx.swf
j'ai trouvé ca aussi:
P1188 Linear 02 Sensor / Compens. Resistor Short to Ground
P1189 Linear 02 Sensor / Compens. Resistor Short to B+
et ca aussi:
P1188
Fuel Pressure Monitoring Malfunction-Leakage
P1189
Fuel Pressure Monitoring Malfunction-Governor Deviation at Engine Speed Too High
encore ca:
P1187 Fuel Pressure Monitoring - Regulator Valve Stick
All Common rail diesel engine, rail pressure regulator is controlled based on rail pressure sensor signal in order to maintain optimum rail pressure according to current engine rpm and load.
However when the problem that leads rail pressure to out of target value intended by ECM occurs due to mechanical or electronical reason, ECM shuts engine down and sets DTC by limiting fuel (stops injector operation) in order to prevent engine from being controlled abnormally. "rail pressure monitoring error" is the DTC which diagnose 1). supplying state of low pressure fuel and 2). mechanical operating conditions of high pressure pump and 3). rail pressure regulator indirectly based on rail pressure sernsor output voltage and rail pressure sensor duty. thus, repair relavant to this DTC requires mechanics the total understand of fuel system.
P1189 Fuel Pressure Monitoring - Governor Deviation at Engine speed Too High
Fuel pressure monitoring is used to detect the troubles and the fuel leakage in high pressure system. The ECM determines the rail pressure value as a function of the engine’s operating conditions and controls the fuel pressure regulator to ensure that the rail pressure reaches the required value. Fuel pressure in the fuel line including the pumps and injector are continuously monitored during engine runing. If the rail pressure is excessive, the fuel pressure regulator opens and a portion of the fuel returns from the rail to the fuel tank via a collector line. If the rail pressure is too low, the fuel pressure regulator closes. The fuel pressure regulator closes. the fuel pressure regulator is installed in the tail end of high pressure accumulator. In case of the insufficient fuel supply in the fuel line, the engine symptoms will occur a shut down and a starting impossible.
Dernière modification par ricards99 ; 11/11/2010 à 06h40.
ricards99 est déconnecté
The Following User Says Thank You to ricards99 For This Useful Post:
MecaTech (11/08/2013)
Vieux 12/11/2010, 22h15   #3
sidj
Avatar de sidj
Par défaut salut ricards99
merci pour ta réponse
je trouvé les mêmes références défaut
j'ai changer les injecteurs,la rampe,capteur rampe
mais toujours même défaut
il suffit de la poussr un peu et elle coupe
il faut que je change la pompe
sidj est déconnecté
Vieux 12/11/2010, 22h24   #4
prodiag
Avatar de prodiag
prodiag has a spectacular aura aboutprodiag has a spectacular aura aboutprodiag has a spectacular aura about
Question
Envoyé par sidj Voir le message
oui sidj si un probleme de pompe hp
bon chance
« L'union fait la force »
prodiag est déconnecté
Vieux 12/11/2010, 22h46   #5
omar36
Avatar de omar36
omar36 is an unknown quantity at this point
salut il faut que je change la pompe (hp)
omar36 est déconnecté
Vieux 23/11/2010, 01h47   #6
sidj
Avatar de sidj
Par défaut probleme résolu
bonsoir a tous
après changement pompe hp injecteurs common rail et filtre a gasoil
le probleme à été résolu
je vous remercie pour vos réponses
sidj
sidj est déconnecté
Discussion fermée
Fuseau horaire GMT +1. Il est actuellement 03h20.
