Précédent   Tlemcen Car electronics > Outils & Diag > Outils de diagnostique > MBStar, Xentry, DAS
Vieux 22/03/2015, 09h32   #1
badik
Avatar de badik
badik is on a distinguished road
Par défaut SDConnect unlock dump!!! 100% working solution.
This is a dump read out from PIC16LF88 chip of my own SDConnect C4 device (4-5 years old). It's 100% working.
I know it exactly because I've succesfully unlocked 3 units for last 2 days using it. Each one works fine.
You don't need to buy a new one PIC16FL88. You just have to program chip from your own device.
After that when you run your SDconnect you will probably see that serial number, OS version of your device are changed into zeroes "0000".
Don't worry. Just change your C4 to factory state using buttons near by LCD (no need to explain "How to..." because it's quite clear). After rebooting you'll see ****** SN, OS version and so on.
Also you can change serial number of your device. 24c02 contains it. After changing number just run "factory settings" function...other way it will not change. After reboot you'll probably see (on lcd of your device) your SN looks like "the number you've programmed into chip +1"... I mean 10001 inspite of 10000 for example and so on, but in SDNC tool kit you'll see the real SN (10000), and after succesfull reconfiguring your device you'll see the right number on LCD of your C4.
I was using cheap ssop28 (0.65mm step) adapter and Pickit3 programmer to read/write PIC16lf88. This scheme made for Pickit3 OEM socket(ICSP).
Also I've got dumps of both flashes 29f016 and PIC18lf8680 if somebody need it.
Archive is protected. Password by PM.
Type de fichier : jpg Brochage_pickit.jpg (11,3 Ko, 124 affichages)
Type de fichier : jpg PIC16F88 connection icsp.JPG (54,4 Ko, 135 affichages)
Type de fichier : rar pic16f88 ok.rar (2,5 Ko, 59 affichages)
badik est déconnecté   Réponse avec citation
The Following 13 Users Say Thank You to badik For This Useful Post:
autodiagauto (11/05/2019), chongzii (20/12/2018), Doux (21/06/2022), fantomel (13/04/2015), hamada (11/05/2019), jah83 (24/11/2018), khoums (30/07/2019), natouss225 (12/04/2015), Nextrick (11/05/2019), noppathon (17/07/2022), youcef_trik (11/05/2019)
Vieux 22/03/2015, 09h47   #2
badik
Avatar de badik
Here are dumps of both flash memories 29f016. Finally I've found them. In the picture below you can see marks A & B made with pencil and dumps in archive are also named according to signs in the picture.
One of archives (probably - device1) contains dumps from device which didn't support command CE_flash_loeschen and the other one ( it seems device2) contains dums from working SDConnect.
I read them both using Triton 5.7 programmer with hand-made adapter for 8-bit flash memories (29XXXX).
If you try to read-write them using TL866/wizardprog/willem...then don't waste your time. These programmers won't dothis job. But it was few years ago, so probably something changed.
Type de fichier : jpg IMG_20130930.jpg (87,9 Ko, 101 affichages)
Type de fichier : rar sd connect 29f016 device1.rar (186,1 Ko, 51 affichages)
Type de fichier : rar sd connect flash 29f016 device2.rar (191,1 Ko, 39 affichages)
The Following 5 Users Say Thank You to badik For This Useful Post:
autodiagauto (11/05/2019), chipshop (24/11/2018), khoums (30/07/2019), natouss225 (12/04/2015)
Vieux 22/03/2015, 09h50   #3
badik
Avatar de badik
24c02 dump of cloned device.
Type de fichier : bin serial 24c02.BIN (256 octets, 53 affichages)
The Following 4 Users Say Thank You to badik For This Useful Post:
autodiagauto (11/05/2019), chipshop (24/11/2018), natouss225 (12/04/2015)
Vieux 29/07/2015, 14h24   #4
bibo3002
Avatar de bibo3002
bibo3002 is an unknown quantity at this point
Merci pour cette info .... c vraiment utile ... je vais testé
bibo3002 est déconnecté   Réponse avec citation
Vieux 24/11/2018, 10h30   #5
Aleksey_cm
Avatar de Aleksey_cm
Aleksey_cm is an unknown quantity at this point
does this lf88 dump allow changing s/n via eeprom?
Aleksey_cm est déconnecté   Réponse avec citation
Vieux 20/12/2018, 13h43   #6
chongzii
Avatar de chongzii
chongzii is an unknown quantity at this point
Comment télécharger des fichiers
---------- Post added at 13h43 ---------- Previous post was at 13h36 ----------
Как скачивать файлы
chongzii est déconnecté   Réponse avec citation
Vieux 21/06/2022, 07h22   #7
Doux
Avatar de Doux
Doux is an unknown quantity at this point
Grand merci pour votre aide
Doux est déconnecté   Réponse avec citation
Aide pour virgin dump DAE Clio3, solution non trouvée sur le forum juned Immobilizer dumps/solutions 11 19/03/2015 20h14
Peugeot 307 Transmission stops working!Big Problem Kellertroll Section for english users 10 04/09/2014 12h58
rns-e unlock code via cd sos-compteur Autoradio et Navigateur GPS 13 22/11/2013 09h41
Fuseau horaire GMT +1. Il est actuellement 00h44.
