Vieux 16/08/2014, 02h11   #1
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut AL4 Programming
Hi There,
Does any one know how to connect to the AL4 ECU?? and what is the tool needed.
Regards,, Simple.
Simple est déconnecté   Réponse avec citation
The Following User Says Thank You to Simple For This Useful Post:
Mike H (20/08/2014)
Vieux 16/08/2014, 12h27   #2
Simple
Avatar de Simple
The car has done 160000 km, and the AL4 is supposed to be maintenance free. I changed the transmission oil last night and it very dark.
Now the car shifts through the gears much smoother.
Mike H (20/08/2014)
Vieux 17/08/2014, 09h02   #3
sepptdi
Avatar de sepptdi
sepptdi is an unknown quantity at this point
AL4 a un remplissage à vie. Fonctions Adapitive peuvent être réinitialisés
Les faits parlent pour Peugeot.
sepptdi est déconnecté   Réponse avec citation
The Following User Says Thank You to sepptdi For This Useful Post:
Mike H (20/08/2014)
Vieux 17/08/2014, 21h20   #4
Simple
Avatar de Simple
I have a generic Bluetooth OBDII adapter, I can reset codes using it. Is it possible to reset the Oil Change counter as well, using it?
Mike H (20/08/2014)
Vieux 20/08/2014, 08h36   #5
Mike H
Avatar de Mike H
Mike H will become famous soon enoughMike H will become famous soon enough
Par défaut reset compteur vidange sur citroen
Envoyé par Simple Voir le message
You don't tell witch type of your car.
Here's a manual way to reset the counter of oil change for c2 or c3, but you can find another video if you have a different type
https://www.youtube.com/results?sear...eur+vidange+C2
Best regards
Michel
Mike H est déconnecté   Réponse avec citation
The Following User Says Thank You to Mike H For This Useful Post:
Kevinio (22/08/2014)
Vieux 21/08/2014, 14h25   #6
Simple
Avatar de Simple
Sorry,
Having entered this data in may posts, I feel I have over done it, but then you are right.
Car: Citroen C8
Engine: 2.0 HDI
Gear: Automatic AL4
Regards, Simple.
Mike H (22/08/2014)
Vieux 21/08/2014, 14h27   #7
Simple
Avatar de Simple
Well, I have watched the attached video, it is about the engine oil. I need to reset the oil change counter for the Gearbox.
Vieux 22/08/2014, 08h55   #8
Mike H
Avatar de Mike H
Sorry,
Car: Citroen C8
Engine: 2.0 HDI
Gear: Automatic AL4
Regards, Simple.
I found this post in french:
xxxxxxxxxxxxxxxxxxxxxxxxxxxx
They say that this reset must be done by Citroën themselves, or you must buy the interface to acces the reset option
Edit : lien vers d'autres forum auto interdit.
Dernière modification par diagnosis29 ; 22/08/2014 à 09h08.
Vieux 24/08/2014, 02h20   #9
Simple
Avatar de Simple
@ Mike H,
Thanks, the link has been removed. However, I think you may be referring to a Lexia 3 device. I have ordered one already and I hope to be able to do this.
Now I need a repository to download the ECU firmware so that I can update them.
Thanks again, Simple.
Mike H (24/08/2014)
Vieux 24/08/2014, 07h19   #10
Mike H
Avatar de Mike H
@ Mike H,
Effectively, I don't remember this rule of the forum. I'll never put a direct line to another forum on an answer @diagnosis29
You're right for your answer, the only way to reset is an interface, like the Lexia.
I've seen that this problem often happens on an automatic C8.
At the begin, it's enough to turn off the engine, wait a few moment...
But later, you're in the problem. They also talk about E/V witch also can made a problem with this car
[SIGPIC][/SIGPIC] Si vous croyez qu'un professionnel va coûter cher, tentez l'aventure avec un amateur
Vieux 26/08/2014, 03h20   #11
Simple
Avatar de Simple
Currently I don't have a problem, but I wish to avoid having one. Hence the order of Lexia 3 tool.
By the way, it took me sometime to understand the difference between the various clones.
Mike H (26/08/2014)
Recherche PSA key programming device hakose Vente, Achat, Echange 12 25/05/2013 15h28
HC08 Programmer (Programming error) Nextrick Programmateur de composant (flasher) 7 04/04/2013 21h53
BR9010 programming benyunes Programmateur de composant (flasher) 0 22/01/2012 23h54
Renault PIN Code reading Key programming taxi300 Renault, Dacia, Nissan 0 17/03/2011 18h05
opel antara key programming addgsm Opel-Vauxhall, Saab 0 25/03/2009 21h52
Fuseau horaire GMT +1. Il est actuellement 03h35.
