Vieux 17/12/2009, 20h25   #1
digicar
Avatar de digicar
Post programmer cle de G4
salut tous
je souhaite programmer une clé sur golf4 ,je cherche a savoir la procédure avec vag com.
merci.
Vieux 17/12/2009, 23h08   #2
RGS
Avatar de RGS
tien voila la procedure mais en anglais
Key Matching
Prerequisites:
All keys are either new or were adapted to this car (IMMO-ID) before.
You can match up to 8 keys.
While adapting each key, make sure to place the other keys away from the ignition lock (reader coil). The passenger seat is an adequate place.
Battery voltage at least 12.5 V.
[Select]
[17 - Instruments]
[Meas. Blocks - 08]
Select Block 022.
[Go!]
The value in field 3 must be 1. If value is not 1, the key is not capable of being adapted to Immobilizer.
You can check each key in this manner.
Select Block 024.
[Go!]
Make sure the shown lock times in field 1, 2 and 3 are 0 (each field represents a time in minutes).
If the lock times are NOT 0:
Do NOT switch off the ignition!
Allow the car to sit for AT LEAST the number of minutes that were indicated by the fields 1-3.
[Done, Go Back]
[Login - 11]
There are 2 possibilities how to enter a PIN, choose the one that applies for you.
4-digit PIN
Enter zero followed by the 4-digit PIN. For example, if your PIN is 1234, enter 01234.
7-digit PIN
[Use 7-digit PIN/SKC]
Enter the 7-digit PIN, Date on which the PIN was generated by the dealer, along with the Workshop Code (WSC) and the Importer number of the dealer that generated the code.
[OK]
VAG-COM will validate the data you have entered and return you to the Login screen, where the Login Code will show as "XXXXX".
[Do it!]
[Adaptation - 10]
Enter 21 in "Channel Number".
[Read]
The "Stored Value" is the number of keys currently matched.
Enter a "new value" corresponding to the total number of keys to be matched, including any existing keys.
The old keys are automatically beeing cleared.
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
Repeat the following steps until all keys have been matched:
Switch ignition off and remove key.
Insert next key to ignition and switch ignition on again.
The warning light for the Immobilizer will light up for ~2 seconds, then go out Switch ignition off and remove key.
Note: The above steps after saving the adaptation, should not exceed 60 seconds!
The Following User Says Thank You to RGS For This Useful Post:
dav62 (29/10/2010)
Programmer cle clio 3 A-M-S programmation & synchronisation de clé 1 16/12/2009 00h33
Sbb key programmer tatisoft.renault programmation & synchronisation de clé 0 13/06/2009 19h27
which is a good key programmer eagle Outil de programmation 7 15/05/2009 16h57
Fuseau horaire GMT +1. Il est actuellement 12h50.
