I Need Help For This Ecu
Bosch 0281001969 |
I Read This B58 328ts
Help Me Please
THIS B58 328ts IS 24C02 RIGHT?
Fondateur
![]() Date d'inscription: novembre 2008
Pouvoir de réputation: 1335 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
what you need ?
immo key ?
🚀 MOD-FILES.COM Service de fichiers Chiptuning Haute Performance Stage 1, 2, 3 | FlexFuel - DPF - EGR - AdBlue - Pop&Bang CLIQUEZ ICI POUR ACCÉDER AU SERVICE 24/7 |
the car does not work, I wanted the best solution
Fondateur
The best and hard solution is to code a new key,
You will need: - Key to code key - Pin for this car - Key in good stat or transponder Regards
not enough to eliminate the immo, to work soon
#10 |
Fondateur
You want to eliminate the immo ?
#11 |
![]() Date d'inscription: décembre 2008
this is the immo off dump but must program it in a 24w02 ( 24 W 02) and cut ecu pin 59 and connect pin 7 of eprom to + 5V ( desolder from board) . search + 5V then after solder the eprom ( important else the motor start first and you must reprogram the eprom secondly)
pass in pm Dernière modification par ricards99 ; 11/01/2009 à 20h47. |
#12 |
yes
is possible? |
#13 |
yes is possible?
#14 |
Pouvoir de réputation: 20 ![]() ![]() |
HI
test the solution and send the rResul tanks |
#15 |
yes thank you
