Vieux 13/05/2013, 13h22   #1
legendaryslave
Avatar de legendaryslave
legendaryslave will become famous soon enough
Par défaut logiciel de code PIN ( Effi )
logiciel permettant d'extraire interface broches
Type de fichier : txt Effi.txt (53 octets, 205 affichages)
Dernière modification par cedrsan ; 28/09/2014 à 16h55.
legendaryslave est déconnecté   Réponse avec citation
The Following 44 Users Say Thank You to legendaryslave For This Useful Post:
abdel_ren (21/06/2013), adiago (13/05/2013), angels59 (14/05/2013), Auto16 (26/10/2013), autodiagauto (13/05/2013), bbatman (28/07/2013), ben6901 (10/04/2015), BOD69 (25/07/2014), bouizanne (17/01/2015), CALIBOS (15/05/2013), delphi38 (14/05/2013), dounga (21/10/2014), drissdiag (30/07/2013), Drogo (03/06/2013), estwood68 (08/08/2017), fakhri (24/09/2014), ferchichi (19/05/2015), ikhtisari (14/05/2013), jpay2 (17/09/2014), julien74 (04/06/2013), komorovskij (13/05/2013), lock66 (15/07/2013), losconosciuto (14/05/2013), mahfoud lichani (13/05/2013), marcodu45 (14/05/2013), matt1781 (04/06/2013), medcapot (15/05/2013), menzoulou (09/07/2013), nasisamy (27/10/2014), newfree (04/06/2013), nimbus (15/05/2013), prodiag (04/06/2013), rikaoua (14/07/2013), sahnoun363 (21/01/2015), sametelec2003 (25/09/2017), samscan (07/06/2013), sapopt (31/07/2013), sasa69 (01/06/2013), sawadogo2 (14/05/2013), Shadab (14/11/2014), tihiuvek (16/10/2014), valontiono (16/07/2013), vince bzh (14/05/2013), youcef_trik (13/05/2013)
Vieux 13/05/2013, 14h08   #2
nordin_93
Avatar de nordin_93
nordin_93 will become famous soon enough
Salut l'ami !
tu peux me préciser c'est quoi le soft que tu proposes .
merci du retour ....
a+
nordin_93 est déconnecté   Réponse avec citation
Vieux 13/05/2013, 15h26   #3
TAGRART
Avatar de TAGRART
TAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud ofTAGRART has much to be proud of
Envoyé par legendaryslave Voir le message
http://www.mediafire.com/?4ibkjsl2ek3nzjp
logiciel permettant d'extraire interface broches sans
....interface broche sans quoi?
Il faut etre plus explicite dans un poste
TAGRART est déconnecté   Réponse avec citation
Vieux 13/05/2013, 15h34   #4
mahfoud lichani
Avatar de mahfoud lichani
Pouvoir de réputation: 41
Thumbs up
merci mon frère d'Italie
1° participation extra
merci et bienvenu à notre table
on mange et on donne à manger
bonne journée
The Following User Says Thank You to mahfoud lichani For This Useful Post:
Vieux 13/05/2013, 17h52   #5
legendaryslave
non, je n'ai pas besoin de n'importe quelle interface fois que vous atteignez le dell'immobox d'enfouissement peut 'être chargé de doux à extraire le code PIN
The Following User Says Thank You to legendaryslave For This Useful Post:
nimbus (28/08/2013)
Vieux 13/05/2013, 18h42   #6
francab
Avatar de francab
francab is just really nicefrancab is just really nicefrancab is just really nicefrancab is just really nice
Merci pour ta participation. Peux tu t' expliquer un peu mieux. Je comprends qu'il ne faut pas d'interface .
(une fois que vous atteignez le dell'immobox d'enfouissement peut 'être chargé de doux à extraire le code PIN) ça je ne comprends plus. Veux tu dire de charger le dump de l'immobox ?
francab est déconnecté   Réponse avec citation
Vieux 13/05/2013, 22h29   #7
legendaryslave
vous à la lecture dell'immobox vous pouvez «obtenir le code PIN très utile
Type de fichier : jpg Cattura.JPG (94,8 Ko, 437 affichages)
The Following 12 Users Say Thank You to legendaryslave For This Useful Post:
autodiagauto (14/05/2013), CALIBOS (15/05/2013), danielif (22/10/2013), dounga (21/10/2014), drissdiag (18/07/2013), komorovskij (13/05/2013), marcodu45 (14/05/2013), MCNexo94 (04/06/2013), mouradiag (14/05/2013), nordin_93 (14/05/2013), sahnoun363 (21/01/2015), TAGRART (20/05/2013)
Vieux 14/05/2013, 09h58   #8
francab
Avatar de francab
C'est compri ce soft calcule code pin à travers du dump de l' immobox
Vieux 14/05/2013, 12h25   #9
angels59
Avatar de angels59
Pouvoir de réputation: 67
Bonjour à tous
Effectivement il a l'air trés utile ce soft , à tester ;-)
Vieux 03/06/2013, 23h00   #10
saysso
Avatar de saysso
saysso is on a distinguished road
Slt tout d'abord un grand merci ; mais un peut d'explication svp .
saysso est déconnecté   Réponse avec citation
Vieux 04/06/2013, 10h40   #11
skaner69
Avatar de skaner69
skaner69 will become famous soon enoughskaner69 will become famous soon enough
c'set un soft de zed bull qui est pas pal pour reperé l'eprom et identifier la ref , par contre il faut l'interface pour extraire le code pin
skaner69 est déconnecté   Réponse avec citation
Vieux 15/12/2013, 16h57   #12
hamido-kouba
Avatar de hamido-kouba
hamido-kouba is a jewel in the roughhamido-kouba is a jewel in the roughhamido-kouba is a jewel in the rough
Par défaut EFfi kms 2011
software EFfi voila.......... mot passe en pm
[Liens HS]
Dernière modification par cedrsan ; 04/05/2014 à 01h12.
hamido-kouba est déconnecté   Réponse avec citation
The Following 16 Users Say Thank You to hamido-kouba For This Useful Post:
Auto-Diag (16/12/2013), autodiag25 (29/12/2013), drissdiag (19/12/2013), juju64 (29/12/2013), kilog (23/01/2014), KOMMANE (16/12/2013), land2a (29/12/2013), mahfoud lichani (18/12/2013), mahiou (16/12/2013), mecanodiag93 (03/02/2014), morran (19/12/2013), nabile-airbag (16/12/2013), nasisamy (27/10/2014), Nico66 (15/12/2013), RBX59100 (22/01/2014), samnguen (16/12/2013)
Vieux 06/01/2014, 21h19   #13
juju64
Avatar de juju64
juju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to behold
bonsoir hamido ca fonctionne avec quelle interface? as tu une notice ou manuel , ca a l'air super comme programme
juju64 est déconnecté   Réponse avec citation
Vieux 06/01/2014, 21h38   #14
cedrsan
Avatar de cedrsan
Pouvoir de réputation: 183
cedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond repute
C'est pour Zed-Bull
http://www.youtube.com/watch?v=08VMLz0BSG0
Ced
cedrsan est déconnecté   Réponse avec citation
The Following 6 Users Say Thank You to cedrsan For This Useful Post:
ERIC" (19/10/2014), juju64 (06/01/2014), MecaTech (08/02/2014), mesrine_29 (03/02/2014), poze (29/01/2014), samnguen (03/02/2014)
Vieux 20/10/2014, 21h57   #15
david 34
Avatar de david 34
david 34 is a jewel in the roughdavid 34 is a jewel in the roughdavid 34 is a jewel in the rough
Par défaut EFfi pour le partage
Salut à tous,
Logiciel EFfi pour Zed-Bull, pour le partage
https://mega.co.nz/#!cdNwHDZK!vqXbUe...r6BWKifsIL0KWk
En mp pour le mot de passe
david 34 est déconnecté   Réponse avec citation
The Following 15 Users Say Thank You to david 34 For This Useful Post:
CHATONDU38 (20/10/2014), Licokite (23/10/2014), mahfoud lichani (22/10/2014), Momo44 (22/10/2014), perso69 (23/10/2014), rahmani2008 (30/12/2014), REDZONE31 (21/10/2014), sahnoun363 (21/01/2015), sametelec2003 (25/09/2017), Scanworld2020 (22/10/2014), seadoo831 (20/10/2014), Sebas974 (27/10/2014), skymoon (26/01/2015), technicien (27/11/2014), turbo (23/10/2014)
Pour vous les amis un generateur de code pour une multitude de logiciel sosauto Informatique 2 17/03/2014 22h56
Logiciel upa USB zouk86 Programmateur de composant (flasher) 5 08/06/2013 23h22
Logiciel SOTISEN Programmateur de composant (flasher) 3 25/12/2012 21h56
logiciel pour code pin BilChip Transponder, code pin 4 13/09/2012 23h00
Fuseau horaire GMT +1. Il est actuellement 08h11.
