![]() Date d'inscription: juin 2021
Pouvoir de réputation: 46 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
BMW + Toyota - PSdZData Full + Lite new
Toyota PSdZData 4.52.44 Full PSdZData 4.52.44 Lite BMW PSdZData 4.58.21 Full PSdZData 4.58.21 Lite PSdZData is a data package required for working with electronic control units (ECUs) in BMW, Mini, Rolls-Royce, and recently new Toyota models (developed jointly with BMW, such as the Supra A90). Here are the main differences between the Full and Lite versions: 1. What is it? Lite version: Contains only configuration files and ECU descriptions (SWFL, CAFD, etc.). This is the "skeleton" that allows the program to see the car and change settings. Full version: Contains everything the same, plus full firmware (SWFL, BTLD, etc.) for each ECU. This is a huge data set for a comprehensive software update. 2. Why are they needed? Lite: Used for coding (changing hidden functions, such as disabling Start/Stop) and diagnostics. It's lightweight (usually up to 1 GB) and sufficient for 95% of everyday tasks for owners or technicians. Full: Used exclusively for programming (flashing). If you want to update the firmware in your units to the latest version or restore a "brick" after an unsuccessful experiment, you need the full version. Summary: If you simply want to enable beautiful icons or disable the belt gong, download Lite. If you plan to significantly update the firmware in your units, make sure you have disk space available for the Full version. ![]() Need it? Push buttons Rate+Thanks, PM for pass.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment. |
| The Following 4 Users Say Thank You to Aleksey-MS For This Useful Post: |
#2 | |
Need it? Push button Thanks, PM for pass | or by email right now.
| The Following 2 Users Say Thank You to Aleksey-MS For This Useful Post: | Brandonivo (27/07/2026), youcar (02/06/2026) |
Added PSdZData 4.58.33 Full, Lite
What's new in 4.58.33: Latest firmware: Current integration levels (I-Level) as of spring 2026. New CAFD files: Required for programming the latest vehicles (without them, E-Sys will not read the updated ECUs and will display an error). Bug fixes: Updated factory software to fix errors in electronic control units (ECUs).
| The Following User Says Thank You to Aleksey-MS For This Useful Post: | Brandonivo (27/07/2026) |
#4 | |
Added PSdZData 4.59.30 Full, Lite. What's new: - Support for the latest I-Step (integration levels): Firmware and data have been updated for the latest BMW, MINI, and Rolls-Royce vehicles released up to mid-2026 (particularly relevant for the new U-series platforms and I-series electric vehicles). - Updated CAFD files: New files have been added for coding modules. If you attempt to code a new vehicle using old databases, the software E-Sys will display a CAFD missing error or show trimmed parameters without descriptions.
#5 | |
What's new in BMW PSdZData 4.60.11
* New I-Step (26-07): Integration levels have been added for programming vehicles starting in July 2026 (e.g., S18A-26-07-xxx). * Database Update: The latest firmware and coding files (SWFL, BTLD, CAFD) for current body styles (G60, G90, U- and I-series). * DME Lockouts: No new restrictions; flashing software from higher trim levels works as expected.
What's new in BMW PSdZData 4.60.42
Whats New in BMW PSdZData
- Dataset Release: Bumped the BMW branch up to 4.62.32 (both Full and Lite versions); Toyota stays at v4.60.42. - Updated I-Levels: Includes fresh November 2026 ECU firmware, bootloaders, and coding files for F, G, I, and new NA-series vehicles. - Usage Note: Lite version remains lightweight for everyday FDL/VO coding, while the Full archive contains complete flash data for ECU programming.
| BMW PSdZData 4.30.33 Lite - Mega | Aleksey-MS | BMW, Mini, Rolls-Royce | 46 | 12/03/2026 17h53 |
| BMW PSdZData 4.35.10 Lite - Torrent (without pass) | Aleksey-MS | BMW, Mini, Rolls-Royce | 5 | 26/07/2022 15h17 |
| BMW E-Sys3.28.1, E-Sys Launcher Prem. 2.7.0, Psdzdata V3.61.1 Lite | Nyckos | BMW, Mini, Rolls-Royce | 0 | 06/03/2018 10h54 |
| PSdZData v.4.10.13 - Lite et Full | Nyckos | BMW, Mini, Rolls-Royce | 2 | 06/03/2018 10h25 |
| BMW E-sys PSdZdata Lite 4.10.13 | Nyckos | BMW, Mini, Rolls-Royce | 0 | 06/03/2018 10h24 |
