Précédent   Tlemcen Car electronics > Outils & Diag > Diagnostic automobile > Logiciel & autres documentations général
Vieux 04/05/2026, 20h13   #61
yams25
Avatar de yams25
yams25 is an unknown quantity at this point
Merci pour le partage
yams25 est déconnecté   Réponse avec citation
Vieux 05/09/2026, 11h42   #62
Ralphe62
Avatar de Ralphe62
Ralphe62 has a little shameless behaviour in the past
Merci pour le lien. Pourrais-je avoir le MDP s'il vous plaît ?
Ralphe62 est déconnecté   Réponse avec citation
Vieux 02/10/2026, 15h20   #63
Aleksey-MS
Avatar de Aleksey-MS
Pouvoir de réputation: 46
Aleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond repute
Par défaut Carly Pro Mobile Diagnostics Mega Pack: All Brands, VAG, MB & Renault
WHAT INSIDE:
- Carly+v49.77+Unlocked.apk
- Carly for VAG_19.03.apk
- Carly for Mercedes_19.03.apk
- Carly for Renault_19.02.apk
DESCRIPTION:
Carly is the most powerful tool for mobile devices designed for car diagnostics, coding, and maintenance. This Mega Pack contains the fully unlocked universal application for all major car brands, as well as dedicated Pro versions optimized specifically for VAG, Mercedes-Benz, and Renault.
1. CARLY PRO ALL CAR BRANDS (UNLOCKED)
Supported car brands: Audi, BMW, Lexus, Mercedes, Mini, Porsche, Renault, Seat, Skoda, Toyota, and VW. Every car is unique, so specific features will vary with every model, build year, hardware, and software.
- CHECK THE CAR’S HEALTH AND SAVE MONEY: Read from all built-in electronic control units (ECUs), including engine, transmission, ABS, airbag, & multimedia. Gauge the severity of problems and clear fault codes.
- MONITOR LIVE DATA: Live parameters help you take the guesswork out of understanding what your car needs and detect fault origins.
- CODE AND CUSTOMIZE FEATURES: Access hidden features already set by the manufacturer and customize your car.
- PERFORM SIMPLE CAR MAINTENANCE: Analyze emission and engine gauges, change and register your car battery, perform an oil reset, and much more, all with your smartphone.
- DETECT MILEAGE MANIPULATION: Use Carly to perform a used car inspection before buying to avoid getting tricked.
2. CARLY VAG PRO FULL
Capable of working with VW, Audi, Seat, and Skoda since 1996.
- Coding: get access to the hidden features!
- Parameters: analyze engine parameters like a real professional!
- Check battery: replace the battery and register your car yourself!
- Service interval reset: be independent from your workshop!
- Soot filter: Turn on the regeneration of the soot filter with a single tap!
3. CARLY PRO MERCEDES-BENZ
The most powerful mobile tool that has been able to work with Mercedes cars since 2004.
4. CARLY RENAULT FULL PRO
Contains an unlimited license for health checks of all supported models. Includes Android diagnostics, coding, and real mileage check. Future updates for diagnostics-quality and all further functions like finding and clearing fault codes, full descriptions, and fault reports are included.
HARDWARE REQUIREMENTS:
To connect you need an OBD-II Bluetooth adapter (e.g., ELM327) or a K-DCAN cable. Recent versions work best with the original Carly device. The program receives all the information via the OBD2 interface.
HOW TO INSTALL:
1. Install the APK program.
2. Run the application.
3. Write any email.
4. Write any password.
Disclaimer: I provide links to APK files that I do not test myself. These should be full versions, but sometimes this is not the case.
Need it? Push button Thanks, PM for pass | or by email right now.
Type de fichier : txt Carly_Pro_Mobile_Diagnostics_Mega_Pack_NEW.txt (34 octets, 4 affichages)
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
Aleksey-MS est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to Aleksey-MS For This Useful Post:
Lsg-performance (08/11/2026), MrRorry (23/10/2026), zrekkab (23/10/2026)
Vieux 23/10/2026, 13h14   #64
zrekkab
Avatar de zrekkab
zrekkab is on a distinguished road
Envoyé par Aleksey-MS Voir le message
Carly Pro 48.03 + 90.36 beta All Car Brands (phone diagnostics)
These are supported by the following car brands: Audi, BMW, Lexus, Mercedes, Mini, Porsche, Renault, Seat, Skoda, Toyota, and VW. Every car is unique, so specific features will vary with every model, build year, hardware, and software.
Check the car’s health and save money
With Carly car diagnostics, you’ll have the right scanner tool to read from all built-in electronic control units (ECUs), including engine, transmission, ABS, airbag, & multimedia, keep track of your car’s health, gauge the severity of problems, clear fault codes, and more.
Monitor live data
Live parameters or live data can help you take the guesswork out of understanding what your car needs and detect the fault origins.
Code and customize features
Access hidden features already set by the manufacturer and customize your car to fit your needs. This feature is only available on certain car brands/models, and the coding options vary.
Perform simple car maintenance independent of the workshop
Detect mileage manipulation
Car mileage manipulation is on the rise. Don’t get tricked. Use Carly to perform a used car inspection before buying.
Recent versions only work with the original Carly device.
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
zrekkab est déconnecté   Réponse avec citation
Vieux 26/10/2026, 19h24   #65
Aleksey-MS
Added Carly 50.03 Unlocked.
What's New:
Updated diagnostic databases and coding parameters for recent vehicle models across all supported brands (VAG, BMW, Mercedes, Renault, etc.).
Improved stability and communication speed when using generic OBD-II Bluetooth adapters.
Enhanced battery registration, service reset, and DPF regeneration functions for newer engine control units.
Vieux 06/11/2026, 16h19   #66
Aleksey-MS
Added Carly 50.04 Unlocked.
What's New: Database update, bug fixes, and stability improvements
Vieux 08/11/2026, 12h52   #67
Gwy
Avatar de Gwy
Gwy is an unknown quantity at this point
Merci pour le partage ;o))
Gwy est déconnecté   Réponse avec citation
Carly 90.01 Beta garibek Mobile Windows CE, Android, iOS 0 02/07/2021 08h25
Autoradio Audi concert 2 fonction phone tofone Autoradio et Navigateur GPS 0 15/01/2013 00h36
ford 6000 cd rds e-o-n display phone rikaoua Autoradio et Navigateur GPS 2 04/03/2012 23h24
Fuseau horaire GMT +1. Il est actuellement 04h26.
