Vieux 03/01/2026, 15h39   #1
Verdun
Avatar de Verdun
Verdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud of
Par défaut code pin ou isk
Bonjour suite a un retour de vol j aurai besoin de recupere l isk ou le pin d un calculateur dcm3.4 renault clio 3 pour reconfigurer sur un uch d occasion j ai réussi a lire l eeprom de l ecu merci
95640 dcm3.4 clio.bin
Verdun est déconnecté   Réponse avec citation
Vieux 03/01/2026, 15h56   #2
phil1
Avatar de phil1
Pouvoir de réputation: 109
slt voila pr toi
CRYPTO LO: 9E 7B 0B 68 CRYPTO HI: C0 AB
The Following 7 Users Say Thank You to phil1 For This Useful Post:
a3pughjolu (24/05/2026), binbin29 (08/06/2026), jean-marc 10 (04/01/2026), mcmomo (03/01/2026), Snatsh (03/01/2026), Verdun (03/01/2026)
Vieux 04/01/2026, 01h23   #3
Verdun
Avatar de Verdun
Nickel problème résolu merci a toi
The Following User Says Thank You to Verdun For This Useful Post:
phil1 (04/01/2026)
Vieux 23/05/2026, 17h23   #4
LION06000
Avatar de LION06000
LION06000 is an unknown quantity at this point
je suis dans le même cas vous pouvez m'aider s'il vous plaît☺️
par contre c'est moi qui a effacé les données de mon UCH je dois juste le recode avec un bon pin et ISk valide.
j'ai le fichier eeprom de mon ecu calculo
Merci d'avance
LION06000 est déconnecté   Réponse avec citation
Vieux 24/05/2026, 08h44   #5
a3pughjolu
Avatar de a3pughjolu
Pouvoir de réputation: 23
a3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud ofa3pughjolu has much to be proud of
Bonjour l'ami
Sur ton dump, il me sort ça
ISK : 9E 7B 0B 68 C0 AB
---------- Post added at 08h42 ---------- Previous post was at 08h40 ----------
Envoyé par phil1 Voir le message
slt voila pr toi
J'arrive une fois de plus trop Tard...
---------- Post added at 08h44 ---------- Previous post was at 08h42 ----------
Envoyé par LION06000 Voir le message
Merci d'avance
Salut envoi fichier eeprom
Aider et etre Aidé Pas de Thanks Pas de réputation Plus d'aide
The Following User Says Thank You to a3pughjolu For This Useful Post:
Vieux 08/06/2026, 13h34   #6
binbin29
Avatar de binbin29
binbin29 is an unknown quantity at this point
J'ai malheureusement le même problème que LION06000, je me permets d'intervenir.J'ai une Twingo III UCH vierge, après beaucoup de recherches sur le forum, 2 options s'offrent à moi si j'ai bien compris : passage chez Renault ou alors je flashe l'eeprom de l'ecu et avec beaucoup de chance un membre du forum arrivera à me fournir le code ISK ?
merci d'avance
binbin29 est déconnecté   Réponse avec citation
Vieux 08/06/2026, 16h36   #7
matt978
Avatar de matt978
matt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud ofmatt978 has much to be proud of
Envoyé par binbin29 Voir le message
merci d'avance
essaye de lire l'eeprom de ton ECM
c'est quoi la ref de ton ECM et de ton UCH?
If you want to touch the sky, f**k a duck and try to fly!
matt978 est déconnecté   Réponse avec citation
The Following User Says Thank You to matt978 For This Useful Post:
Vieux 08/06/2026, 21h09   #8
binbin29
Avatar de binbin29
Il s’agit d’un bosch réf : 261s16247
---------- Post added at 21h09 ---------- Previous post was at 21h04 ----------
Et l’uch est un EMM-T4 L4
Vieux 08/06/2026, 21h15   #9
matt978
Avatar de matt978
Tu as de quoi lire l eeprom de ton ECM?
Genre kt200
Autotuner
Kess v3 (pas sûr que les v2 passent les twingo 3)
Vieux 08/06/2026, 21h32   #10
Pouvoir de réputation: 113
l'ecu va jamais avoir un isk long comme dans le T4
Vieux 08/06/2026, 21h46   #11
binbin29
Avatar de binbin29
je peux lire l'eeprom en direct sur l'ecm avec iprog ?
Apres je n'ai que kess V2...
Vieux 09/06/2026, 00h52   #12
binbin29
Avatar de binbin29
Envoyé par matt978 Voir le message
Genre kt200
Autotuner
Après avoir ouvert l'ecm je comprend mieux ta question ...
Je pense qu'un ami arriverai à me sortir le dump mais pensez-vous qu'avec celui-ci, il serait possible d'obtenir le code isk ?
Vieux 09/06/2026, 08h18   #13
matt978
Avatar de matt978
Écoute fils il a bcp plus d expérience que moi.
A première vue le code isk long n'est que dans l uch.
Et pour reprogrammer des clés c'est le long quil faut.
binbin29 (09/06/2026)
Vieux 09/06/2026, 08h29   #14
pas super calé la dessus mais de memoire ecu 12 bit et T4 32bit
va en manquer un peu
et encore un peu plus avec un kess v2 lol
les joies du renolink aliexpress :-)
binbin29 (09/06/2026), matt978 (09/06/2026)
Vieux 16/06/2026, 18h53   #15
binbin29
Avatar de binbin29
Bonjour, je viens aux nouvelles, passage avec un technicien Renault 2 minutes après la connexion sur clip voiture démarre, en revanche je n'arrive pas à obtenir le code pin / isk via renolink et le technicien ne pouvait apparemment pas l'avoir avec sa valise...
The Following User Says Thank You to binbin29 For This Useful Post:
matt978 (16/06/2026)
Peugeot Partner II 2008 : code pin, code taille, code centralisation arso02100 Outil de programmation 6 01/11/2023 10h50
Citroen refuse de me fournir le code pin de la clé (code confidentiel BSI) redmou PSA Group Peugeot, Citroën 27 07/01/2020 22h51
code injection immobilizer renault dacia code antidémarrage yahia1908 Transponder, code pin 0 19/10/2017 16h04
demande modification dump pour eliminer code code off ziamo Autoradio et Navigateur GPS 3 19/01/2013 01h07
Fuseau horaire GMT +1. Il est actuellement 07h32.
