#61 |
![]() Date d'inscription: juin 2021
Pouvoir de réputation: 46 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Added
Ford IDS 131.04
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment. |
| The Following User Says Thank You to Aleksey-MS For This Useful Post: | joel_191 (03/08/2026) |
#62 |
Added
Ford FJDS 131.04
#63 |
Added
FDRS 46.5.6 Ford IDS 132.04 Ford FJDS 132.04
#64 |
Ford IDS 132.04 + FJDS 132.04 + FDRS 47.6 + Mazda IDS 132 - for VCM2 / J2534
IDS. IDS provides complete dealership level vehicle diagnostic coverage for all 1996 to select 2018 Ford, Lincoln, Mercury vehicles. IDS requires the use of Ford diagnostic hardware VCM II. FJDS provides module reprogramming software that covers 1996 to select 2018 Ford, Lincoln, and Mercury module reprogramming functions, plus complete dealership level diagnostic software for all 2018 to present Ford and Lincoln vehicles. FJDS is designed for use with J2534 compatible Vehicle Communications Interfaces (VCI) including Ford diagnostic hardware VCM II. FDRS - next-generation factory Ford Motor Company vehicle diagnostic Software designed for use with VCM II and J2534 compatible VCI. FDRS provides complete dealership-level vehicle diagnostic coverage for some 2018 and forward vehicles. FDRS provides superior capabilities, is more user-friendly, and provides more diagnostic tools than IDS. ![]() Need it? Push buttons Rate+Thanks, PM for pass. Added to a new file sharing service. It works faster and without registration or downloading their application. Ford FDRS 47.6. What's new: Optimization: Improved software stability. Support: New calibration files added for recent Ford/Lincoln models. Fixes: Resolved minor bugs from the previous version.
| The Following 4 Users Say Thank You to Aleksey-MS For This Useful Post: |
#65 |
Added Ford FDRS 47.6.9.
Download link What's new: Full diagnostic and programming support has been added for all 2026 model year Ford and Lincoln models, including updated EVs and hybrids. Software update algorithms via CAN-FD and Ethernet protocols have been optimized, reducing programming time for large modules (e.g., SYNC multimedia). Battery Health analysis features have been expanded for the new generations of the Mustang Mach-E and F-150 Lightning. Step-by-step troubleshooting instructions for new driver assistance systems (BlueCruise/ADAS) have been updated.
#66 |
Mazda IDS 136 — What's New:
2025–2026 Model Support: Full diagnostics and coding for the latest Mazda CX-90, CX-70, and updated CX-5 models. Expanded Calibration Database: Updated firmware files (PATS, PCM, TCM) to correct factory errors in gear shifting algorithms and engine management. Improved Hybrid Support (MHEV/PHEV): Added new special functions for checking the high-voltage battery condition and bleeding the inverter cooling system. VCM II / VCM 3 Optimization: Improved connection stability and data transfer speed when using original adapters and high-quality clones. On-Screen Menu Update: The interface has become slightly more responsive, and tooltips for new DTCs for ADAS systems (lane assist, adaptive cruise control) have been added. Need it? Push buttons Rate+Thanks, PM for pass | or by email right now.
#67 | |
Added. FDRS 48.4.1 FJDS 132.05 Ford IDS 132.05 What's new: Fresh calibration files: New software versions for control units have been added (often related to new recalls). Certificates and security: Security tokens for communication with Ford servers have been updated. Spot fixes: Fixed errors that dealers frequently complained about in the previous build (for example, if in 132.04 the flashing of a specific control unit was interrupted due to a timeout, this timing was adjusted in 132.05).
#68 |
![]() Date d'inscription: août 2019
Pouvoir de réputation: 9 ![]() ![]() |
Salut Alex,
Impossible de faire un tourneo custom de 2019 avec ? j'ai un limiteur de vitesse a désactiver dessus. merci |
#69 | |
Added Mazda IDS 142. What's New:
#70 |
Ford IDS 133.01 + FJDS 133.01 + FJDS_TimeoutReset + FDRS 48.4.1 + Mazda IDS 136, 142
IDS. IDS provides complete dealership level vehicle diagnostic coverage for all 1996 to select 2018 Ford, Lincoln, Mercury vehicles. IDS requires the use of Ford diagnostic hardware VCM II. FJDS provides module reprogramming software that covers 1996 to select 2018 Ford, Lincoln, and Mercury module reprogramming functions, plus complete dealership level diagnostic software for all 2018 to present Ford and Lincoln vehicles. FJDS is designed for use with J2534 compatible Vehicle Communications Interfaces (VCI) including Ford diagnostic hardware VCM II. FDRS - next-generation factory Ford Motor Company vehicle diagnostic Software designed for use with VCM II and J2534 compatible VCI. FDRS provides complete dealership-level vehicle diagnostic coverage for some 2018 and forward vehicles. FDRS provides superior capabilities, is more user-friendly, and provides more diagnostic tools than IDS. ![]() Need it? Push buttons Thanks, PM for pass | or by email right now.
#71 |
What's new in Mazda IDS
* Version Update: Software updated to Mazda IDS 143.00. * Calibration Update: Included the latest calibration files for the newest Mazda models.
#72 |
What's new in Ford IDS & FDRS
* Version Update: Software updated to IDS-133.02 and FDRS-49.5.12. * Calibration Update: Included the latest calibration files for the newest Ford models.
#73 |
Update Highlights - Ford IDS & FDRS
- New Builds: Package updated with the latest Ford IDS 133.03 and FDRS 50.5.4 releases. - Module Data: Added updated factory calibrations and reprogramming support for newer vehicles. - Included Tools: Features the FJDS_TimeoutReset utility to bypass trial limits and hardware blocks.
| Ford IDS 122 + FJDS 122 + FDRS 28.6.3 + Mazda IDS 122 - pour VCM2 / J2534 | Aleksey-MS | Ford, Mazda, Land Rover, Jeep, Jaguar | 47 | 02/11/2022 12h06 |
| driver vcx ford vcm2 | nabin70 | VCMII, IDS, JLR ...etc | 2 | 30/08/2019 15h42 |
| Vcm2 ford | 2009mohrice | VCMII, IDS, JLR ...etc | 1 | 22/06/2018 10h15 |
| probleme sur ford vcm2 rotunda | shasse | Ford, Mazda, Land Rover, Jeep, Jaguar | 3 | 26/04/2017 14h07 |
| Avis sur un achat de ford vcm2 | raed83300 | VCMII, IDS, JLR ...etc | 8 | 05/03/2017 23h02 |
