![]() Date d'inscription: juin 2021
Pouvoir de réputation: 46 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Cummins Insite 8.8. 8.7, 8.5.2 - Mega + Cummins Incal (without pass)
A program for dealer diagnostics of Cummins engine control systems.
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment. |
| The Following 7 Users Say Thank You to Aleksey-MS For This Useful Post: | Faridovitche (10/10/2023), FletesRGC (12/08/2026), kevine (26/08/2025), MecaTech (08/04/2025), Oudy (12/02/2026), out525 (03/02/2025), Tracteur_tom (06/02/2024) |
The link was updated
Added Cummins Insite 8.8.1
| The Following User Says Thank You to Aleksey-MS For This Useful Post: | MecaTech (08/04/2025) |
Working link
New working link
Added
Cummins Insite 8.9.2
Added
Cummins Insite 9.0.1
Added Cummins INSITE 9.03 (0022).
What’s new there: New Engine Support: Full diagnostic support for 2024–2026 engine models (including EPA24 platforms). Enhanced Security: Updated authentication protocols for accessing protected ECMs and changing sensitive parameters. Performance Boost: Faster real-time data monitoring and reduced latency in the Data Monitor/Logger. OS Compatibility: Improved stability and bug fixes specifically for Windows 11. Advanced Aftertreatment: Updated tests for DPF/SCR systems to meet the latest emission standards. Connectivity: Enhanced driver stability for Inline 7 and Nexiq 3 adapters.
#10 | |
![]() Date d'inscription: août 2017
Pouvoir de réputation: 24 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
En technique, bien souvent : mieux vaut la fermer que dire des conneries |
#11 | |
#12 |
Cummins Insite 9.3 + Incal 02.2026
Cummins Insite is software for diagnosing, configuring, and repairing electronic control units (ECUs) for Cummins engines. Cummins Incal is a database of factory firmware (calibrations). It is used to adjust engine power, fix software errors, or update engine emission standards. Cummins Insite works with any diagnostic adapter that supports the RP1210 protocol. Original: Cummins INLINE (versions 5, 6, 7). Third-party equivalents: Nexiq USB-Link (versions 1, 2, 3), Dearborn DPA 5, Noregon DLA+. ![]() Need it? Push buttons Rate+Thanks, PM for pass.
| The Following User Says Thank You to Aleksey-MS For This Useful Post: | FletesRGC (12/08/2026) |
#13 |
Added Incal 02.2026 and a new fast file sharing service.
#14 | |
#15 | |
Added by Cummins Incal on April 2026. What's New: Engine database updates: The latest firmware has been added for a wide range of current engines, including: The B4.5 series (CM2220, CM2350/CM2450) and B5.6 series (CM2670). ISB4.5/6.7 and ISD4.5/6.7 (including Euro 4.5 and Euro 5 emissions standards). 6.7N CM2380 and gas versions (C8.3G, B5.9G). Updates for Agility fuel systems (CM1881). Additional files, such as Cummins ED-4 (for Marine C Command panels). Structure (13 discs): Discs 1–8 and part of disc 9 — automotive applications (Automotive). From the second half of disc 9 through disc 13 — industrial equipment (Industrial). Disc 13 additionally contains files for heavy-duty engines and generator sets (HHP / Power Gen).
| Cummins Insite 7.6 | mod-files.com | Cummins | 1 | 14/11/2019 23h26 |
| Cummins Incal 02.2017 | mod-files.com | Cummins | 4 | 02/06/2017 21h14 |
| Cummins INCAL 02.2012 | TAGRART | Logiciel & autres documentations général | 0 | 02/09/2012 14h13 |
