Vieux 05/04/2019, 07h23   #16
Alessiapia14
Avatar de Alessiapia14
Pouvoir de réputation: 69
Pouf info xentry passthru tourne sur Windows 32 bits avec une smart 451.480c ok, d'autre j'attend pour faire un retour.
---------- Post added at 05h23 ---------- Previous post was at 05h21 ----------
Envoyé par Alessiapia14 Voir le message
Pour deuxième gen tu as celui là
Officiel
https://www.ime-actia.de/download/so...k-2.8.1.24.zip
Vieux 06/04/2019, 10h24   #17
marikette
Avatar de marikette
marikette has a spectacular aura aboutmarikette has a spectacular aura about
Par défaut Actia-XS-Passthru-64bit-Driver- 1Gen VCI-
Envoyé par Roturbo Voir le message
64bit drivers for Actia Passthru+ XS (1 gen yellow & blue interface).
Maybe the first release on the World Wide Web, the old VC1 from Actia
IS working as J2534 on 64bit Windows 7. :wink:
You are the only one to blame if something goes wrong, so first make backup of important data,
or test this instructions first inside a Virtual Machine or any testing PC.
Remember, i don´t have responsibility of any kind, any problem you solve it,
i have test it and it works, and it is free for you to test,, only IF YOU WANT.
Instructions (please follow the more detailed installation inside RAR file)..
No need to disable Anti_Virus, and i strong advise you to do a virus scan on this folder.
This modified drivers are only to work as PassThru under 64bit,
it will not work with Actia Multidiag software, because the interface
is not recognized, for Multi-Diag Actia-Connect use a 32bit OS.
1º install --I+ME-Actia-PassThru-XS-Driverpack-xx1--
2º install --I+ME-Actia-PassThru-XS-Driverpack-xx2--
Go to device manager and chose update drivers for Passthru+ XS,
chose ""Browse my computer for driver software""
Than click "NEXT" it will give you driver warning, press "Yes",,
it will open a red windows security about the publisher, just
click ""Install this driver software anyway""
It will confirm Updated Driver software success, next remove power from
the interface, power it up again, if asking again for drivers just repeat
one more time the process,, if you see the serial number on the driver name ,
power down, power up install driver,and is done.
If this software "I+ME-Actia-PassThru-XS-Driverpack-xx1" is not installed than
your interface will not be listed as a PassThru interface, so you must install it.
This way you will have the 1Gen interface (blue & yellow) listed as available
for any software working with passthru (under 64bit), just select it and start working.
Tested several times in Windows 7 64bit, communication confirmed with
Forscan, Xentry, etc.
Probably there is easy ways to do the same, but this was the fastest i have
discovered by myself, and works without problems.
Also i have Vas5054 working on 64Bit, but is on testing, the xentry
picture show it listed on the available Passthru interfaces (last picture).
You can download the Pictures-mega-link if this ones vanish (no pass),
for the Mega-link.rar PASSWORD you need to follow the next instructions.
First you press and than ,, next send PM with title
-64bit drivers for Actia Passthru+ XS-password-
And you will get BY PM the password for Megalink.
DO NOT ASK THE PASSWORD ON THE BOARD.
Password Pm= Thanks+Rep
ROTURBO.
hello
please possible password fichier rar for installation actia 64b thank.
Chercher n'est pas forcément trouver et ce que tu trouves n'est pas toujours ce que tu cherchais.
marikette est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to marikette For This Useful Post:
Emma (30/08/2021), ituncinho (01/02/2025)
Vieux 24/04/2019, 06h19   #18
Roturbo
Avatar de Roturbo
Roturbo has a spectacular aura aboutRoturbo has a spectacular aura aboutRoturbo has a spectacular aura about
Hello.
New link and pass.
Regards
Type de fichier : rar Mega-Link-Actia-64bit-drivers.rar (579 octets, 111 affichages)
Roturbo est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to Roturbo For This Useful Post:
fkminos (14/03/2021), Ralphe62 (11/04/2026), taxi5114 (10/04/2021)
Vieux 23/09/2019, 23h46   #19
seboune66
Avatar de seboune66
seboune66 can only hope to improve
Ma vci v1 actia ce connecte bien avec xentry en Windows 7 64bits mais donne un voltage erroné 2volts sur tous les véhicules...��
Une solution?
seboune66 est déconnecté   Réponse avec citation
Vieux 23/09/2019, 23h57   #20
seadoo831
Avatar de seadoo831
Pouvoir de réputation: 124
salut en 4 ans d inscription 3 messages seulement et deux demande d aide rien de plus tu vas difficilement trouver de l aide crois moi
Pas de Thank's plus d aides
The Following 4 Users Say Thank You to seadoo831 For This Useful Post:
gary01 (24/09/2019), jah83 (24/09/2019), vortex (24/09/2019), Y.B tec (24/09/2019)
Vieux 18/10/2019, 16h47   #21
adjee
Avatar de adjee
adjee is on a distinguished road
merci Roturbo pour ce partage,
j'ai deja teste d'autres appareil passthru ( VCMII, AVDI ) avec des softs comme xentry et odis mais ça ne marche pas pour toutes les fontions j'attends voir ce que ça donne avec actia bleu.
adjee est déconnecté   Réponse avec citation
Vieux 06/11/2020, 21h43   #22
Habib46300
Avatar de Habib46300
Habib46300 is an unknown quantity at this point
Bonsoir
A propos du driver actia passthru 64 bit
j'ai essayé sur windows 10 64 bit , ca ne marche pas
par contre sur windows 7 64 bit et 32 bit , impeccable
donc j'ai monté deux machines virtual box
pour xentry 2018 , une en 64 bit et une en 32 bit , pour comparer
les diags (communication)
merci beaucoup Roturbo , il fallait avoir l'idée , l'astuce !!!!!!!!!
bonjour zenata,
j'ai chercheé les drivers actia passthru 64 bit partout mais je ne les ai pas trouvé, tu peus m'aider stp ?
Habib46300 est déconnecté   Réponse avec citation
Vieux 14/03/2021, 17h43   #23
fkminos
Avatar de fkminos
Pouvoir de réputation: 23
fkminos is a splendid one to beholdfkminos is a splendid one to beholdfkminos is a splendid one to beholdfkminos is a splendid one to beholdfkminos is a splendid one to beholdfkminos is a splendid one to beholdfkminos is a splendid one to beholdfkminos is a splendid one to behold
Je sais que ce post date, mais quelqu'un a t-il réussi à faire fonctionner l'actia passthru 1ere génération, sur un Win10 64bits?
En ce qui me concerne. Je suis bloquer, les drivers de ROTURBO ne fonctionnent pas donc avant de m'acheter un VCI sous 64, j'aimerais autant savoir si c'est possible.
Bien cordialement et bonne fin de WE à tous.
Le savoir est un fantasme qui n'est fait que pour la jouissance.
fkminos est déconnecté   Réponse avec citation
Vieux 18/03/2024, 15h48   #24
xflow
Avatar de xflow
xflow is an unknown quantity at this point
Thx bro. Very good job
xflow est déconnecté   Réponse avec citation
Vieux 20/01/2025, 14h54   #25
NOVAG
Avatar de NOVAG
Pouvoir de réputation: 7
NOVAG will become famous soon enough
J'ai récupéré une VCI Actia gen 1 originale par contre impossible de trouver le driver x64 à chaque fois les liens mega sont expirés, est-ce que quelqu'un aurait ça dans son pc?
Merci beaucoup d'avance.
NOVAG est déconnecté   Réponse avec citation
Vieux 20/01/2025, 16h17   #26
nicokartcross
Avatar de nicokartcross
Pouvoir de réputation: 8
nicokartcross will become famous soon enoughnicokartcross will become famous soon enough
Envoyé par NOVAG Voir le message
Envoie moi un mp je peut peut etre te depanner ... moi j ai une autre demande en mp pour toi
Sonde actia jaune et bleu ?
cdt
nicokartcross est déconnecté   Réponse avec citation
Vieux 20/01/2025, 17h19   #27
NOVAG
Avatar de NOVAG
J'ai retrouvé le mot de passe pour le fichier dont tu avais besoins je viens de te l'envoyer par MP.
C'est ça sonde jaune et bleu dans une malette Actia avec pleins d'adaptateurs différents.
The Following User Says Thank You to NOVAG For This Useful Post:
nicokartcross (21/01/2025)
Vieux 21/01/2025, 13h32   #28
nicokartcross
PARFAIT MERCI
Tu est en 64 bit ?
Vieux 21/01/2025, 13h45   #29
NOVAG
Avatar de NOVAG
oui mais si j'ai bien compris en 64 bit on ne peut utiliser l'interface qu'en mode Passthru sur des softs comme Xentry, Forscan .... si on veut utiliser Multidiag avec la VCI I il faut une VM avec un windows en 32 bit c'est bien ça ?
Vieux 21/01/2025, 14h59   #30
nicokartcross
Oui je regarde ce soir , j ai un soft avec drivers . je sais plus si il est en 64 ou 32 .
je te dis ca
ACTIA XS PassThru+ original Shadows93 Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 17 07/05/2018 18h33
Probleme de driver ACTIA 2016 sous win 7 mindouza Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 17 01/05/2018 05h54
[BDM100] Drivers W7 64bit zouk86 Programmateur de composant (flasher) 0 01/10/2017 10h09
winols en 64bit luce46M57 Logiciel & autres documentations général 3 08/10/2014 13h38
driver actia multidiag 2010 bebert97490 Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 7 16/09/2014 14h51
Fuseau horaire GMT +1. Il est actuellement 05h49.
