Vieux 05/11/2020, 12h41   #1
hadil
Avatar de hadil
hadil is a jewel in the roughhadil is a jewel in the roughhadil is a jewel in the rough
Par défaut Pedal de frein tres dure (pas de frein)c4 picasso
J ai une c4 picasso de 2010
J ai la pedal de frein tres très dur (sa ne frein quasiment pas)j ai contrôle le circuit frein ca ma l air bon
J ai contrôle pompe hydraulique abs fonctionne
J ai changé le pompe a vide est la durite qui par du mastervac a la pompe a vide...je sais qui ya un clapet anti retour dans cette durite...
Je sais plus quoi contrôle la...
Qui aurai des infos svp merci a vous
hadil est déconnecté   Réponse avec citation
Vieux 05/11/2020, 12h45   #2
barthdu22
Avatar de barthdu22
barthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud ofbarthdu22 has much to be proud of
Salut, c est quoi comme moteur ? Quand tu as changer la pompe a vide tu as regarder que le bout d arbre a came n etait pas cassé ?
barthdu22 est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to barthdu22 For This Useful Post:
bilal59100 (13/11/2020), hadil (05/11/2020), zenata (05/11/2020)
Vieux 05/11/2020, 13h01   #3
yahiadiag
Avatar de yahiadiag
yahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond reputeyahiadiag has a reputation beyond repute
tu as contrôle fuite d’air servon frein coti pédale de frein
---------- Post added at 12h01 ---------- Previous post was at 11h59 ----------
tu as contrôle fuite d’air de servo frein coti pédale
yahiadiag est connecté maintenant   Réponse avec citation
The Following 3 Users Say Thank You to yahiadiag For This Useful Post:
gchx (07/11/2020), hadil (05/11/2020), zenata (05/11/2020)
Vieux 05/11/2020, 13h03   #4
vv58
Avatar de vv58
salut pour controler pompe a vide il faut controler la depression soit tu debranches le tuyau au mastervac et tu bouches avec ton doigt moteur en route il doit etre aspiré tu coupes le moteur la depression doit tenir le mieux c est un mano en derivation(tout est branché) sur la durite ou piquage anexe moteur en route a peine 1 bar de depression mais qui doit monté rapidement tu arretes le moteur cette depression environ 850mbars ne doit pas bougé sinon tu as une fuite mastervac ou pompe ect
The Following 3 Users Say Thank You to vv58 For This Useful Post:
Vieux 05/11/2020, 13h42   #5
boris93600
Avatar de boris93600
Pouvoir de réputation: 52
Tu confirmes avoir 0 défaut (DTC) dans le bloc ABS/ESP ?
hadil (05/11/2020)
Vieux 05/11/2020, 14h01   #6
boris93600
Quels travaux ont été fait sur le véhicule ?
Tous les connecteurs ont été rebranché correctement ?
hadil (05/11/2020)
Vieux 05/11/2020, 14h37   #7
hadil
Avatar de hadil
Moteur 1.6 hdi
La pompe a vide fonctionne a aspire quand le moteur tourne
La durite qui par du mastervac a la pompe a vide est bonne j ai changé 3 durite dans le doute
Au diag pas défaut non plus
Tout les connecteurs son bien en place
Je vient d enlevé la partie sevofrein la pedal c est débloquer....
En appuyant sur le frein je vous bien la tige qui pousse la petit pompe sur le sevofrein
Maisbje ne sais toujours pas ci c est bien cette pieces qui mort
Vieux 05/11/2020, 19h34   #8
Mécanichien
Avatar de Mécanichien
Mécanichien is an unknown quantity at this point
Regarde si tu entends de l'air quand tu pompe ou si tu n'as pas.un bouchon avec le mastervac
Envoyé de mon P10000_Pro en utilisant Tapatalk
Mécanichien est déconnecté   Réponse avec citation
The Following User Says Thank You to Mécanichien For This Useful Post:
hadil (07/11/2020)
Vieux 06/11/2020, 23h24   #9
Jock66
Avatar de Jock66
Pouvoir de réputation: 68
Si pedale tres dur manque ou pas d’assistance du tout !
Controle la dépression de la pompe a vide avec un mano !
-1 bars environ, et controle si le mastervac ne fuit pas, ou pas de dot 4 dedans ( si c’est le cas mastervac hs plus maitre cylindre qui fuit )
hadil (07/11/2020)
Vieux 07/11/2020, 13h30   #10
dixneuf57
Avatar de dixneuf57
dixneuf57 is on a distinguished road
Salut tu dois avoir une fuite d'air ou une durite ou autre regarde au niveau de la bombonne si tz pas une fuite
dixneuf57 est déconnecté   Réponse avec citation
The Following User Says Thank You to dixneuf57 For This Useful Post:
hadil (07/11/2020)
Vieux 07/11/2020, 18h29   #11
SToXiT
Avatar de SToXiT
SToXiT is an unknown quantity at this point
Envoyé par dixneuf57 Voir le message
Merci j'avais le même problème et c'était bien la bombonne qui déconnait chez moi
SToXiT est déconnecté   Réponse avec citation
The Following User Says Thank You to SToXiT For This Useful Post:
hadil (07/11/2020)
Vieux 07/11/2020, 18h58   #12
hadil
Avatar de hadil
J ai pris un mastervac a ma casse je vais le change je vous tien au courant .
Merci tous
The Following User Says Thank You to hadil For This Useful Post:
gchx (08/11/2020)
Vieux 10/11/2020, 15h36   #13
hadil
Avatar de hadil
Bon j ai changé le mastervac, j ai la pedal qui est devenu normal mais toujours pas de frein ,ça frein tres très peux en forçant
Bien sur j ai pure les frein après avoir changé le mastervac
Je sais plus quoi faire la
Vieux 10/11/2020, 17h09   #14
sadna
Avatar de sadna
Pouvoir de réputation: 36
Envoyé par hadil Voir le message
Je ne sais pas ce qui est arrivé a ta voiture, mais on dirait qu'il y a eu un probleme avec le liquide de frein ou un liquide qui a du mal se melanger au liquide de frein et a ruiner ton systeme.
te reste a demonter tes etriers, controler qu'il n'ya pas de la limaille bizzare ou des granulés,
controler le fonctionnement de ton ABS.
hadil (10/11/2020)
Vieux 10/11/2020, 17h21   #15
hadil
Avatar de hadil
Je vais essayer ca demain ont sais jamais ,
Par contre moin j ai changé que le mastervac seul (la bombonne) pas la pompe qui a sur le mastervac
J ai l avais controle le verin qui ya dedans fonction bien...
C4 Picasso esp et frein à main électrique johnny59410 ABS, ESP, DSC 17 02/10/2020 21h29
Frein de parking C4 Picasso 2015 eCU25 ABS, ESP, DSC 6 11/03/2020 10h25
c4 picasso probleme frein parking martinn PSA Group Peugeot, Citroën 10 01/07/2019 21h27
Commande de frein défaillante, frein électrique auto active C4 Grand Picasso Walid25 ABS, ESP, DSC 5 08/10/2016 16h03
Ford transit pédale très très dure skikdi13 ABS, ESP, DSC 6 15/09/2016 20h45
Fuseau horaire GMT +1. Il est actuellement 11h42.
