Vieux 18/11/2017, 22h19   #1
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut Lexia & PP2000 update 8.50-8.55 (DiagBox v8.55)
The software provided and the procedures proposed are intended for personal, educational and experimental use to install DiagBox 8.xx related updates. I hold no responsibility for any illegal or improper usage. Carry out this procedure at your own risk.
Link is provided in the attachment for "APP_Update_850-855.exe". This is intended to update Lexia and PP2000 components of DiagBox 8.50, 8.53 or 8.54 to 8.55.
Procedure:
1- Ensure you have a backup copy of the file "C:\AWRoot\bin\fi\APPDIAG.SYS" before you start.
2- Download and execute the appropriate file for your own setup. The process will copy all necessary files to the updt folder, it will then automatically kill all DiagBox associated processes to enable overwriting without conflicts.
3- Run DiagBox to start the update process and wait until DiagBox is operational. Close DiagBox and restart your computer to ensure all processes are running.
Done..! you may run DiagBox as usual.. Notice that DiagBox version will change to 07.855 after the update..
Have fun!
Regards, Simple.
Type de fichier : txt APP_Update_850-855.txt (898 octets, 256 affichages)
Simple est déconnecté   Réponse avec citation
The Following 43 Users Say Thank You to Simple For This Useful Post:
abdel93 (19/11/2017), adiago (19/11/2017), AKDAN (14/01/2018), al1962 (19/10/2018), amine08 (13/04/2018), bej 974 (08/11/2018), bzkmatrix (14/01/2019), catley (19/10/2018), chafi (17/01/2018), colas (20/12/2017), DIAGAUTO33 (19/11/2017), dingo307 (19/11/2017), djslowrnb (20/11/2017), dounga (21/10/2018), elie (19/11/2017), Florian Doke (21/02/2018), frank-ebert (30/10/2018), franz93 (24/10/2018), gabyraptor (10/12/2025), gchx (16/08/2018), guyguy307 (18/11/2017), Ian995 (15/08/2018), indians42 (14/04/2018), k.emra (13/04/2018), kam306 (19/11/2017), lazizouille (21/01/2018), lounaisse (13/04/2018), mahfoud lichani (19/11/2017), mehdi1-1 (16/10/2018), Mer (11/08/2018), ouragh (02/11/2019), prinzo57 (18/11/2017), REDZONE31 (19/11/2017), Roturbo (27/04/2018), saidsaad (28/10/2018), saigne (14/03/2020), samii1955 (18/11/2017), tatel (08/02/2018), taxi5114 (19/05/2018), techtronic1 (19/11/2017), titic (31/10/2018), tony60 (18/11/2017), zenata (20/11/2017)
Vieux 19/11/2017, 02h21   #2
abdel93
Avatar de abdel93
salam aleycom merci
Vieux 20/11/2017, 09h43   #3
Pouvoir de réputation: 84
selem alikom chekran for the update
Vieux 20/11/2017, 11h49   #4
Simple
Avatar de Simple
ِوعليكم وعلى الجميع السلام
Enjoy.. Simple.
Vieux 13/04/2018, 08h45   #5
lounaisse
Avatar de lounaisse
lounaisse is on a distinguished road
merci thank
sonde clip interface peugeot citroen AUTEL MX 808 TS Launch CRP 429
lounaisse est déconnecté   Réponse avec citation
Vieux 15/04/2018, 00h13   #6
badgeling
Avatar de badgeling
badgeling is an unknown quantity at this point
slm alikom thxn for the update
badgeling est déconnecté   Réponse avec citation
The Following User Says Thank You to badgeling For This Useful Post:
lounaisse (16/04/2018)
Vieux 15/08/2018, 19h35   #7
Ian995
Avatar de Ian995
Ian995 is an unknown quantity at this point
Thank you Simple
Worked after a bit of messing
Some reason my v7.83 had jre and not jre7 in the c\:APP\bin
It failed to load SIM after updates 817 to 837
I deleted the jre folder and made new folder jre7 in that location
Then loaded java 7 to that location and the SIM then loaded fine
Cheers Simple keep up the good work
Ian995 est déconnecté   Réponse avec citation
The Following User Says Thank You to Ian995 For This Useful Post:
2009mohrice (30/09/2018)
Vieux 15/08/2018, 19h46   #8
Ian995
Avatar de Ian995
Should of said I loaded all fine to 8.55
No problem
Vieux 19/10/2018, 09h05   #9
catley
Avatar de catley
Pouvoir de réputation: 9
catley is on a distinguished road
merci pour cette update pack.
la mise à jour s'est bien effectuée (diagbox 7.855 affiché), par contre en analysant les fichiers, j'ai l'impression que tout n'est pas mis à jour:
dans C:\AWRoot\dtwr\updt\Appli\Extract\MajListe on retrouve les 3 updates non décompressées.
et si je regarde un fichier d'un calculateur de véhicule au hasard provenant de ces archives, je ne le retrouve pas dans mon arborescence
exemple:
C:\AWRoot\dtwr\updt\Appli\Extract\MajListe\inter8_ 55.rar
contient AWRoot\dtrd\tree\Vehicle\W2\AAS\AAS_UDS\W2_AAS_AAS _UDS_VARIANTE_CALCULATEUR.s, 38044 octets, date 12/09/2017 15:17
dans mon arborescence C:\AWRoot\dtrd\tree\Vehicle\W2\AAS\AAS_UDS\ le fichier en question date toujours du 24/06/2015 et fait 22543 octets
je me trompe peut-être... mais peux tu quand même vérifier la bonne exécution de cette update ?
catley est déconnecté   Réponse avec citation
Vieux 19/10/2018, 14h55   #10
catley
Avatar de catley
En complément:
j'ai fait une analyse avec un comparateur de fichiers (WinMerge) entre l'arborescence de diagbox 8.55 (7.855) et le dossier updt\MAJDIST contenant les 3 archives inter8_53,54,55 décompressés.
Il en ressort une grande différence de fichiers non à jour et/ou manquants.
Est-ce normal ?
Est-ce que @Simple pourrait corriger ?
Type de fichier : zip compare 8.55(7.855) - update rar 8.53,54,55.csv.zip (562,4 Ko, 14 affichages)
Vieux 22/10/2018, 09h13   #11
catley
Avatar de catley
En 2ème complément:
J'ai discuté avec @Simple à propos de ces update pack: En fait il ne s'occupe que de mettre à jour la partie PP2000/Lexia.
Il ne s'occupe pas de la partie Diagbox car il n'en a pas l'utilité (son véhicule personnel n'est que sous PP2000/Lexia).
Donc lorsque l'on exécute ses packs, bien que la version de Diagbox soit incrémentée, cela ne met pas à jour les fichiers que Diagbox utilise.
Donc peut-être que @MaitreSox ou une autre personne compétente pourrait se pencher sur ces mises à jour pour Diagbox... ?
Vieux 22/10/2018, 10h22   #12
adiago
Avatar de adiago
Pouvoir de réputation: 35
MaitreSox ne fait plus les mises à jour depuis un moment pour cause revente de ses updates .
adiago est connecté maintenant   Réponse avec citation
maitresox (22/10/2018)
Vieux 22/10/2018, 10h27   #13
catley
Avatar de catley
OK.
J'ai discuté également avec Maitresox et je comprend son point de vue.
Vieux 22/10/2018, 10h43   #14
yann3
Avatar de yann3
Pouvoir de réputation: 76
il a bossé pour se faire piquer sont boulot,rorry n´a pas fait la meme erreur
The Following 3 Users Say Thank You to yann3 For This Useful Post:
adiago (22/10/2018), guyguy307 (22/10/2018), maitresox (22/10/2018)
Vieux 28/10/2018, 19h47   #15
saidsaad
Avatar de saidsaad
saidsaad is an unknown quantity at this point
Envoyé par Simple Voir le message
Procedure:
Have fun!
Regards, Simple.
merci de m'envoyer le lien
saidsaad est déconnecté   Réponse avec citation
Lexia & PP2000 (from DiagBox 8.35) Simple LEXIA, PP2000, DiagBox 63 25/11/2018 22h25
Diagbox pp2000 lexia YomGui PSA Group Peugeot, Citroën 35 16/06/2017 13h12
Lexia and PP2000 update without internet scarymistake LEXIA, PP2000, DiagBox 0 14/01/2012 10h20
Fuseau horaire GMT +1. Il est actuellement 05h50.
