Vieux 04/10/2017, 11h56   #1
julien34560
Avatar de julien34560
julien34560 will become famous soon enoughjulien34560 will become famous soon enough
Par défaut codage polo 6R ESP 8.2
salut à tous
quelqu'un peut il me donner le codage esp pour
WVWZZZ6RZAY116476 polo 1,6 TDI
j'avais le soft mais perdu suite à un plantage pc
merci d'avance
julien34560 est déconnecté   Réponse avec citation
Vieux 04/10/2017, 12h46   #2
Pouvoir de réputation: 175
bonjour julien34560
VW POLO 6Q0 907 379 AC ABS Pump
VW Polo 9N
Address 03: ABS Brakes
Controller: 6Q0 907 379 AC
Component: ABS 8.0 front H03 0002
Coding: 0000145
ALTERNATIVE ABS MODULE CODING
NB! These are the codings I currently have but are certainly not the only ones use by Volkswagen, SEAT, Skoda and Audi. As I get them I will update this list.
6Q0 907 379 - Coding: 00036 or 00044
6Q0 907 379 AA - Coding: 0000005 or 0000008
6Q0 907 379 AB - Coding: 0000005 or 0000008
6Q0 907 379 AC - Coding: 0000145 or 0000142
6Q0 907 379 AF - Coding: 0002061 or 0002079 or 0002082 or 0002085 or 0002103 or 0002115 or 0002118 or 0002122 or 0002136 or 0002145 or 0002175 or 0002181 or 0002190 or 0002193 or 0002199 or 0002202
As can be seen above, AF suffix has the whole gamut of codings and each should be tried before throwing in the towel.
6Q0 907 379 AG - Coding: 0002202 or 0002229 or 0002238
6Q0 907 379 AH - Coding: 0000299 or 0000284
6Q0 907 379 AQ - Coding: 0002356
6Q0 907 379 AS - Coding: 0002347 or 0002368 or 0002368 or 0002491
6Q0 907 379 AT - Coding: 0000269
6Q0 907 379 BC - Coding: 0002136 or 0002098
6Q0 907 379 C - Coding: 00044
6Q0 907 379 D - Coding: 00124 or 00188
6Q0 907 379 E - Coding: 0001097
6Q0 907 379 G - Coding: 00044 or 00045
6Q0 907 379 H - Coding: 00188
6Q0 907 379 L - Coding: 0001097
6Q0 907 379 M - Coding: 0000000
6Q0 907 379 R - Coding: 0000008
6Q0 907 379 T - Coding: 0000281 or 0000296 or 0000299
---------- Post added at 10h46 ---------- Previous post was at 10h41 ----------
re
Volkswagen:- (VW) Polo (6N/6N2 chassis) 1994 - 2002 and newer
Volkswagen:- (VW) Polo (9N chassis) 2002 -2010
ABS
Adaptation access MK60 = 00212
Adaptation access NDBW = 01025
Adaptation access DBW = 04097
Adaptation access SPECIAL A6 = 09399
Adaptation access FWD = 13204
Adaptation access AWD = 13504
Adaptation access AWD ESP = 18446
Adaptation access MK60 = 19469
Adaptation access FWD ESP = 23049
Adaptation access General = 27861
Adaptation access to basic settings = 40168
The Following 4 Users Say Thank You to zenata For This Useful Post:
Auto16 (14/11/2023), julien34560 (06/01/2018), prodiag2017 (23/01/2018), youcef_trik (05/03/2018)
Vieux 06/01/2018, 17h04   #3
julien34560
ce codage ne me sers pas il faut 36 caractères par vcds, après
j'ai acheter le VAG CAN PRO pour le faire automatiquement mais il me met erreur 00
Vieux 06/01/2018, 17h38   #4
bonjour julien34560
ABS-ESP-CALCULATOR .rar
259 Ko
https://mega.nz/#!bk1CQLDC!5N2sBoThh...RMcr628TsSb0o0
The Following 8 Users Say Thank You to zenata For This Useful Post:
julien34560 (16/01/2018), KEVINOX46 (21/11/2018), martinn (22/11/2018), morran (01/08/2019), nasisamy (05/04/2021), prodiag2017 (23/01/2018), progdebutant (13/08/2019), youcef_trik (05/03/2018)
Vieux 17/01/2018, 21h46   #5
julien34560
Merci mais il y’a un id a faire avec un pass
Mais ça ne me dis pas pourquoi au vag can pro en mode automatique pourquoi ça me met error 00
Vieux 19/01/2018, 19h15   #6
julien34560
J’ai rentré une autre polo. Il n’y avait pas de problème d’abs. J’ai tenté un codage auto avec vag can pro pareil. Il me met error 00
The Following User Says Thank You to julien34560 For This Useful Post:
Vieux 28/01/2018, 09h06   #7
raid91
Avatar de raid91
raid91 is an unknown quantity at this point
210224c2006e00b8842924e900d700420000
raid91 est déconnecté   Réponse avec citation
Vieux 02/03/2018, 18h30   #8
julien34560
merci je vais tester
Vieux 04/03/2018, 17h21   #9
julien34560
quand je le fais ça me met erreur 55 codage rejeté
Vieux 05/03/2018, 10h33   #10
youcef_trik
Avatar de youcef_trik
youcef_trik has a spectacular aura aboutyoucef_trik has a spectacular aura aboutyoucef_trik has a spectacular aura about
bonjour julien34560
259 Ko
merci zenata pour ton aide stp j'aimerais activer le calculateur abs esp
youcef_trik est déconnecté   Réponse avec citation
Vieux 05/03/2018, 10h58   #11
fayssal2017
Avatar de fayssal2017
Pouvoir de réputation: 40
Envoyé par julien34560 Voir le message
Essaye d'introduire le code d'accès 40168, ensuite refait le codage
The Following 2 Users Say Thank You to fayssal2017 For This Useful Post:
momo59490 (22/11/2019), zenata (05/03/2018)
Vieux 05/03/2018, 11h06   #12
bonjour youcef_trik
Type de fichier : rar Abs esp code version plug and play.rar (258,2 Ko, 213 affichages)
The Following 13 Users Say Thank You to zenata For This Useful Post:
Auto16 (14/11/2023), bej 974 (12/05/2020), fayssal2017 (05/03/2018), hams (27/01/2020), ishams2002 (25/12/2019), losconosciuto (22/11/2019), martinn (22/11/2018), momo59490 (22/11/2019), progdebutant (13/08/2019), REDZONE31 (17/10/2019), salim-diad13 (27/09/2019), youcef_trik (05/03/2018)
Vieux 05/03/2018, 11h10   #13
tiens un autre
Type de fichier : rar ABS ESP code calculateur pour le groupe VAG.rar (258,2 Ko, 192 affichages)
The Following 11 Users Say Thank You to zenata For This Useful Post:
CHEAPSHOP (27/11/2019), fayssal2017 (05/03/2018), hams (27/01/2020), ishams2002 (25/12/2019), juju94 (28/11/2019), losconosciuto (22/11/2019), martinn (22/11/2018), momo59490 (22/11/2019), progdebutant (13/08/2019), youcef_trik (05/03/2018), zack007 (09/07/2026)
Vieux 05/03/2018, 11h12   #14
encore un autre
Type de fichier : rar ABS-ESP-CALCULATOR.rar (259,3 Ko, 131 affichages)
The Following 10 Users Say Thank You to zenata For This Useful Post:
Abdssamed1992 (29/12/2018), fayssal2017 (05/03/2018), hams (27/01/2020), juju94 (28/11/2019), kev29200 (22/04/2025), losconosciuto (22/11/2019), momo59490 (22/11/2019), progdebutant (13/08/2019), youcef_trik (05/03/2018), zack007 (09/07/2026)
Vieux 05/03/2018, 11h14   #15
et encore un autre
pas oublier thanks !!!
Type de fichier : rar VAG_ESPcalculator_setup.rar (507,1 Ko, 183 affichages)
The Following 16 Users Say Thank You to zenata For This Useful Post:
Abdssamed1992 (29/12/2018), digimotion (15/09/2023), djamel30 (21/05/2022), fayssal2017 (05/03/2018), hams (27/01/2020), juju94 (28/11/2019), kev29200 (22/04/2025), KEVINOX46 (21/11/2018), KIKI92 (24/11/2020), losconosciuto (22/11/2019), momo59490 (22/11/2019), progdebutant (13/08/2019), saysso (17/11/2019), youcef_trik (05/03/2018), zack007 (09/07/2026)
codage ecu calixo22 Airbag 2 14/07/2017 14h34
Codage abs Jean23 ABS, ESP, DSC 2 05/07/2017 14h42
codage abs,esp,asr christ ABS, ESP, DSC 0 06/12/2015 09h27
codage injecteur polo 1.6 tdi nas33 VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 5 30/11/2015 07h49
Codage ABS Polo 2011 newfree VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 10 11/02/2015 18h57
Fuseau horaire GMT +1. Il est actuellement 19h36.
