Précédent   Tlemcen Car electronics > Categorie principale > Café du forum > Section for english users
Section for english users English talking about cars, problems and solutions ...
Vieux 14/04/2016, 14h51   #1
costinet
Avatar de costinet
costinet is an unknown quantity at this point
Par défaut clone DDCR
Hello everyone. I have a question about ecu compatibility between a ecu ddcr mounted in a renault megane 2 1.5 dci euro3 and a ecu ddcr mounted in a renault clio 1.5 dci euro3. It's possible to be replaced, after rewrite the software? I have original ECU from megane II with this serial nr.:8200334419 , 8200340926 , DDCR R0410B024A , SERIAL No80975965 JWG and the ecu from clio have this serials : 8200334540 , 8200412768, DDCR R041B026C , SERIAL No 82436926 JXG
Thank you.
costinet est déconnecté   Réponse avec citation
Vieux 14/04/2016, 16h25   #2
nas33
Avatar de nas33
salu ecu clio ddcr et megane ddcr ne sont pas compatible .ecu ddcr megane eeprom atmel 95080 et l autre clio 95080
Vieux 20/04/2016, 20h48   #3
costinet
Avatar de costinet
k .merci beaucoup.
another question : i found another ecu with same HW serial like original.it's possible to clone the ecu only on obd connector, or must cut the plastic case for desoldering and read eeprom to clone IMMO? i have fgtech galleto v45 china clone, mpps v16 and fg galletto 1260. the new ecu have same proprieties like old ecu, same power 82hp, but i make a chiptunning on mine ecu.
Vieux 21/04/2016, 14h56   #4
nas33
Avatar de nas33
non il faut dessouder eeprpm et la ressouder
Vieux 21/04/2016, 22h07   #5
costinet
Avatar de costinet
thank you...best regards
Vieux 09/05/2016, 22h03   #6
machin76
Guest
Avatar de machin76
Messages: n/a
Envoyé par nas33 Voir le message
je confirme
Vieux 06/06/2016, 09h00   #7
costinet
Avatar de costinet
hello guys. i come back with another question and request to help: can anyone to tell me how virginize this ecu? i read some forum , and i see this tips:
Can be done ONLY virgin Delphy DDCR ecu.
On the 95080 flash, : >
Put line 0000 : all 16 bytes to FF AND
line 0001 : first 9 bytes to FF,
and this is virgin. Use emu or recode ecu by original uch and keys as you wish
100 % guaranteed solution, virginised those ecus many, many times !
so....any advise?!
Vieux 06/06/2016, 16h44   #8
adel2789
Avatar de adel2789
adel2789 is a jewel in the roughadel2789 is a jewel in the roughadel2789 is a jewel in the roughadel2789 is a jewel in the rough
post the original dump i will do it
best regards
adel2789 est déconnecté   Réponse avec citation
Vieux 22/06/2017, 20h04   #9
conan981
Avatar de conan981
conan981 is an unknown quantity at this point
it is right, only virgin. but you can use immo emulator like julie or similar if you need immo off after virginizing
conan981 est déconnecté   Réponse avec citation
Vieux 22/06/2017, 20h27   #10
Slt si c'est le même tu fais un vierge tu remet vin code injecteurs..
sharediag (04/01/2019)
Vieux 04/01/2019, 23h49   #11
sharediag
Avatar de sharediag
sharediag will become famous soon enough
bonsoir,
apres plusieurs dessoudage je viens de bousiller la st95080 de DDCR megane 2 1.5 dci de 2003 REF: 8200334419 , 8200340926 , R0410B024A
si qlq1 peut me filer le dump orig
merci d avance.
sharediag est déconnecté   Réponse avec citation
Vieux 04/01/2019, 23h52   #12
sharediag
Avatar de sharediag
ou si qlq1 peut me confirmer si ce dump n est pas corrompu.
Type de fichier : bin 95080-megane2.bin (1,0 Ko, 20 affichages)
Vieux 06/01/2019, 15h34   #13
sharediag
Avatar de sharediag
ou un dump fonctionnel pour le calculateur en référence.
merci pour votre aide.
Vieux 10/01/2019, 19h43   #14
ducla
Avatar de ducla
ducla is just really niceducla is just really niceducla is just really niceducla is just really nice
Bonsoir.Comme déjà dit il suffit de virginiser l'eprom (off partout)et ça doit démarrer.Il ne reste plus qu'à remettre le vin et les codes injecteurs pour ne pas avoir de remontée de défauts.
ducla est déconnecté   Réponse avec citation
Vieux 11/01/2019, 00h07   #15
kaki02
Avatar de kaki02
kaki02 is a splendid one to beholdkaki02 is a splendid one to beholdkaki02 is a splendid one to beholdkaki02 is a splendid one to beholdkaki02 is a splendid one to beholdkaki02 is a splendid one to beholdkaki02 is a splendid one to behold
Ton eeprom soit tu mets tout en fffffffffff eeprom totalement vierge et tu le ressoudes dans ce cas la voiture demarre voyant prechauffage alumé regime moteur 1100rpm et pas d'acceleration tu dois rentrer les code injecteurs.
Deusieme cas virginiser seulement les deux premieres lignes en fffffff tu ressoudes eeprom demarrage directe sans prechauffage
Voila c à vous de choisir ce que tu veux faire
kaki02 est déconnecté   Réponse avec citation
Ddcr 1,5 dci costinet Renault, Dacia, Nissan 6 26/03/2016 16h22
DDCR 1.5 renault can Ecomouv Immobilizer dumps/solutions 3 19/01/2015 13h59
bdm delphi ddcr zaouibachir Programmateur de composant (flasher) 3 16/06/2013 02h27
Fuseau horaire GMT +1. Il est actuellement 17h11.
