#16 | |
***************** * LIST OF PARTS * ***************** codes for: http://uk.farnell.com http://www.rs-components.com/index.html items also available: http://www.tme.eu ======================== | Solutions for KessV2 | ======================== Transistors ----------- 5x BCR112 (WF) or PDTC143ET (tO2, p02); SOT-23 (NPN 2x4k7) my: WFs farnell: 2319267, rscomponents: 287-667 pcb: Q2, Q6, Q10, Q13, Q14 4x MMUN2113 (A6C) or PDTA144ET (t07, p07); SOT-23 (PNP 2x47k) my: W07 farnell: 8736987, rscomponents: 690-0133 pcb: Q7, Q11, Q12, Q16 3x BC817 (6DW, 6Dp, 6Dt, 6Cp, 6C, 6CW); SOT-23 (NPN) my: 6CR BC717-16 (6A), -25 (6B), -40 (6C) {hFE} farnell: 1081223, rscomponents: 216-9410 pcb: Q4, Q9 2x BC807 (5B, 5BW, 5Bp, 5Bt); SOT-23 (PNP) my: 5B farnell: 1081222, rscomponents: 216-9404 pcb: Q3, Q15 Bi-Directional Dual Line CAN Bus Protector ------------------------------------------ 3x NUP2105LT1G (27E) or PESD2CAN (6R); SOT-23 my: 27E farnell: 1510712, rscomponents: 464-255 pcb: DZ3, DZ4, DZ5 Filters ------- 6x NFE61PT472C1H9L Murata (all connect to ground) farnell: 9528229, rscomponents: 188-8772 pcb: L1 - L6 Capacitors ---------- 3x 1uF/35V size B, farnell: 1457432, rscomponents: 538-2357 pcb: C27, C29 2x 220uF/10V size X, farnell: 1457539, rscomponents: 538-2717 pcb: C34, C37 8x 10uF/16V size B, farnell: 1457436, rscomponents: 801-5445 pcb: C31, C25?(above C23), C40, C46, C61, C64, C82, C98 Resonators ---------- CSTCE8M00G55A-R0 (muRata) farnell: 2443269, rscomponents: 721-4830 pcb: Y2 Speaker piezzo (not necessary) ------------------------------- PKM17EPP (muRata) farnell: 2443200, rscomponents: 516-8246 pcb: SP1 |
#17 |
cool pas mal en plus il y a même les reference
![]() ![]() donc aucun intérêt de rajouté le puce? |
#18 |
![]() Date d'inscription: mai 2016
SALUT betrescudan
tu aurais un tuto photos?? merci |
#19 |
bon j'ai tous commandé je ferais un petit tuto pendant le remplacement.
a oui attention il y a une grande différence de prix entre farnell et les autres moi j'ai commandé pour 35€ avec certain composant vendu en lot de 5 ou 10. |
#20 |
salut lol lol c un composant que tu peut trouver sur tout les appareille qui fait( bip bip bip bip) c un buzzeur pour l autre j arive pas a lire sa referance bon courage @@@
#21 |
bonjour bon j'ai reçu tous les composants j'ai déjà remplacé pas mal de chose.
petite question le ResonatorsCSTCE8M00G55A-R0 (muRata) qui est sur le pcb: Y2 a t’il un sens pour le soudé? aussi sur le pcb en RF il y a un fil ou vas t-il? sur la carcasse du boitier? merci |
#22 |
j'ai commander les composants et j'attend patiament ton tuto :) y a t'il un moyen de le mettre full (tracteur et pl) merci |
#23 |
pour le tuto des que je fini et un peu de temps il seras fait.
comment tu c'est que le tient ne fais pas tracteur et pl? |
#24 |
tout est grisé sur les pl et tracteur
#25 |
bizard moi non je peut rentré dedans
#26 |
des news de tes modifs ??? et du ptit tuto ?? :) |
#27 |
salut oui j'ai remplacé pas mal de chose il me reste en gros dix composant a faire mais le temps me manque.
je ferais un petit tuto ne tkt pas |
| Outils de la discussion | |
| Besoin d'aide pour identifier un composant (boitier bmw gestion hauteur suspension) | doud77 | Electronique | 23 | 01/06/2016 22h27 |
| Quel est la référence de ce composant? Besoin d'aide! | Ben29200 | Café du forum | 14 | 04/02/2016 22h41 |
| Fichier aide Kess V2.13 | jpanasonic | Pinout calculateurs et bootmode | 0 | 16/06/2015 12h15 |
| fichier d'aide Kess V2 & Ktag en V2.10 | jpanasonic | Pinout calculateurs et bootmode | 1 | 18/04/2015 03h39 |
| aide identification composant | sony55 | Electronique | 4 | 08/01/2013 16h27 |
