Discussion fermée
Vieux 10/04/2009, 22h12   #1
ROG3R
Avatar de ROG3R
ROG3R is an unknown quantity at this point
Par défaut Lucas dcn2 citroen berlingo 1.9d
hi
citroen berlingo 1.9d year 2006 LUCAS DCN2
my problem is this car have accident,and ecu broke.
and buy one used,and bsi and keys.but car not work,
put the machine does not diagnose, says connection corrupted.
I do not know what may be, the unit will be blocked?
ROG3R est déconnecté
Vieux 10/04/2009, 22h29   #2
Hafid_elec
Avatar de Hafid_elec
Hafid_elec is an unknown quantity at this point
Check the wires, maybe a wire is cutted,
is the BSI, Key, ECU is same with the old one ?
Hafid_elec est déconnecté
The Following User Says Thank You to Hafid_elec For This Useful Post:
ROG3R (14/04/2009)
Vieux 10/04/2009, 22h31   #3
ROG3R
Avatar de ROG3R
hi
yes i check the wires.
and nothing.
Vieux 10/04/2009, 22h34   #4
Hafid_elec
i think problem is in your Bsi or Ecu :)
99% if wire connexion is ok ;)
ROG3R (14/04/2009)
Vieux 10/04/2009, 23h26   #5
ROG3R
Avatar de ROG3R
how resolv this problem?
Vieux 12/04/2009, 16h43   #6
spookie
Avatar de spookie
spookie is an unknown quantity at this point
But you forgot to change the solenoid on the pump encoded.
It is a shielded solenoid valve,
you have 2 solutions :
-put a simple SOLENOID
and connected to a + contact after.
-recover the solenoid of the car where your taking the bsi and ecu
the best solution is to put a simple SOLENOID uncoded.
spookie est déconnecté
The Following User Says Thank You to spookie For This Useful Post:
ROG3R (14/04/2009)
Vieux 12/04/2009, 18h26   #7
ricards99
Avatar de ricards99
if all other systems works normaly then it's the best solution
ricards99 est déconnecté
The Following User Says Thank You to ricards99 For This Useful Post:
ROG3R (14/04/2009)
Vieux 14/04/2009, 16h18   #8
ROG3R
Avatar de ROG3R
hi
if put immo off
does not solve the problem?
Vieux 14/04/2009, 21h25   #9
ricards99
Avatar de ricards99
if the solenoid is bad then the problem is not resolved,
ROG3R (14/04/2009)
Vieux 14/04/2009, 21h30   #10
ROG3R
Avatar de ROG3R
I try to make the diagnosis with ECU injection and does not notice,says connection corrupted.
the problem is solenoid?
connection corrupted is solenoid?
Vieux 14/04/2009, 21h44   #11
ricards99
Avatar de ricards99
no, had you verify the engine wires
ROG3R (14/04/2009)
Vieux 14/04/2009, 22h01   #12
ROG3R
Avatar de ROG3R
hi
i see wires and is good
today see not work lights average, and the engine of glass
Vieux 14/04/2009, 22h19   #13
ricards99
Avatar de ricards99
just an idea: disconnect the ABS and try to scan ecu
ROG3R (14/04/2009)
Vieux 14/04/2009, 22h21   #14
ROG3R
Avatar de ROG3R
ok
tomorrow i try
thank you
Vieux 20/04/2009, 22h37   #15
ROG3R
Avatar de ROG3R
hi
thank you all for help
now i see problem is wires broke.
now is possible immo of in this ecu
i read memorie 25080
Type de fichier : rar 25080.rar (296 octets, 39 affichages)
Discussion fermée
Citroen C4 comment mettre l'immo off didi_du_93000 Immobilizer dumps/solutions 10 15/03/2009 02h05
citroen jumper pecirepi Immobilizer dumps/solutions 2 20/02/2009 07h21
Fuseau horaire GMT +1. Il est actuellement 15h04.
