Vieux 28/04/2016, 20h46   #1
Verdun
Avatar de Verdun
Verdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud of
Par défaut Xprog 5.55 sans dongle
Bonsoir a tous je partage le soft xprog 5.55 que vous pouvez utiliser sans dongle je l ai tester il marche s en souci mp en privée et uniquement pour les habituer TE
Type de fichier : txt lien.txt (85 octets, 491 affichages)
Dernière modification par nowen ; 28/04/2016 à 21h32.
Verdun est déconnecté   Réponse avec citation
The Following 24 Users Say Thank You to Verdun For This Useful Post:
abdou_hail (17/10/2018), akai77 (20/02/2018), akasa67 (02/07/2019), allpatchi (19/09/2020), arnaud_dejard (03/05/2016), bouzimeca (03/11/2017), diago2001 (22/12/2019), drissdiag (18/06/2019), estwood68 (30/04/2018), garageramey (18/11/2020), ggvaniou (18/10/2019), haythoumazz (09/01/2019), IMOU01 (08/02/2021), jardini (01/12/2020), Kicecool (05/11/2017), Mrpromega (17/08/2017), poze (31/10/2020), progdebutant (07/06/2016), RBX59100 (08/02/2019), ricou 81 (04/03/2019), speedy_bou (08/10/2017), tico (15/08/2019), tony montana (19/01/2019)
Vieux 01/05/2016, 14h35   #2
hatem006
Avatar de hatem006
Pouvoir de réputation: 23
hatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud of
merci pour le partage il c'es installer du premier coup merci
hatem006 est déconnecté   Réponse avec citation
Vieux 01/05/2016, 14h49   #3
Verdun
Avatar de Verdun
Sa pu régler ton souci ?
Envoyé de mon GT-I9195I en utilisant Tapatalk
Vieux 01/05/2016, 22h25   #4
hatem006
Avatar de hatem006
bonsoir j'etais sur windows xp et j'ai changer windows 7 professionnel et avec la5.55 sans dangle que j'ai installer grace a toi toute est ok merci
Vieux 01/05/2016, 22h39   #5
hatem006
Avatar de hatem006
bonsoir tous le monde alors mon probleme d'installation est resolu et grace avous on avance doucement
alors j'ai extrait le dump dash xsara picasso annee 2000 2.0 hdi 90 eprom st93c66 mais j'ai un doute sur le dump qu'il soit corrumpu parce sur liczink il me dis erreur
si quelqu'un peut me dire sur le dump ca serait gentill
Type de fichier : bin dump dash ST93c66 6.bin (512 octets, 21 affichages)
Vieux 02/05/2016, 12h10   #6
mexicain
Avatar de mexicain
mexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to beholdmexicain is a splendid one to behold
salut hatem tu peut nous s'il te plait c'est quoi comme xprog que tu as ?
si c'est un 5.51 ou autre ou 5.55.
si ta flasher le ATMEGA64 ou autre procedure.plus de detail quoi.
mexicain est déconnecté   Réponse avec citation
Vieux 02/05/2016, 12h31   #7
hatem006
Avatar de hatem006
Slaut mexicain j'ai achete xprog 5.55 avec dongle mais jai telecharger le 5.55 sans dongle que notre amis Verdun a partager tout simplement jai pas flasher quoi que ce soit voila,je suis sur windows 7 pro 32 bits
Vieux 02/05/2016, 13h08   #8
mexicain
Avatar de mexicain
et sur xp sa fonctionne ou pas?
Vieux 02/05/2016, 13h47   #9
hatem006
Avatar de hatem006
non pour moi il na pas fonctionner sur xp sp2 32bits mais sur windows 7 pas de probleme il me reste juste mnt a verifier i ma lecture de dump es bonne
The Following User Says Thank You to hatem006 For This Useful Post:
mexicain (02/05/2016)
Vieux 02/05/2016, 13h56   #10
diago2001
Avatar de diago2001
salut mon amis alors sa marche sans toucher le ATMEGA64?
Un bon travail n'a pas de prix.
Vieux 02/05/2016, 14h00   #11
hatem006
Avatar de hatem006
pour moi mon doitier xprog elle es deja a 5.55 avec dongle alors jai telecharger le lein de verdu de xprog 5.55 sans dongle alors jai pas besoin de flasher ATMEGA64
Vieux 07/06/2016, 20h26   #12
pouettedu76
Avatar de pouettedu76
Pouvoir de réputation: 77
Bonsoir je suis a la recherche du soft xprog 5.55 sans dongle Verdun si tu peut remettre le soft sur mega sa serait top merci et y'a t'il un petit tuto pour l'instalation ? Merci
Le liens mega me met une erreur lors du telechargement merci de ta comprehension et bonne soirée @ tous cordialement @+
Vieux 07/06/2016, 20h54   #13
Verdun
Avatar de Verdun
Je viens de tester mon liens et bon l ami le souci viens de chez toi
The Following User Says Thank You to Verdun For This Useful Post:
pouettedu76 (07/06/2016)
Vieux 07/06/2016, 20h57   #14
pouettedu76
Bonsoir Verdun je vais tester avec un autre pc merci je reviens aux nouvelles :)
Vieux 07/06/2016, 21h10   #15
pouettedu76
Donc je ne sais pas si j'ai la mal chance met meme sur mon autre pc c'est la meme :
Erreur temporaire , nouvelle tentaive en cours pourtant pour telecharger d'autres fichier sur mega sa fonctionne aiie aiie pas de chance pour moi donc je laisse tomber pour se soir et je vais ressayer demain bonne soirée et merci comme meme Verdun @+
Xprog 5.55 dongle hatem006 Programmateur de composant (flasher) 18 22/07/2016 21h15
Galletto 2 et 3 V53 sans dongle rickymix Programmateur de composant (flasher) 14 17/03/2014 16h29
XPROG-M Programmer V5.1 with the dongle VAMPERNIGHT Programmateur de composant (flasher) 3 05/08/2012 21h24
Fuseau horaire GMT +1. Il est actuellement 23h28.
