Vieux 28/02/2015, 01h14   #1
hichan
Avatar de hichan
hichan will become famous soon enoughhichan will become famous soon enough
Par défaut Tutoreil réparation compteur renault espace 4 ou scenic
la solution pour le problème du compteur Espace 4 et scenic 2, il s'agit d'un problème sur un transistor mosfet et un fusible
pour la réparation regarder la vidéo
un petit merci ne coûte rien , mais que cela fait plaisir ...
voici le lien
http://www.youtube.com/watch?v=UUcnZQbhVvc
hichan est déconnecté   Réponse avec citation
The Following 33 Users Say Thank You to hichan For This Useful Post:
Alissa1970 (25/04/2015), aminexl (05/03/2015), atlon2 (05/03/2015), autodiagauto (05/03/2015), badpilot (03/03/2015), benorama (12/03/2015), billka (02/03/2015), cracker563 (03/07/2020), darty (04/03/2015), DIAGNOSTIC AUTO (05/03/2015), dounga (03/08/2019), ECU diag (05/03/2015), evoevo (09/03/2015), funzy74 (06/03/2015), hicham40 (06/05/2015), jah83 (06/03/2015), jeanalitre (13/04/2019), Jeancat (23/10/2023), karumbo (13/03/2015), kent to kill (15/03/2015), MecaTech (07/03/2015), mindouza (18/01/2021), mustaphcl (23/08/2015), nyonsais (06/03/2015), rrguillaume (19/03/2015), samb4064 (28/02/2015), seko (10/07/2016), thomas (12/06/2020), Tony-Stark (01/02/2021), transitforum (23/03/2015), walter92 (22/10/2019), Yoann29 (13/01/2021), zav_ze_best (08/11/2020)
Vieux 04/03/2015, 22h05   #2
darty
Avatar de darty
darty will become famous soon enough
Tres bonne video,, tres bon taf,,
darty est déconnecté   Réponse avec citation
Vieux 11/07/2015, 09h14   #3
MrRorry
Avatar de MrRorry
MrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond repute
Attention, a noter quand meme que changer le mosfet seul ne suffit pas, il chauffe mais ne doit pas surchauffer meme si le fabricant indique dans le datasheet qu'il peut aller jusqu'a 175° en fonctionnement normal si mes souvenirs sont bons donc bien prendre le temps de reviser les soudures avec une station a air chaud (ne pas mettre a fond sinon tout les composants s'envolent! lol)
- Ne jamais deporter le mosfet sur un circuit de fortune comme ca a pu etre vu.
- Pas besoin de mettre des ventilos de 2000watts partout ou d'en faire une passoire
car un circuit electronique qui surchauffe est un circuit defaillant donc non reparé.
Bon courage a tous ceux qui se lancent dans cette reparation.
MrRorry est déconnecté   Réponse avec citation
Vieux 11/07/2015, 15h00   #4
ecutech
Avatar de ecutech
Aussi j'ajouterai simplement la solution du mofset et du fusible cest du bricolage il faut aussi controler lalim les resitances le contrôleur pwm ....
Je vois de ces compteur réparer par de soit disant gros boite avec 1 siècle d'expérience mon cul.... oui
Juste le mosfet de changer l'écran dessouder et replier nimporte quoi.....
Le top c'est le truc garantie a vie...
Enfin pour bien faire il faut travailler avec du flux de soudure et pas faire de grosse boulette de soudure ca sert a rien..
Reprendre zone par zone les soudure juste en appliquant du flux et combler les soudure pauvre en etain.
Ensuite toujours remplacer le controler pwm de l'alimentation et les condo tentale ou simplement les tester... allez j'en ai trop dit :))))
Envoyé de mon GT-I9505 en utilisant Tapatalk
The Following 2 Users Say Thank You to ecutech For This Useful Post:
jeanalitre (13/04/2019), pp08 (13/06/2020)
Vieux 11/07/2015, 18h11   #5
MrRorry
Avatar de MrRorry
Envoyé par rojhat Voir le message
Mdr. >Je vois de ces compteur réparer par de soit disant gros boite avec 1 siècle d'expérience mon cul....
Tout a fait d'accord avec toi.
Vieux 17/07/2015, 16h15   #6
jbea2
Avatar de jbea2
jbea2 is an unknown quantity at this point
super tutorial de réparation !
jbea2 est déconnecté   Réponse avec citation
Vieux 27/08/2015, 08h12   #7
skrountch
Avatar de skrountch
skrountch is an unknown quantity at this point
excellent travail qui démontre que l on ne peut pas faire du bon taff sans le matériel approprié.
skrountch est déconnecté   Réponse avec citation
Vieux 11/10/2015, 21h22   #8
yoyomartin2003
Avatar de yoyomartin2003
Bonjour pour completer la video le lien pour le logiciel modif km apres reparation
http://www.tlemcen-electronic.com/fo...ead.php?t=5249
Tout est sur Tlemcen.
The Following 2 Users Say Thank You to yoyomartin2003 For This Useful Post:
ibg2568 (07/12/2020), walter92 (22/10/2019)
Vieux 28/10/2015, 14h47   #9
forge94
Avatar de forge94
forge94 is an unknown quantity at this point
très bon tuto et qui peux servir, merci.
forge94 est déconnecté   Réponse avec citation
Vieux 09/06/2020, 19h49   #10
Damien1383
Avatar de Damien1383
Damien1383 is an unknown quantity at this point
Je suis propriétaire d'un Scenic 2 et mon compteur ne fonctionne plus.
Je souhaiterai le réparer et j'ai effectué beaucoup de recherche sur le net pour cela mais je n'arrive pas à trouver les ref des différents composants à changer pour pouvoir les acheter sur RS par exemple.
Est ce que vous pouvez m'aider ?
-> mosfet :IRF3710S
-> fusible :
-> le controler pwm
-> les condo
-> eeprom : 93C56
Damien
Damien1383 est déconnecté   Réponse avec citation
Vieux 12/06/2020, 18h30   #11
Damien1383
Oui j'ai vu, mais parfois j'ai des surprises lorsque j’achète des composants sur ebay.
Effectivement, si je n'y arrive pas je le confierais à un "professionnel".
merci pour la réponse
Damien
Vieux 12/06/2020, 19h09   #12
thomas
Avatar de thomas
il utilise quoi comme soft pour décoder l'eprom ?
Vieux 12/06/2020, 19h39   #13
Damien1383
il y a Dashboard Scénic
mais je ne l'ai pas encore utilisé
The Following User Says Thank You to Damien1383 For This Useful Post:
thomas (13/06/2020)
Vieux 12/06/2020, 21h37   #14
gary01
Avatar de gary01
Pouvoir de réputation: 104
Envoyé par thomas Voir le message
Si ca t’interesse thomas j’ai un soft que je peux t’envoyer en mp
Envoyé de mon iPad en utilisant Tapatalk
thomas (13/06/2020)
Vieux 13/06/2020, 11h13   #15
thomas
Avatar de thomas
salut c'est toujours interressant d'apprendre.
si tu as un dump de compteur avec, cela serait parfait, pour que je vois comment ça marche (c'est ce qui m'interresse).
reparation compteur scenic 2 a l aide laid75 Tableau de bord (Dashboard) 22 21/11/2014 22h50
Compteur espace 4 Sagem identique au scenic kazouille Tableau de bord (Dashboard) 3 13/09/2014 18h13
reparation compteur espace 4 IV Al hoceima Tableau de bord (Dashboard) 10 24/06/2014 22h26
Quel outil pour compteur scenic 2, Espace 4 Mathieu35500 Tableau de bord (Dashboard) 5 20/12/2013 18h27
Réparation compteur espace 4 julien74 Tableau de bord (Dashboard) 12 14/06/2013 23h17
Fuseau horaire GMT +1. Il est actuellement 23h33.
