Vieux 21/08/2015, 01h31   #1
manueldord
Avatar de manueldord
manueldord is an unknown quantity at this point
Par défaut renault laguna 2 1.9 dci 2002 fixed light immo
Hello fellow someone can lend me a hand on this topic
Immo in light fixed dash and not start
thanks and regards
manueldord est déconnecté   Réponse avec citation
Vieux 21/08/2015, 02h02   #2
wscar
Avatar de wscar
wscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to behold
show the ecu relay sometimes it happens that the gnd don t arrive to the relay due to a wire who often is broken betwen battery and radiator
if you want to be sure of your problem just show what is the relay of ecu locate the +12 and make a bridge and show if car start
Si j ai peu aider n oubliez pas de cliquer sur THANKS!
wscar est déconnecté   Réponse avec citation
Vieux 21/08/2015, 02h25   #3
manueldord
you do not quite understand but I try to do what he says
Vieux 21/08/2015, 03h53   #4
wscar
Avatar de wscar
sorry for my bad english but im sure its your problem ive solved many times yhe same problem red immo light fixed and engine dont start
if thlight is fixed it mean that the ecu is not conncted
Vieux 21/08/2015, 08h41   #5
manueldord
you know what relay should I look? thanks and regards
Vieux 21/08/2015, 19h55   #6
hsf2014
Avatar de hsf2014
bonjour , did you try a "hard reset batterie" ? it maybe a bug of the habitacle unit controle , a hard reset can debug it . recurent case for this type of cars . good luck
Vieux 21/08/2015, 20h16   #7
manueldord
I should do then mate?
Vieux 21/08/2015, 20h26   #8
adel2789
Avatar de adel2789
adel2789 is a jewel in the roughadel2789 is a jewel in the roughadel2789 is a jewel in the roughadel2789 is a jewel in the rough
first you have to check fault codes to know if ecu communicates or not after that there many reasons for this problem
adel2789 est déconnecté   Réponse avec citation
Vieux 24/08/2015, 11h32   #9
manueldord
Hello again fellow did not connect any machine diagnosis
so I can not put bugs
Demande immo sur Renault Laguna momoh-93 Immobilizer dumps/solutions 15 02/03/2014 20h03
immo off / vierge laguna 1.9dci 2002 kro93420 Immobilizer dumps/solutions 5 10/12/2013 22h14
Immo off , renault Espace , 2002 bangreno Immobilizer dumps/solutions 4 27/12/2011 14h36
RENAULT LAGUNA 1.9 dci 2002 freeman2001 Renault, Dacia, Nissan 5 27/10/2010 14h58
RESOLU ou pas, FIXED or not. Amine13 Café du forum 1 10/12/2009 20h44
Fuseau horaire GMT +1. Il est actuellement 18h09.
