Hello fellow someone can lend me a hand on this topic
Immo in light fixed dash and not start thanks and regards |
Pouvoir de réputation: 21 ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
show the ecu relay sometimes it happens that the gnd don t arrive to the relay due to a wire who often is broken betwen battery and radiator
if you want to be sure of your problem just show what is the relay of ecu locate the +12 and make a bridge and show if car start
Si j ai peu aider n oubliez pas de cliquer sur THANKS! |
you do not quite understand but I try to do what he says
sorry for my bad english but im sure its your problem ive solved many times yhe same problem red immo light fixed and engine dont start
if thlight is fixed it mean that the ecu is not conncted
you know what relay should I look? thanks and regards
bonjour , did you try a "hard reset batterie" ? it maybe a bug of the habitacle unit controle , a hard reset can debug it . recurent case for this type of cars . good luck
I should do then mate?
Pouvoir de réputation: 16 ![]() ![]() ![]() ![]() |
first you have to check fault codes to know if ecu communicates or not after that there many reasons for this problem
Hello again fellow did not connect any machine diagnosis
so I can not put bugs |
| Demande immo sur Renault Laguna | momoh-93 | Immobilizer dumps/solutions | 15 | 02/03/2014 20h03 |
| immo off / vierge laguna 1.9dci 2002 | kro93420 | Immobilizer dumps/solutions | 5 | 10/12/2013 22h14 |
| Immo off , renault Espace , 2002 | bangreno | Immobilizer dumps/solutions | 4 | 27/12/2011 14h36 |
| RENAULT LAGUNA 1.9 dci 2002 | freeman2001 | Renault, Dacia, Nissan | 5 | 27/10/2010 14h58 |
| RESOLU ou pas, FIXED or not. | Amine13 | Café du forum | 1 | 10/12/2009 20h44 |
