Vieux 07/07/2015, 19h51   #151
stephane
Avatar de stephane
Pouvoir de réputation: 121
Oups je le fait desuite
Vieux 07/07/2015, 20h00   #152
yvespapou
Avatar de yvespapou
yvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond repute
voila steph les schéma ultraprog mdp dans ta boite
Type de fichier : rar STEPH SCHEMA ULTRAPROG.rar (1,79 Mo, 46 affichages)
yvespapou est déconnecté   Réponse avec citation
Vieux 08/07/2015, 08h34   #153
stephane
Avatar de stephane
Branchement du fiat 500 similaires au golf7 X-prog
Vieux 08/07/2015, 10h27   #154
Scanworld2020
Avatar de Scanworld2020
Scanworld2020 has a brilliant futureScanworld2020 has a brilliant futureScanworld2020 has a brilliant futureScanworld2020 has a brilliant futureScanworld2020 has a brilliant futureScanworld2020 has a brilliant futureScanworld2020 has a brilliant futureScanworld2020 has a brilliant futureScanworld2020 has a brilliant futureScanworld2020 has a brilliant futureScanworld2020 has a brilliant future
Bjr Stephane,
je peux avoir le clear Airbag logan
A2C80612810
285584207R
merciii
Type de fichier : rar mpc5603p_data flash(00800000, 00010000)_(LE)_(2015.06.23_17.07.rar (5,1 Ko, 24 affichages)
Scanworld2020 est déconnecté   Réponse avec citation
Vieux 08/07/2015, 15h25   #155
stephane
Avatar de stephane
Voilà msieux passe dans ta boîte
Type de fichier : rar DACIA LOGANE 285584207R A2C80612810_cleared.rar (5,4 Ko, 45 affichages)
Vieux 08/07/2015, 15h42   #156
Scanworld2020
Mercii, je vais le tester des que possible
Vieux 08/07/2015, 20h42   #157
yvespapou
Avatar de yvespapou
Envoyé par stephane Voir le message
ok tu avait raison
Vieux 11/07/2015, 22h39   #158
stephane
Avatar de stephane
Salutation
Voilas suite a ta demande Verdun voilà le dossier avec la flash et le code flash si c est corrompu tu pourras sauver ton boîtier
Type de fichier : rar CLIO4 FE 3000.rar (205,0 Ko, 22 affichages)
Vieux 12/07/2015, 22h07   #159
Verdun
Avatar de Verdun
Verdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud ofVerdun has much to be proud of
Salutation
merci je te tien au courant.
Verdun est déconnecté   Réponse avec citation
Vieux 13/07/2015, 15h44   #160
Scanworld2020
après le teste, le fichier est fonctionnel à 100%
Merci Stephane .
Vieux 13/07/2015, 15h59   #161
stephane
Avatar de stephane
Merci pour le retour
Vieux 14/07/2015, 06h42   #162
mouaoued
Avatar de mouaoued
mouaoued is a jewel in the roughmouaoued is a jewel in the roughmouaoued is a jewel in the roughmouaoued is a jewel in the rough
Par défaut bonjour
aide clear airbag A2C80613911 985101389R
Type de fichier : rar ARBAG.rar (5,8 Ko, 17 affichages)
mouaoued est déconnecté   Réponse avec citation
Vieux 14/07/2015, 11h17   #163
stephane
Avatar de stephane
Salutation mouaoued
Tu as extrait le code flash !!
Il me faut la data flash
Vieux 15/07/2015, 02h57   #164
zidane autodiag
Avatar de zidane autodiag
zidane autodiag is a jewel in the roughzidane autodiag is a jewel in the roughzidane autodiag is a jewel in the roughzidane autodiag is a jewel in the rough
Thumbs up
salut Stephane
stp tu peu me fair un clear crash dacia logan
A2C80612810 285584207R
cordialement
Type de fichier : rar DACIA LOGANE A2C80612810 285584207R .rar (5,7 Ko, 22 affichages)
Dtc, Egr, Dpf,Throttle, Flaps, Lambda, Hotstart, AdBlue, Evap, Nox, Speed limiter
Skype : soufi217
zidane autodiag est déconnecté   Réponse avec citation
Vieux 15/07/2015, 23h22   #165
stephane
Avatar de stephane
Voilas ton clear n oublie pas le retour
Type de fichier : rar DACIA LOGANE 285584207R A2C80612810_cleared.rar (5,4 Ko, 35 affichages)
Voici pour vous un vierge uch dacia 2010- clio symbol 2010- 8201068828 juju64 Immobilizer dumps/solutions 0 18/01/2015 16h13
Rate sur une dacia 1.4 mpi raisinsec Renault, Dacia, Nissan 9 14/09/2012 20h50
UCH Dacia hs Jarpy Tableau de bord (Dashboard) 12 19/04/2012 02h16
dacia 2008 messhi78 Renault, Dacia, Nissan 5 28/02/2011 12h58
dacia ems3132 digicar Renault, Dacia, Nissan 5 06/12/2009 21h13
Fuseau horaire GMT +1. Il est actuellement 17h43.
