Vieux 07/10/2014, 06h54   #1
maitresox
Avatar de maitresox
Pouvoir de réputation: 69
maitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond repute
Thumbs up Renault CAN CLIP Version 143
Voici le soft RENAULT Can Clip V 143, version complète Multi-langues
Bon diag
N'oubliez pas le petit Thanks
Maitres@x
Type de fichier : txt Renault Clip V143.txt (98 octets, 237 affichages)
Dernière modification par cedrsan ; 07/10/2014 à 07h22.
maitresox est déconnecté   Réponse avec citation
The Following 64 Users Say Thank You to maitresox For This Useful Post:
سعدان (28/10/2014), abdelamjid (19/10/2014), adiago (07/10/2014), amarpop (11/12/2014), benhedi70 (27/08/2017), br25 (07/10/2014), camacho (07/10/2014), caroptimum (07/10/2014), cedrsan (07/10/2014), CHATONDU38 (19/10/2014), dalysmag (09/11/2014), devildante007 (07/10/2014), diagnosis29 (07/10/2014), diagprog (07/10/2014), dingo307 (15/11/2014), dollarbill (13/11/2014), drissdiag (07/10/2014), EDAS (07/10/2014), EL9AROUS (22/10/2014), foulques (15/11/2014), franck95 (07/10/2014), h tech (07/10/2014), hydrofrein (07/10/2014), izi (07/10/2014), izouf (02/11/2014), jardini (21/10/2014), jéjé (11/01/2015), jope (25/10/2014), jpanasonic (09/10/2014), jphp (07/10/2014), juju64 (07/10/2014), komorovskij (19/10/2014), krimo054 (17/10/2014), KWP2000 (06/11/2014), L.D.B.OMAR (13/10/2014), leblanc76418 (07/10/2014), mahfoud lichani (07/10/2014), MALLATATEF (17/02/2015), manudiag (26/10/2014), MCNexo94 (16/10/2014), Mike H (07/10/2019), Momo44 (07/10/2014), monsach (22/10/2014), Mousdiouf (17/04/2015), mustafa (10/10/2014), mvl (11/10/2014), nastradini (07/10/2014), nimbus (07/12/2014), reda75 (07/10/2014), san-style95 (24/11/2014), sapeurs01 (08/10/2014), Scanworld2020 (15/10/2014), serval (07/10/2014), silver2x (07/10/2014), slv (04/11/2014), sntyad (12/10/2014), star31 (07/10/2014), vortex (19/10/2014), willy14 (07/10/2014), wism3 (03/11/2014), youcef_trik (07/10/2014), yvespapou (26/10/2014), zagor (30/10/2014)
Vieux 07/10/2014, 16h42   #2
juju64
Avatar de juju64
juju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to behold
Bonjour à tous, Attention beaucoup de problèmes dans le réseau Renault avec cette nouvelle mise à jour.
juju64 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to juju64 For This Useful Post:
krimo054 (18/10/2014), youcef_trik (08/10/2014)
Vieux 07/10/2014, 19h10   #3
salut, on devait me prêter un clip original pour une clio II et le chauffage !, mais cet aprèm mon ami me dit que son clip ne fonctionne plus depuis sa dernière Mise a jour, il s'est bloqué ! si vous avez une idée du problème ?
Vieux 07/10/2014, 20h12   #4
juju64
Avatar de juju64
Apparemment problème de pilote sonde, il est sous xp ?
The Following User Says Thank You to juju64 For This Useful Post:
jphp (07/10/2014)
Vieux 07/10/2014, 20h58   #5
kitten13
Guest
Avatar de kitten13
Messages: n/a
Envoyé par juju64 Voir le message
et avec seven ?
Sinon je prefere passer mon tour et attendre la version 144...
Encore merci maitresox
jphp (07/10/2014)
Vieux 07/10/2014, 21h04   #6
juju64
Avatar de juju64
Sous win 7 la sonde Bluetooth a bien été mise a jour, j'ai du redémarrer le pc pour qu'elle refonctionne , attention la fonction Bluetooth ne fonctionnera plus si on revient a une version précédente. Pour la sonde can alu je sais pas si elle marche .
jphp (07/10/2014)
Vieux 07/10/2014, 21h22   #7
merci, c un clip officiel sous xp le mini pc est entièrement dedié a ce clip sous xp oui il me l'avait prêté l'année dernière et j'en avait besoin, il avait les drapeaux RENAULT ds son garage a cette epoque, et plus aujourd'hui le matériel lui appartient, il ne fonctionne plus depuis la dernière MAJ , je suppose comme vous que son abonnement est résilié, je sais pas ?
des soluces ??
Vieux 07/10/2014, 21h28   #8
juju64
Avatar de juju64
l'abonnement est d'un an renouvelable a la date anniversaire avec le token , si il a eu le message c'est ca si non, la v143 a plantée, le mieux c'est de repassé en 142.
jphp (07/10/2014)
Vieux 07/10/2014, 21h35   #9
j'irai chercher son clip pour en savoir plus sur sa version
et j'aurai besoin de vous pour le refaire marcher , si c possible
merci a tous
Vieux 07/10/2014, 23h24   #10
Heineken
Avatar de Heineken
Pouvoir de réputation: 31
malheureusement pour savoir , il faudra plus de précision sur le problème .
Genre quand le problème survient , quel message d'erreur apparait (illustré avec une capture écran pourquoi pas) , dans quel circonstance survient le blocage.....
ça peut être logiciel , matériel , où oui , niveau activation aussi.... Sans plus de précisions , nos conseil ne resteront que supposition .
The Following User Says Thank You to Heineken For This Useful Post:
jphp (08/10/2014)
Vieux 08/10/2014, 00h23   #11
cedrsan
Avatar de cedrsan
Pouvoir de réputation: 183
cedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond repute
Actuellement déployé chez 4 pros, pas de soucis. Je n'ai pas non plus de problème. (Je parle pour de l'original uniquement)
  • - Petite Astuce Pour utiliser la Recherche sur le Forum => Cliquez-ICI
  • - Faire fonctionner Nyo4_2012 sur Windows 7 x64=> ICI
  • - Décompresser sans erreur les fichiers .RAR avec la dernière version de Winrar => ICI
  • - Ne plus avoir de Pub sur Internet => ICI
cedrsan est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to cedrsan For This Useful Post:
diagnosis29 (08/10/2014), jphp (08/10/2014), juju64 (08/10/2014), Scanworld2020 (15/10/2014), youcef_trik (08/10/2014)
Vieux 08/10/2014, 07h20   #12
juju64
Avatar de juju64
Salut Cedrsan, avec quelle modèle de sonde et sous quel OS, merci
Vieux 08/10/2014, 11h16   #13
cedrsan
Avatar de cedrsan
RLT2002 sous Clip Access en XP.
The Following 7 Users Say Thank You to cedrsan For This Useful Post:
devildante007 (08/10/2014), diagnosis29 (08/10/2014), jphp (08/10/2014), juju64 (08/10/2014), nastradini (08/10/2014), Scanworld2020 (15/10/2014), youcef_trik (08/10/2014)
Vieux 08/10/2014, 17h54   #14
nowen
Avatar de nowen
Pouvoir de réputation: 66
Alors, chez nous 3 instal sur clip officielles en xp, 2 ok avec sonde rtl mais la 3 problème le clip marche mais disque dur rempli, plus que 47 ko de libre, pas possible de faire grand chose, genre imprimer ou autre. en fait au téléchargement de la mise à jour il y a une création d'un fichier .log qui doit faire 1 ko je crois mais là ce fichier faisait plus de 63 Go. suite à la suppression de ce fichier tout est ok.
elle est un peu ratée cette mise à jour
The Following 3 Users Say Thank You to nowen For This Useful Post:
cedrsan (08/10/2014), diagnosis29 (08/10/2014), juju64 (08/10/2014)
Vieux 15/10/2014, 13h56   #15
bonjour, j'ai récupéré le pc de mon pote, clip est verrouillé suite a la derniere mise a jour, il essayer de réinstaller a partir du cd officiel, et c pareil!
je suppose que je doit désinstaller, ? pour installer ta version ?
Dernière modification par jphp ; 15/10/2014 à 13h59.
Renault CAN-Clip Version 116 - 117 - 118 - 119 -120 cedrsan Renault clip, DDT2000, Nissan consult 5 31/01/2018 09h05
Installation de Renault - CAN CLIP - Version 124 dybou Renault clip, DDT2000, Nissan consult 11 21/12/2014 13h59
Fuseau horaire GMT +1. Il est actuellement 18h31.
