voila comment teste un debimetre sans le demonter avec multimetre
http://www.youtube.com/watch?v=t1sJdy29TjI
l union fait la force |
| The Following 64 Users Say Thank You to electro_bordeaux1 For This Useful Post: | ajfleclerc (24/08/2014), al1962 (06/10/2014), allpatchi (07/03/2015), angels59 (24/08/2014), auto diag1 (15/10/2014), autodiagauto (23/08/2014), brabra (25/08/2014), camacho (23/08/2014), carspeed (03/01/2015), cmoithiery (24/04/2015), corre (14/12/2014), DCH22 (11/02/2015), diagprog (23/08/2014), didine (31/10/2014), dinalo (05/10/2014), djardo42 (28/12/2014), domtoréto (21/03/2015), ECU diag (24/08/2014), el portable (04/01/2015), filou2411 (24/08/2014), garageducentre (26/08/2014), garciasgt76600 (24/08/2014), hydrofrein (24/08/2014), ishams2002 (06/11/2014), jéjé la bricole (23/08/2014), karwad (24/08/2014), legrek (06/10/2014), Malfra90 (07/09/2014), MecaTech (24/08/2014), MERCO86 (26/08/2014), moradweb (05/10/2014), muro57 (02/11/2014), mustauto (07/12/2014), mvl (07/09/2014), nasisamy (24/08/2014), nimbus (23/08/2014), Nizar-maoukil (05/09/2014), nono95 (11/11/2014), nounour10 (07/01/2019), nyonsais (26/08/2014), philou6871 (30/12/2014), pp08 (19/08/2017), prodlt (27/08/2014), ptidave001 (06/10/2014), reda75 (25/08/2014), samb4064 (07/12/2014), sapopt (03/09/2014), selouan (16/09/2014), sharable1 (11/11/2014), shud (12/11/2014), sofian.melun (01/01/2015), television (03/09/2014), tigreblanc (27/08/2014), tizef (24/08/2014), tom077 (26/10/2014), tonio5766 (06/09/2014), vortex (04/09/2014), VWPassat31 (23/08/2014), walteck (25/08/2014), YaseiSan (17/01/2026), ygsxr (29/05/2015), YUMBO (24/08/2014), yvespapou (23/08/2014), zemiguel (24/10/2014) |
![]() Date d'inscription: mai 2009
Pouvoir de réputation: 43 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
très utile cela sert il a tous les debimetre
merci |
| The Following User Says Thank You to autodiagauto For This Useful Post: | electro_bordeaux1 (23/08/2014) |
d apres cette video le principe est tres claire donc on peut l utilier sur n importe quelle debimetre
| The Following 3 Users Say Thank You to electro_bordeaux1 For This Useful Post: |
plus besoin de valise
| The Following 2 Users Say Thank You to Meziane93 For This Useful Post: | didine (31/10/2014), electro_bordeaux1 (24/08/2014) |
Pouvoir de réputation: 26 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
tu ne peux pas te tromper comme ça à la valise des fois ta debimetre hs et il ne l'est pas
| The Following 2 Users Say Thank You to ryosaeba For This Useful Post: | didine (31/10/2014), electro_bordeaux1 (24/08/2014) |
petite précision!
je suis d'accord avec la video dans le principe pour les débitmètres à fil chaud psa 5 ou 6 fils: 12V, masse (chauffer le fil);temp air CTN, masse, et signal débit mètre(0 à5 volts) 0,5 vAPC ralenti avec egr 2V, sans egr 2,5V et minimum 4 volts sur coup de gaz sinon valeur erronée! chez renault un 5 volt en plus |
| The Following 2 Users Say Thank You to tizef For This Useful Post: | electro_bordeaux1 (24/08/2014), pacoaloha (06/09/2014) |
salut, ce n'est pas une science exact non plus,
j'ai eu le cas sur Audi A4 , voyant allumé, mais tous marche pas de dégradé, au diag, = débitmètre!, débitmètre remplacé , et c pareil, en fait ils avait déconnecter, le tube de l'ELCV EGR et bouché avec une vis, donc c'était pas le débitmetre , mais le bricolage depuis ca , plus de voyant, les gars ne nous disent pas tout!! non plus @+ |
| The Following 4 Users Say Thank You to jphp For This Useful Post: |
cette méthode était possible avant la présence d'un capteur de position pour la recopie( et que le calculateur en tienne compte) < 2005
| The Following 5 Users Say Thank You to tizef For This Useful Post: | adiago (24/08/2014), autodiagauto (24/08/2014), dinalo (05/10/2014), electro_bordeaux1 (24/08/2014), Jimbo (23/09/2017) |
salut tizef
tu peut nous en dire plus sut les capteur de position pour la recopie comment fontionne merci |
| The Following User Says Thank You to autodiagauto For This Useful Post: | electro_bordeaux1 (24/08/2014) |
#10 |
je parlais de l'egr et pas du débit mètre
en fait c'est une gestion en boucle fermée! a une demande calculateur correspond une position dans une vanne egr renault http://www.pierburg-service.de/ximag...85a_fr_web.pdf il y a la bobine et le potentiomètre, la bobine c'est la partie commande alimenté en 12 v et masse commandée en RCO a une demande x correspond une position le potentimetre dans l'exemple (capteur de psition) est alimenté en 5 v et masse et signal ce signal est repris par le calculo( boucle fermée), a une demande correspond une position avant 2005: - on pouvait supprimer la commande ( la masse commandé) sans que cela n'allume un voyant; le potentiomètre et son signal -on pouvait aussi boucher le tuyau de sortie de l'EV EGR maintenant c'est plus possible car soit l'on compare la commande et la position et dans tous les cas le signal débitmètre est là aussi pour surveiller la quantité de gaz recyclé! seul moyen egr off via reprog |
| The Following 8 Users Say Thank You to tizef For This Useful Post: | autodiagauto (04/09/2014), diagnosis29 (24/08/2014), dinalo (05/10/2014), electro_bordeaux1 (25/08/2014), garageducentre (26/08/2014), pacoaloha (06/09/2014), prodlt (27/08/2014), tigreblanc (26/08/2014) |
#11 |
dit nous plus mon ami sltp, les programmes EGR chez PSA ?? ceux qui verrouille a partir d'un certains nombres d'erreurs de recopie ??
#12 |
#13 |
2012> les nouveaux DV6C le nombres d'erreurs de recopies EGR est limité a 14 !!!
mm si certains pense 50!! ca na rien a voir, tu as beau changer la vanne , !! et coder !! c pareil !!, ca met ok ca code , mais c pareil mm symptômes, mm code défauts chez psa ils remplace le calculateur !!pour çà @++ |
#14 |
mes remarques concernait avant 2005 !merci de me l'apprendre(enfin , il me semble que j'avais déjà lu ta remarque dans un autre post), donc de me le ,non de le nous rappeler!
et toi pour ça que préconises tu jp? un chagement de calculo comme peugeot! |
#15 |
lol ! les chiptuners on une technique qui marche, il faut planter le calculateur!!
chose a ne jamais faire ! jamais, c pour ca qu'il ne faut pas la mettre entre ttes les mains mais ca marche pas besoin de changer le calculateur
| The Following 2 Users Say Thank You to jphp For This Useful Post: | diagnosis29 (04/09/2014), dinalo (05/10/2014) |
| Outils de la discussion | |
| Pince Ampèremétrique(multimètre) Original Facom à Vendre Sous Emballage | nany | Vente, Achat, Echange | 0 | 25/03/2014 10h20 |
| probleme debimetre 407 hdi 2.2 | MAXYBOOM | Mécanique générale | 4 | 03/12/2013 00h52 |
| Valeurs de débimetre | DIAGAUTO33 | Mécanique générale | 6 | 11/08/2013 21h24 |
| Flashage de débimètre ! | Amine13 | VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche | 25 | 26/01/2013 18h44 |
| multimetre Fluke | hi_Tech_Dz | Electronique | 6 | 11/12/2010 11h56 |
