Vieux 23/08/2014, 15h41   #1
electro_bordeaux1
Avatar de electro_bordeaux1
Par défaut tester un debimetre avec multimetre
voila comment teste un debimetre sans le demonter avec multimetre
http://www.youtube.com/watch?v=t1sJdy29TjI
l union fait la force
The Following 64 Users Say Thank You to electro_bordeaux1 For This Useful Post:
ajfleclerc (24/08/2014), al1962 (06/10/2014), allpatchi (07/03/2015), angels59 (24/08/2014), auto diag1 (15/10/2014), autodiagauto (23/08/2014), brabra (25/08/2014), camacho (23/08/2014), carspeed (03/01/2015), cmoithiery (24/04/2015), corre (14/12/2014), DCH22 (11/02/2015), diagprog (23/08/2014), didine (31/10/2014), dinalo (05/10/2014), djardo42 (28/12/2014), domtoréto (21/03/2015), ECU diag (24/08/2014), el portable (04/01/2015), filou2411 (24/08/2014), garageducentre (26/08/2014), garciasgt76600 (24/08/2014), hydrofrein (24/08/2014), ishams2002 (06/11/2014), jéjé la bricole (23/08/2014), karwad (24/08/2014), legrek (06/10/2014), Malfra90 (07/09/2014), MecaTech (24/08/2014), MERCO86 (26/08/2014), moradweb (05/10/2014), muro57 (02/11/2014), mustauto (07/12/2014), mvl (07/09/2014), nasisamy (24/08/2014), nimbus (23/08/2014), Nizar-maoukil (05/09/2014), nono95 (11/11/2014), nounour10 (07/01/2019), nyonsais (26/08/2014), philou6871 (30/12/2014), pp08 (19/08/2017), prodlt (27/08/2014), ptidave001 (06/10/2014), reda75 (25/08/2014), samb4064 (07/12/2014), sapopt (03/09/2014), selouan (16/09/2014), sharable1 (11/11/2014), shud (12/11/2014), sofian.melun (01/01/2015), television (03/09/2014), tigreblanc (27/08/2014), tizef (24/08/2014), tom077 (26/10/2014), tonio5766 (06/09/2014), vortex (04/09/2014), VWPassat31 (23/08/2014), walteck (25/08/2014), YaseiSan (17/01/2026), ygsxr (29/05/2015), YUMBO (24/08/2014), yvespapou (23/08/2014), zemiguel (24/10/2014)
Vieux 23/08/2014, 16h26   #2
autodiagauto
Avatar de autodiagauto
Pouvoir de réputation: 43
autodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond reputeautodiagauto has a reputation beyond repute
très utile cela sert il a tous les debimetre
autodiagauto est connecté maintenant   Réponse avec citation
The Following User Says Thank You to autodiagauto For This Useful Post:
electro_bordeaux1 (23/08/2014)
Vieux 23/08/2014, 17h56   #3
electro_bordeaux1
d apres cette video le principe est tres claire donc on peut l utilier sur n importe quelle debimetre
The Following 3 Users Say Thank You to electro_bordeaux1 For This Useful Post:
autodiagauto (23/08/2014), didine (31/10/2014), dinalo (05/10/2014)
Vieux 24/08/2014, 00h19   #4
Meziane93
Avatar de Meziane93
plus besoin de valise
The Following 2 Users Say Thank You to Meziane93 For This Useful Post:
didine (31/10/2014), electro_bordeaux1 (24/08/2014)
Vieux 24/08/2014, 10h36   #5
ryosaeba
Avatar de ryosaeba
Pouvoir de réputation: 26
tu ne peux pas te tromper comme ça à la valise des fois ta debimetre hs et il ne l'est pas
The Following 2 Users Say Thank You to ryosaeba For This Useful Post:
Vieux 24/08/2014, 13h23   #6
tizef
Avatar de tizef
tizef is a name known to alltizef is a name known to alltizef is a name known to alltizef is a name known to alltizef is a name known to alltizef is a name known to all
petite précision!
je suis d'accord avec la video dans le principe
pour les débitmètres à fil chaud
psa 5 ou 6 fils: 12V, masse (chauffer le fil);temp air CTN, masse, et signal débit mètre(0 à5 volts)
0,5 vAPC ralenti avec egr 2V, sans egr 2,5V et minimum 4 volts sur coup de gaz
sinon valeur erronée!
chez renault un 5 volt en plus
tizef est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to tizef For This Useful Post:
electro_bordeaux1 (24/08/2014), pacoaloha (06/09/2014)
Vieux 24/08/2014, 13h33   #7
salut, ce n'est pas une science exact non plus,
j'ai eu le cas sur Audi A4 , voyant allumé, mais tous marche pas de dégradé, au diag, = débitmètre!,
débitmètre remplacé , et c pareil, en fait ils avait déconnecter, le tube de l'ELCV EGR et bouché avec une vis, donc c'était pas le débitmetre , mais le bricolage
depuis ca , plus de voyant, les gars ne nous disent pas tout!! non plus
The Following 4 Users Say Thank You to jphp For This Useful Post:
dinalo (05/10/2014), electro_bordeaux1 (24/08/2014), tizef (24/08/2014), vortex (04/09/2014)
Vieux 24/08/2014, 19h32   #8
tizef
Avatar de tizef
cette méthode était possible avant la présence d'un capteur de position pour la recopie( et que le calculateur en tienne compte) < 2005
The Following 5 Users Say Thank You to tizef For This Useful Post:
adiago (24/08/2014), autodiagauto (24/08/2014), dinalo (05/10/2014), electro_bordeaux1 (24/08/2014), Jimbo (23/09/2017)
Vieux 24/08/2014, 21h07   #9
autodiagauto
salut tizef
tu peut nous en dire plus sut les capteur de position pour la recopie
comment fontionne
Vieux 24/08/2014, 23h33   #10
tizef
Avatar de tizef
je parlais de l'egr et pas du débit mètre
en fait c'est une gestion en boucle fermée!
a une demande calculateur correspond une position
dans une vanne egr renault
http://www.pierburg-service.de/ximag...85a_fr_web.pdf
il y a la bobine et le potentiomètre, la bobine c'est la partie commande alimenté en 12 v et masse commandée en RCO
a une demande x correspond une position
le potentimetre dans l'exemple (capteur de psition) est alimenté en 5 v et masse et signal
ce signal est repris par le calculo( boucle fermée), a une demande correspond une position
avant 2005:
- on pouvait supprimer la commande ( la masse commandé) sans que cela n'allume un voyant; le potentiomètre et son signal
-on pouvait aussi boucher le tuyau de sortie de l'EV EGR
maintenant c'est plus possible car soit l'on compare la commande et la position et dans tous les cas le signal débitmètre est là aussi pour surveiller la quantité de gaz recyclé!
seul moyen egr off via reprog
The Following 8 Users Say Thank You to tizef For This Useful Post:
autodiagauto (04/09/2014), diagnosis29 (24/08/2014), dinalo (05/10/2014), electro_bordeaux1 (25/08/2014), garageducentre (26/08/2014), pacoaloha (06/09/2014), prodlt (27/08/2014), tigreblanc (26/08/2014)
Vieux 04/09/2014, 19h50   #11
dit nous plus mon ami sltp, les programmes EGR chez PSA ?? ceux qui verrouille a partir d'un certains nombres d'erreurs de recopie ??
Vieux 04/09/2014, 20h31   #12
tizef
Avatar de tizef
ça j'en sais rien jphp ,ça concerne quel véhicule, quel année?
Vieux 04/09/2014, 21h38   #13
2012> les nouveaux DV6C le nombres d'erreurs de recopies EGR est limité a 14 !!!
mm si certains pense 50!! ca na rien a voir,
tu as beau changer la vanne , !! et coder !! c pareil !!, ca met ok ca code , mais c pareil mm symptômes, mm code défauts
chez psa ils remplace le calculateur !!pour çà
dinalo (05/10/2014), tizef (04/09/2014)
Vieux 04/09/2014, 22h01   #14
tizef
Avatar de tizef
mes remarques concernait avant 2005 !merci de me l'apprendre(enfin , il me semble que j'avais déjà lu ta remarque dans un autre post), donc de me le ,non de le nous rappeler!
et toi pour ça que préconises tu jp? un chagement de calculo comme peugeot!
Vieux 04/09/2014, 22h35   #15
lol ! les chiptuners on une technique qui marche, il faut planter le calculateur!!
chose a ne jamais faire ! jamais,
c pour ca qu'il ne faut pas la mettre entre ttes les mains
mais ca marche pas besoin de changer le calculateur
diagnosis29 (04/09/2014), dinalo (05/10/2014)
Pince Ampèremétrique(multimètre) Original Facom à Vendre Sous Emballage nany Vente, Achat, Echange 0 25/03/2014 10h20
probleme debimetre 407 hdi 2.2 MAXYBOOM Mécanique générale 4 03/12/2013 00h52
Valeurs de débimetre DIAGAUTO33 Mécanique générale 6 11/08/2013 21h24
Flashage de débimètre ! Amine13 VAG group vw, audi, skoda, seat, bentley, lamborghini, porsche 25 26/01/2013 18h44
multimetre Fluke hi_Tech_Dz Electronique 6 11/12/2010 11h56
Fuseau horaire GMT +1. Il est actuellement 18h25.
