Autoradio et Navigateur GPS Astuce, dump, aide pour décodage d'autoradio et navigateur. |
08/02/2012, 09h51 | #1 |
Pouvoir de réputation: 41 |
Delco-calc BAY SN
The Following 15 Users Say Thank You to reda75 For This Useful Post: | benyunes (08/02/2012), bonus2010 (09/02/2012), carfixer (14/10/2013), DIAGSYSTEM25 (08/02/2012), djemai (14/02/2012), Formator (15/02/2012), kadi0209 (17/02/2012), kam306 (09/02/2012), leon2 (08/02/2012), massiniss (09/02/2012), mohamadvw (08/02/2012), noreddine ben ahmed (14/02/2012), ricards99 (08/02/2012), verdi (14/02/2012), wilcocoyot (08/02/2012) |
14/02/2012, 00h18 | #2 |
Pouvoir de réputation: 0 |
Hi reda75 thanks for prog
The program does not work with me. Please tell me what needs to be done Note I am working on Windows me and did not work on xp thank you for your time |
14/02/2012, 19h40 | #3 |
Pouvoir de réputation: 179 |
il ne s'agit pas d'un programme, ni un calculateur. C'est une base de donnée uniquement ! ++ ced |
The Following User Says Thank You to cedrsan For This Useful Post: | talel66 (14/02/2012) |
14/02/2012, 20h51 | #4 |
thanks cedrsan
You are right. I know it's database. But tell me how I can use it I have this SN helped me to get code GM0500W9356377 GM150010356511 & GM1500Y9500750 thank you |
14/02/2012, 21h16 | #5 |
This Database is too old.
Your carradio's are CDR500. Codes available only by dump the TMS370 or by K-LINE ++ ced |
14/02/2012, 21h51 | #6 |
Hi cedrsan
Made one. But each read a different number and returned connections did not know where the defect. Tell me if you have a solution .please thanks |
Sponsored Link |
Liens sociaux |
Discussions similaires | ||||
delco avec sensor | haddadou | Mécanique générale | 16 | 13/08/2015 16h48 |
[Résolu] Plz code radio delco cdr500 | helmi reguig | Autoradio et Navigateur GPS | 6 | 04/02/2012 15h31 |
Delco CDR500 code | auto diag1 | Autoradio et Navigateur GPS | 4 | 25/01/2012 14h53 |
Delco electronic cdr500 | auto diag1 | Autoradio et Navigateur GPS | 6 | 29/12/2011 21h41 |
code cd delco | sametelec2003 | Autoradio et Navigateur GPS | 2 | 04/03/2009 16h54 |
