Vieux 13/12/2015, 21h43   #121
sebea33
Avatar de sebea33
sebea33 is on a distinguished road
je suis en 7.65 et je ne trouve pas 7.65 to 7.66 pour pouvoir faire les mise a jour.
sebea33 est déconnecté   Réponse avec citation
Vieux 13/12/2015, 22h14   #122
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Scarymistake did not post any release after DiagBox v7.65. So, you have to use maitresox's:
1- Make a backup copy of your Appdiag.sys file (C:\AWRoot\bin\fi\APPDIAG.SYS).
2- Use maitresox DiagBox v762-766 to upgrade from Scarymistake 7.65 and continue to upgrade using maitresox releases.
If you have issues, clean the "C:\AWRoot\dtwr\updt" folder and try upgrading again or downgrade your current installation using DiagBox v758-762 and continue upgrading.
Simple est déconnecté   Réponse avec citation
Vieux 13/12/2015, 23h10   #123
maitresox
Avatar de maitresox
Pouvoir de réputation: 69
maitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond repute
Prochainement 8.18 alias 7.82
maitresox est déconnecté   Réponse avec citation
Vieux 15/12/2015, 05h38   #124
work87
Avatar de work87
work87 is an unknown quantity at this point
Bravo Maitresox on attends la mise à jour avec impatience !
Le problème de changement de langue sera t'il corrigé ?
work87 est déconnecté   Réponse avec citation
Vieux 15/12/2015, 10h02   #125
ptidemon
Avatar de ptidemon
ptidemon is a jewel in the roughptidemon is a jewel in the roughptidemon is a jewel in the rough
pour compléter la question de work87, cette nouvelle version va t-elle régler le problème de désactivation de diagbox ? faudra t-il encore garder le fichier APPDIAG.SYS ?
Merci pour ce superbe travail Maitresox !!!
ptidemon est déconnecté   Réponse avec citation
Vieux 15/12/2015, 13h44   #126
adiago
Avatar de adiago
Pouvoir de réputation: 35
Super cadeau pour Noël !merci maitresox
Vieux 15/12/2015, 20h58   #127
JOohns
Avatar de JOohns
JOohns is an unknown quantity at this point
Merci pour les mises à jour ;) c'est Cool !! puis-je mettre la mise à jour si je suis en 7.62 ? en gros de passer 7.62 à 7.66 ?
JOohns est déconnecté   Réponse avec citation
Vieux 15/12/2015, 21h00   #128
CED300482
Avatar de CED300482
CED300482 will become famous soon enoughCED300482 will become famous soon enough
Oui biensur pas de problème
CED300482 est déconnecté   Réponse avec citation
Vieux 15/12/2015, 21h56   #129
maitresox
Avatar de maitresox
Envoyé par work87 Voir le message
Le changement de langue à l'intérieur de diagbox ne sera pas résolu. J'ai trouvé une solution mais je pense que cela a des impacts sur le fonctionnement en Diag. Du coup je laisse comme avant.
Diagbox sera entièrement en Français, lexia et pp2000 aussi sans rien changé, vous n'aurez rien à faire.
Il me reste le test des télécodages a réaliser mais j'avais déjà fait des modifs sur la 7.79 qui fonctionnait parfaitement.
Télécodage sur 3008 2014 ok.
Je uploaderai la maj à la fin de la semaine.
Pour infos, le C4 cactus a une nouvelle couleur !
Maitresox
The Following User Says Thank You to maitresox For This Useful Post:
DIAGAUTO33 (16/12/2015)
Vieux 15/12/2015, 22h27   #130
Simple
Avatar de Simple
Well done maitresox, keep up the good work..
Vieux 16/12/2015, 06h31   #131
work87
Avatar de work87
J'ai toujours le problème que les onglets documentation et rapport affichent un label avec not found.
Pourtant j'ai bien installé la dernière version de Java 7 et .NET Framework 3.5/4 sur mon Windows XP.
Une idée ?
Vieux 16/12/2015, 09h13   #132
dinalo
Avatar de dinalo
dinalo is a jewel in the roughdinalo is a jewel in the roughdinalo is a jewel in the rough
bonjour tt le monde
je suis sur Windows 7 64 bits
est ce que ca passe l installation desus
je vois que certain on des prob avec lexia
merci de vos reponse
plus c est complique mieux c est !!!!!
ON N OUBLIES PAS THANKS !!!!!!!!!!!!
SEBAMECA
dinalo est déconnecté   Réponse avec citation
Vieux 16/12/2015, 09h21   #133
Simple
Avatar de Simple
@work87,
The reason behind the language problem is two folds and was introduced when Actia decided to change the coding standard in release update 7.74.. I personally don't have this problem as I changed the language manually and described how to do it in another thread.
You could do the following:
Add language "English US" to your Windows and compare your DiagBox language settings with manual language change I posted somewhere on this forum, then tell us if it has helped.
If does not help after you perform the above, I will ask you to check or post few other files.
Vieux 16/12/2015, 09h49   #134
dinalo
Avatar de dinalo
rebonjour je retrouve plus mon cd d'installation que j ai eu avec mon lexia
peu on trouve l installation de bas quelque part ?
merci de votre aide je suis un peu perdu la
SEBAMECA
Vieux 16/12/2015, 09h56   #135
adiago
Avatar de adiago
@dinalo
question posée des centaines de fois !avec seven 64 bits diagbox nouveaux modèles seulement.
avec seven 32bits diagbox nouveaux et anciens modèles lexia3 et pp2000
Mises à jour Diagbox 7.56 vers 7.57 et 7.01 vers 7.57 (updates OFFLINE) maitresox LEXIA, PP2000, DiagBox 9 29/11/2018 20h15
Mises à jour Diagbox 7.62 vers 7.66 (8.02) (updates OFFLINE) maitresox LEXIA, PP2000, DiagBox 104 28/02/2018 14h24
Mises à jour Diagbox 7.57 vers 7.58 et 7.58 vers 7.62 (updates OFFLINE) maitresox LEXIA, PP2000, DiagBox 59 25/08/2017 13h56
Mises à jour Diagbox 7.54 vers 7.55 et 7.44 vers 7.55 (updates OFFLINE) maitresox LEXIA, PP2000, DiagBox 1 22/11/2015 13h45
Mises à jour Diagbox 7.57 vers 7.61 (updates OFFLINE) maitresox LEXIA, PP2000, DiagBox 37 28/01/2015 21h37
Fuseau horaire GMT +1. Il est actuellement 23h12.
