Vieux 13/11/2017, 06h30   #1321
gabigafu
Avatar de gabigafu
Pouvoir de réputation: 44
gabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond repute
je n'ai pas de solution, il faut le modifier manuellement.
gabigafu est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to gabigafu For This Useful Post:
freddy5923 (18/03/2018), pouettedu76 (13/11/2017), Scanworld2020 (22/11/2017), vivi91r (13/11/2017), youcef_trik (13/11/2017)
Vieux 13/11/2017, 08h06   #1322
vivi91r
Avatar de vivi91r
vivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant future
Ok merci gabi pour la réponse.
Envoyé de mon SM-G531F en utilisant Tapatalk
vivi91r est déconnecté   Réponse avec citation
Vieux 17/11/2017, 17h14   #1323
tony60
Avatar de tony60
Pouvoir de réputation: 102
Salut est ce que clear air bag twingo 3 passe avec renolink?
Vieux 17/11/2017, 18h00   #1324
tony60
Avatar de tony60
J'ai trouver ma réponse c'est oui
http://www.tlemcen-electronic.com/forum/showthread.php?t=69205&highlight=Airbag+twingo+3
prinzo57 (17/11/2017)
Vieux 17/11/2017, 19h09   #1325
stephane
Avatar de stephane
Pouvoir de réputation: 121
Oui tu passe Clio 4
The Following 3 Users Say Thank You to stephane For This Useful Post:
pouettedu76 (17/11/2017), prinzo57 (17/11/2017), tony60 (17/11/2017)
Vieux 17/11/2017, 19h09   #1326
Ghis13
Avatar de Ghis13
Ghis13 will become famous soon enough
Salut aujourd’hui j ai fait une dae de clio 2ph2 je fait mon clear et je change le vin jusqu’à la tout va bien sauf que quand j’essaie de démarrer ça ne marche pas je mets le contact ça fait bip ça m’allume les warning et pas de démarreur si quelqu’un a une idée je suis preneur
Ghis13 est déconnecté   Réponse avec citation
Vieux 17/11/2017, 19h12   #1327
stephane
Avatar de stephane
Tu veux dire Clio 3
The Following 2 Users Say Thank You to stephane For This Useful Post:
Ghis13 (17/11/2017), pouettedu76 (17/11/2017)
Vieux 17/11/2017, 19h14   #1328
Ghis13
Avatar de Ghis13
Pffff fin de journée difficile lol oui clio 3 ph2
Vieux 17/11/2017, 19h16   #1329
stephane
Avatar de stephane
C'est quoi ton soucis à la base parce que en général Renolink marche très très bien sur les Clio III DAE
Ghis13 (17/11/2017), nowen (17/11/2017), pouettedu76 (17/11/2017)
Vieux 17/11/2017, 19h19   #1330
Ghis13
Avatar de Ghis13
C’est la voiture d’un client apparemment juste le changement de la colonne bien sûr une fois changer la voiture ne démarré plus
Vieux 17/11/2017, 19h21   #1331
tony60
Avatar de tony60
Refais un clear sur la dae alors... Sa fonctionne sur toute les clio 3 avant sa passé que sur les 1 ere clio 3
Ghis13 (17/11/2017)
Vieux 17/11/2017, 19h22   #1332
stephane
Avatar de stephane
Ça j'ai bien compris mais pourquoi ils ont changé la colonne c'est pas forcément un problème de DAE
Vieux 17/11/2017, 19h24   #1333
nowen
Avatar de nowen
Pouvoir de réputation: 66
Envoyé par Ghis13 Voir le message
Salut Ghis13,
ça ressemble à une détection de crash, c'est étrange ce qu'il t'arrive.
stephane dit vrai, ça passe tout seul avec RenoLink.
tu dois avoir un défaut dans un boitier non?
en état dans la dae tu as quoi?
The Following 4 Users Say Thank You to nowen For This Useful Post:
davycdz (18/11/2017), Ghis13 (17/11/2017), pouettedu76 (17/11/2017), Scanworld2020 (22/11/2017)
Vieux 17/11/2017, 19h32   #1334
Ghis13
Avatar de Ghis13
Exactement pourquoi il l’on changé je sais pas pourtant quand je rentre dans la direction sa me marque bien que le code et appris tout et nickel le seul défaut qui me sort sur la voiture c est circuit commande actuateur basse pression
Vieux 17/11/2017, 21h30   #1335
jah83
Avatar de jah83
Pouvoir de réputation: 245
Tu avait bien vu l état vierge avant ?
Ghis13 (17/11/2017), pouettedu76 (17/11/2017), tony60 (17/11/2017)
Fonctions cachées du Climatronic vw nany Systeme de climatisation 6 27/11/2014 22h06
fonctions digiprog3 TONY55 Tableau de bord (Dashboard) 3 16/09/2014 16h04
classement interfaces/softs/fonctions/marques Molil Electronique 4 28/07/2014 19h57
quels sont toutes les fonctions de l'abritus72 mustauto Outil de programmation 5 04/02/2013 12h50
Fuseau horaire GMT +1. Il est actuellement 10h22.
