Vieux 04/11/2015, 15h10   #91
Simple
Avatar de Simple
Pouvoir de réputation: 23
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Thanks Maitresox,
I am aware that the problem is not in the INI files, I can ******ly trace it!!. But I thought I will provide a "Simple" solution to everyone that they can perform themselves.
You will notice that I did not try to package the upgrade to v7.77.
I wanted to empower the members and share with them some knowledge. I do not do this for living, I do it for love, and I *******ly hope that people will enjoy the experience.
Regards, Simple.
Simple est déconnecté   Réponse avec citation
Vieux 04/11/2015, 15h57   #92
maitresox
Avatar de maitresox
Pouvoir de réputation: 69
maitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond repute
Envoyé par izi Voir le message
salut maitresox
je viens d'installer la mise à jour 7.74 to 7.76 avec ton patch Fr et a l'ouverture du soft j'ai deux erreurs soit (javascript) ou error (httd_ddc.exe)en fonction du demarrage de windows xp
as tu une idée voir meme une solution ??
Tu as mis les mises à jour qui sont dans le fichier txt (en ce moment) car j'ai fait des modifs cet apm ?
Tu as net framework 3.5 sur ton xp ?
Dernière modification par maitresox ; 04/11/2015 à 16h39.
maitresox est déconnecté   Réponse avec citation
Vieux 04/11/2015, 20h03   #93
maitresox
Avatar de maitresox
Salut IZI
Tu as LEXIA en Francais ?
Vieux 04/11/2015, 22h17   #94
manudiag
Avatar de manudiag
manudiag is just really nicemanudiag is just really nicemanudiag is just really nicemanudiag is just really nicemanudiag is just really nice
salut maitresox
merci pour ton super boulot , j ai installe tes mises a jour sur mon lenovo T420 sous Windows 10 32 bits , elle fonctionne super et lexia était en anglais , j ai installe ton patch et tous en rentre dans l ordre , il est de nouveau en FRANÇAIS
mille merci pour ton super travail
manudiag est déconnecté   Réponse avec citation
Vieux 05/11/2015, 12h06   #95
Simple
Avatar de Simple
Hi,
Language problem sorted....!!
Type de fichier : jpg DB9.jpg (46,6 Ko, 47 affichages)
Vieux 05/11/2015, 20h33   #96
work87
Avatar de work87
work87 is an unknown quantity at this point
Chez moi le patch ne marche pas, quand je double clic dessus il ne se passe rien !
J'ai pourtant bien .net framework 3.5
Que dois je faire ?
work87 est déconnecté   Réponse avec citation
Vieux 05/11/2015, 23h34   #97
maitresox
Avatar de maitresox
C'est normal. Il faut juste vérifier si LEXIA est passé en Francais
Vieux 06/11/2015, 14h23   #98
DIAGAUTO33
Avatar de DIAGAUTO33
DIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant futureDIAGAUTO33 has a brilliant future
Salut Maitresox,
Ton patch fonctionne parfaitement !
Lexia est en francais .
Merci pour tout.
DIAGAUTO33 est déconnecté   Réponse avec citation
Vieux 07/11/2015, 12h10   #99
tarmac
Avatar de tarmac
tarmac will become famous soon enough
Merci maitresox , tout fonctionnement parfaitement en 7.77 avec lexia en français :)
Juste un bug de langage sur les onglets documentation et rapport
tarmac est déconnecté   Réponse avec citation
Vieux 07/11/2015, 12h24   #100
maitresox
Avatar de maitresox
Perso mes Maj s'arrêtent à 7.76 !
Si tu as ID... soit tu as modifié ou essayé de modifier la langue dans certains fichiers ??
Essaie de ré-installer la dernière maj 7.76 si c'est toujours pareille après redémarrage du PC, il faudra ré-installer DIAGBOX
Maitresox
Dernière modification par maitresox ; 07/11/2015 à 13h32.
Vieux 07/11/2015, 13h39   #101
tarmac
Avatar de tarmac
je n'ai rien modifié, c'est apparu avec la mise à jour 7.76, ce n'est pas bien grave, car tout le reste fonctionne !
Vieux 09/11/2015, 08h31   #102
otrac79
Avatar de otrac79
otrac79 will become famous soon enough
salut les amis j'ai tout installé il reste en français jusqu'au 7.76 mais j'ai perdu l'activation du produit que dois je faire merci les gars
a+
otrac79 est déconnecté   Réponse avec citation
Vieux 09/11/2015, 18h28   #103
chaoui05
Avatar de chaoui05
Pouvoir de réputation: 80
Envoyé par otrac79 Voir le message
a+
Problème déjà abordé;lancer en administrateur
Vieux 18/11/2015, 01h30   #104
ecutech
Avatar de ecutech
ATTENTION LES UPDATE SONT AU TOP merci maitresox mais a partir de 7 76 plus de telecodage manuel possible sur 208 ET 308 RCZ ATTENTION UNIQUEMENT CONNEXION SERVEUX AUTO ,
Vieux 18/11/2015, 13h30   #105
mecano13
Avatar de mecano13
mecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud of
merci pour la mise a jour ses le top
mecano13 est déconnecté   Réponse avec citation
Mises à jour Diagbox 7.56 vers 7.57 et 7.01 vers 7.57 (updates OFFLINE) maitresox LEXIA, PP2000, DiagBox 9 29/11/2018 20h15
Mises à jour Diagbox 7.62 vers 7.66 (8.02) (updates OFFLINE) maitresox LEXIA, PP2000, DiagBox 104 28/02/2018 14h24
Mises à jour Diagbox 7.57 vers 7.58 et 7.58 vers 7.62 (updates OFFLINE) maitresox LEXIA, PP2000, DiagBox 59 25/08/2017 13h56
Mises à jour Diagbox 7.54 vers 7.55 et 7.44 vers 7.55 (updates OFFLINE) maitresox LEXIA, PP2000, DiagBox 1 22/11/2015 13h45
Mises à jour Diagbox 7.57 vers 7.61 (updates OFFLINE) maitresox LEXIA, PP2000, DiagBox 37 28/01/2015 21h37
Fuseau horaire GMT +1. Il est actuellement 20h01.
