Vieux 04/04/2017, 10h44   #871
kmtech
Avatar de kmtech
Pouvoir de réputation: 67
kmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond reputekmtech has a reputation beyond repute
Envoyé par gabigafu Voir le message
Probleme a resoudre, il y a des paires seed/key, j'ai besoin d'algo pour calculer la cle de debloquer l'ecu.
fichier
ReqSA1 et ReqSA2 ?
>> RocketDump << Logiciel Immo OFF/Immo vierge/Airbag reset/extraction code PIN, ...
kmtech est déconnecté   Réponse avec citation
Vieux 04/04/2017, 10h55   #872
gabigafu
Avatar de gabigafu
Pouvoir de réputation: 44
gabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond repute
oui, Security Access
gabigafu est déconnecté   Réponse avec citation
The Following User Says Thank You to gabigafu For This Useful Post:
freddy5923 (17/03/2018)
Vieux 05/04/2017, 11h54   #873
davycdz
Avatar de davycdz
davycdz has a spectacular aura aboutdavycdz has a spectacular aura aboutdavycdz has a spectacular aura about
Salut les amis, petit retour pour prog de clés sur Clio 3 ph 2 de mes parents ( à la base il fallait absolument une clé passé par Renault net pour l'affectation avec clip), effectué en moins de 3 min chrono !
Re merci gabi !
N'OUBLIEZ PAS LE PETIT BOUTON THANKS EN BAS À DROITE
davycdz est déconnecté   Réponse avec citation
The Following User Says Thank You to davycdz For This Useful Post:
barho67 (06/04/2018)
Vieux 06/04/2017, 20h38   #874
Topal
Avatar de Topal
Topal is a name known to allTopal is a name known to allTopal is a name known to allTopal is a name known to allTopal is a name known to allTopal is a name known to all
Salut, Gabi
comment faire pour utiliser Renolink avec le protocole ISO8 ?
car je me connecte mais c'est tout je ne peux rien faire d'autre
Pat
Topal est déconnecté   Réponse avec citation
Vieux 06/04/2017, 21h14   #875
gabigafu
Avatar de gabigafu
Protocole Iso8 n'est pas supporte par Renolink
Vieux 06/04/2017, 21h16   #876
tony60
Avatar de tony60
Pouvoir de réputation: 102
Voici les protocoles supporté
· Protocole OBD et OBD-II
· ISO15765-4 (CAN)
· ISO14230-4 (KWP2000)
· ISO9141-2
· J1850 VPW
· J1850 PWM
· Protocole de sortie USB
· Fréquences: 9600,19200 ou 38400
The Following 2 Users Say Thank You to tony60 For This Useful Post:
freddy5923 (17/03/2018), prinzo57 (06/04/2017)
Vieux 07/04/2017, 00h16   #877
Formator
Avatar de Formator
Pouvoir de réputation: 72
Envoyé par Topal Voir le message
Salut, Gabi
Pat
Si tu veux rentrer dans les anciens protocoles de diagnostic (ISO 8 - ISO9141-2 - ISO14230 (KWP2000 ou KW2000), avec un outil équivalent à RenoLink, tu peux utiliser une version de DDT2000 avec une sonde KKL (utilisée avec les anciens softs VAG.com 409.1)
Vieux 07/04/2017, 05h55   #878
Topal
Avatar de Topal
c'est dommage de ne pas pouvoir utiliser Renolink sur ce type de protocole !
je vais voir pour utiliser DDT2000 avec la sonde KKL comme tu me le dis Formator, mais a l'epoque ou j'avais deja voulu utiliser ce systeme, je n'y etais pas arriver
je vais tout reprendre a zero car si j'ai bien vu il y a avais des fichiers XML pour les uch de megane I et c'est tout a fait ce qu'il me faut
Pat
Vieux 07/04/2017, 18h21   #879
ECU diag
Avatar de ECU diag
Pouvoir de réputation: 65
Salut j'ai un problème avec renolink il trouve plus l'interface
Elle est bien reconnu par Windows mais pas renolink
Type de fichier : jpg image.jpg (16,0 Ko, 62 affichages)
Vieux 07/04/2017, 21h36   #880
Topal
Avatar de Topal
des fois ca m'arrive, je deconnecte le sonde et je relance Renolink et c'est bon
tu n'as pas suprimé ton fichier licence ?
sinon demande a Gabi
Pat
Vieux 07/04/2017, 21h48   #881
net_proo
Avatar de net_proo
net_proo is an unknown quantity at this point
il faut aller au répertoire au ce trouve le logiciel avec la clé dedans
net_proo est déconnecté   Réponse avec citation
Vieux 10/04/2017, 10h08   #882
gabigafu
Avatar de gabigafu
qui est dispo pour un boitier airbag megane3 avec crash pour faire des tests par teamviewer?
Vieux 10/04/2017, 11h53   #883
S-keys
Avatar de S-keys
Pouvoir de réputation: 141
gabigafu tu conte faire msj aprantiçage carte clio4 ?
Vieux 10/04/2017, 12h10   #884
gabigafu
Avatar de gabigafu
non pour le moment
Vieux 10/04/2017, 14h14   #885
tony60
Avatar de tony60
Salut tu va développer l apprentissage des carte megane 3
Merci pour le travail que tu accomplis
Fonctions cachées du Climatronic vw nany Systeme de climatisation 6 27/11/2014 22h06
fonctions digiprog3 TONY55 Tableau de bord (Dashboard) 3 16/09/2014 16h04
classement interfaces/softs/fonctions/marques Molil Electronique 4 28/07/2014 19h57
quels sont toutes les fonctions de l'abritus72 mustauto Outil de programmation 5 04/02/2013 12h50
Fuseau horaire GMT +1. Il est actuellement 01h27.
