Vieux 23/03/2017, 15h54   #811
gabigafu
Avatar de gabigafu
Pouvoir de réputation: 44
gabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond repute
merci a jah pour son aide
gabigafu est déconnecté   Réponse avec citation
Vieux 23/03/2017, 16h16   #812
vivi91r
Avatar de vivi91r
vivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant futurevivi91r has a brilliant future
Merci gabi
vivi91r est déconnecté   Réponse avec citation
Vieux 23/03/2017, 22h24   #813
kamel2003
Avatar de kamel2003
kamel2003 is on a distinguished road
Merci gabi
kamel2003 est déconnecté   Réponse avec citation
Vieux 24/03/2017, 08h39   #814
selouan
Avatar de selouan
Pouvoir de réputation: 26
selouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud ofselouan has much to be proud of
Salut les affaires reprennent pour toi gabi merci pour les mises à jour.
selouan est déconnecté   Réponse avec citation
Vieux 24/03/2017, 17h30   #815
nowen
Avatar de nowen
Pouvoir de réputation: 66
fonction copie et écriture du dump uch clio2 testé et tout est nickel, pas de resynchronisation à effectuer.
un vrai plug and play
The Following User Says Thank You to nowen For This Useful Post:
baccaraboss (25/08/2021)
Vieux 24/03/2017, 19h19   #816
fruky
Avatar de fruky
fruky is a name known to allfruky is a name known to allfruky is a name known to allfruky is a name known to allfruky is a name known to allfruky is a name known to all
super merci gabi
fruky est déconnecté   Réponse avec citation
Vieux 24/03/2017, 19h45   #817
jah83
Avatar de jah83
Pouvoir de réputation: 245
Juste au cas ou. Lors du test avec gabi j ai eu un Bus init error. Il a suffit de couper et remettre le +a pc pour que ca passe
Vieux 24/03/2017, 21h15   #818
yoyomartin2003
Avatar de yoyomartin2003
Bonsoir et merci Gabi.
Vieux 27/03/2017, 01h03   #819
davycdz
Avatar de davycdz
davycdz has a spectacular aura aboutdavycdz has a spectacular aura aboutdavycdz has a spectacular aura about
Génial ! La perfection gabigafu !
N'OUBLIEZ PAS LE PETIT BOUTON THANKS EN BAS À DROITE
davycdz est déconnecté   Réponse avec citation
Vieux 27/03/2017, 20h06   #820
gabigafu
Avatar de gabigafu
Qui s'offre demain pour quelques testes sur UCH Laguna2 phase2?
Vieux 27/03/2017, 20h31   #821
davycdz
Avatar de davycdz
Ail malheureusement je n'en ai pas, mais j'ai un espace 4 ph2 m9r en casse, il faut que je contrôle demain si il est pas trop dépouillé
Vieux 27/03/2017, 21h22   #822
jah83
Avatar de jah83
Desole je n ai que laguna 2 ph1...
Vieux 28/03/2017, 11h18   #823
davycdz
Avatar de davycdz
L'espace 4 est encore opérationnel
Vieux 28/03/2017, 20h53   #824
gabigafu
Avatar de gabigafu
Nouvelle mise a jour 1.39, lecture/ecriture eeprom Uch Laguna2, aussi phase 1 que phase 2, a tester ecriture eeprom. Aussi corriger apprentissage cartes pour Laguna2 ph2, https://mega.nz/#!TpsESS7S!iZY-4BWeX...tLdb6-HoLl3fE8
The Following 2 Users Say Thank You to gabigafu For This Useful Post:
barho67 (06/04/2018), freddy5923 (16/03/2018)
Vieux 28/03/2017, 20h56   #825
jah83
Avatar de jah83
J sais pas si tu as vu si tu veux j en ai une autre ou faut juste que je remette une batterie si tu veux tester pour l ecriture
Fonctions cachées du Climatronic vw nany Systeme de climatisation 6 27/11/2014 22h06
fonctions digiprog3 TONY55 Tableau de bord (Dashboard) 3 16/09/2014 16h04
classement interfaces/softs/fonctions/marques Molil Electronique 4 28/07/2014 19h57
quels sont toutes les fonctions de l'abritus72 mustauto Outil de programmation 5 04/02/2013 12h50
Fuseau horaire GMT +1. Il est actuellement 12h00.
