Vieux 15/11/2013, 22h01   #61
CSYSTEME
Avatar de CSYSTEME
CSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant futureCSYSTEME has a brilliant future
bonsoir
le soft evolue bien ,merci
demain ,tu met la mise a jour edc17
cordialement
The Following User Says Thank You to CSYSTEME For This Useful Post:
auto_ks (21/12/2013)
Vieux 15/11/2013, 22h09   #62
Amine-TE
Fondateur
Avatar de Amine-TE
Pouvoir de réputation: 1335
EDC17, oui pourquoi pas mais a ce moment là, que des modifs de fichier.
🚀 MOD-FILES.COM
The Following 3 Users Say Thank You to Amine-TE For This Useful Post:
auto_ks (21/12/2013), CSYSTEME (15/11/2013), Ecomouv (20/11/2013)
Vieux 17/11/2013, 06h52   #63
Ecomouv
Avatar de Ecomouv
Est-il possible de faire un immo off sur espace 2.2DCI de 2000 en edc15 et BII ?
Bien amicalement Ecomouv
Ecomouv est déconnecté   Réponse avec citation
Vieux 17/11/2013, 11h48   #64
Amine-TE
Fondateur
Avatar de Amine-TE
@Ecomouv
Peut être dans les prochaines mise à jour.
🚀 MOD-FILES.COM
The Following 2 Users Say Thank You to Amine-TE For This Useful Post:
auto_ks (21/12/2013), Ecomouv (17/11/2013)
Vieux 19/11/2013, 12h38   #65
nacerweb
Avatar de nacerweb
nacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud of
experience sur un edc15C2 jumpy 2L hdi 5p08c3 original 29F400 patcher le vehicule ne demarre pas antidemarrage toujour actif.
nacerweb est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to nacerweb For This Useful Post:
Amine-TE (19/11/2013), auto_ks (21/12/2013)
Vieux 19/11/2013, 12h53   #66
CSYSTEME
Avatar de CSYSTEME
nacerweb
tu peut mettre les dumps eeprom et flasch ,et si une broche ou 3
je ferais un test
j'ais un ecu aussi qui est rester en on
cordialement
The Following 3 Users Say Thank You to CSYSTEME For This Useful Post:
Amine-TE (19/11/2013), auto_ks (21/12/2013), nacerweb (19/11/2013)
Vieux 19/11/2013, 13h56   #67
Amine-TE
Fondateur
Avatar de Amine-TE
@nacerweb
tu peux envoyer le dump original(eprom et flash) ici ou par pm avec les info Hw et SW,
je vais voir cela.
🚀 MOD-FILES.COM
The Following User Says Thank You to Amine-TE For This Useful Post:
Vieux 19/11/2013, 17h21   #68
nacerweb
Avatar de nacerweb
Envoyé par CSYSTEME Voir le message
nacerweb
je ferais un test
cordialement
voici les dumps pass en mp
jumpy 2l hdi calculateur bosch 3broches reference :0281010591 HW:9643527180 SW:9640938680
Type de fichier : zip jumpy hdi 3broches.zip (389,5 Ko, 32 affichages)
Dernière modification par cedrsan ; 10/01/2014 à 15h52.
The Following User Says Thank You to nacerweb For This Useful Post:
Vieux 19/11/2013, 19h47   #69
Amine-TE
Fondateur
Avatar de Amine-TE
@nacerweb
je trouve sur ton pack aussi un fichier eprom off.
Est-ce que tu as fait le OFF que sur le flash ou aussi sur l'eprom?
Car avec le logiciel on peut faire que sur le flash sans toucher sur l'eprom.
tiens moi au courant pour te préparer un fichier dans le meuilleur temps.
🚀 MOD-FILES.COM
Vieux 19/11/2013, 21h08   #70
nacerweb
Avatar de nacerweb
en premier temp je l avait fait avec l eprom en off pas de demarrage je l est refait avec le dump original de l eprom meme resultat.
Vieux 19/11/2013, 21h11   #71
motard_21130
Avatar de motard_21130
motard_21130 is just really nicemotard_21130 is just really nicemotard_21130 is just really nicemotard_21130 is just really nice
Envoyé par nacerweb Voir le message
tu as remis leprom en ori du coup?
l tu as regarder au diag voir s'il y a pas une erreur du genre capteur pmh qui se cache par la?? lol
Ne pas avoir peur de rêver trop haut...
motard_21130 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to motard_21130 For This Useful Post:
Vieux 19/11/2013, 21h30   #72
nacerweb
Avatar de nacerweb
non ;au diag sa donne default antidemarrage j ai essayer le vehicule avec un ecu de 307 hdi que j ai mi en off avec otocheck le vehicule demarre au quart de tour.
auto_ks (21/12/2013), motard_21130 (19/11/2013)
Vieux 19/11/2013, 21h41   #73
motard_21130
remets la 5p08 en ori et flash la 29f400
Vieux 19/11/2013, 21h43   #74
Amine-TE
Fondateur
Avatar de Amine-TE
c'est étrange, essaye de mettre cet eprom 5P08 :)
Type de fichier : rar 5P08OFF eprom par amine.rar (339 octets, 64 affichages)
🚀 MOD-FILES.COM
Vieux 19/11/2013, 22h00   #75
nacerweb
Avatar de nacerweb
ok amine je te tien informé
Envoyé par motard_21130 Voir le message
c 'est ce que j ai fait ca demarre pas.
Dernière modification par cedrsan ; 30/01/2014 à 23h41.
Cartools V0.10 Beta (Update 07/08/2014) cedrsan Immobilizer dumps/solutions 18 17/08/2016 10h48
IMMOTOOL v5.05 dingo Outil de programmation 1 07/12/2013 22h53
Comment installer immotool Drogo Transponder, code pin 1 06/04/2013 02h18
Immotool 26.12.2007 Amine-TE Vente, Achat, Echange 0 27/02/2009 23h12
Fuseau horaire GMT +1. Il est actuellement 06h16.
