Vieux 11/12/2014, 09h08   #571
soustourou
Avatar de soustourou
soustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud ofsoustourou has much to be proud of
bonjour murat voici mon dump 307 merci d'avance
Type de fichier : rar peug307.rar (159,6 Ko, 21 affichages)
soustourou est déconnecté   Réponse avec citation
Vieux 11/12/2014, 10h51   #572
pif78
Avatar de pif78
Pouvoir de réputation: 22
pif78 is a splendid one to beholdpif78 is a splendid one to beholdpif78 is a splendid one to beholdpif78 is a splendid one to beholdpif78 is a splendid one to beholdpif78 is a splendid one to beholdpif78 is a splendid one to behold
Envoyé par SALASH1610 Voir le message
Salut,après éffacement de la BSI,je voudrais avoir le code pin a partir ECU BOSCH EDC15C2
EEPROM 5P08C3
peugeot 307 2L HDI 110CV 0281010779
MERCI
Salut salash,
Post ton dump que l'on te fournisse ton code ...
pif78 est déconnecté   Réponse avec citation
The Following User Says Thank You to pif78 For This Useful Post:
SALASH1610 (12/12/2014)
Vieux 11/12/2014, 13h14   #573
Nizar-maoukil
Avatar de Nizar-maoukil
Nizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud of
Smile eeprom dump
Envoyé par soustourou Voir le message
salut sous
t'as poster la flash
poste le dump d'eprom bsi ou ecu
pour avoir le code pin
reagrds
Mercedes esl repair programing and renew
bmw E90 and E60 esl off ( car runs without esl )
regards
Nizar-maoukil est déconnecté   Réponse avec citation
The Following User Says Thank You to Nizar-maoukil For This Useful Post:
diagprog (11/12/2014)
Vieux 12/12/2014, 00h39   #574
SALASH1610
Avatar de SALASH1610
SALASH1610 is a glorious beacon of lightSALASH1610 is a glorious beacon of lightSALASH1610 is a glorious beacon of lightSALASH1610 is a glorious beacon of lightSALASH1610 is a glorious beacon of lightSALASH1610 is a glorious beacon of light
Envoyé par pif78 Voir le message
Salut salash,
salut pif78
c'est résolu j'ai mis les fichiers d'un kit démarrage d'une autre voiture
SALASH1610 est déconnecté   Réponse avec citation
Vieux 12/01/2015, 11h49   #575
rayad
Avatar de rayad
rayad will become famous soon enoughrayad will become famous soon enough
je cherche le code pin pour megane UCH 82007800018A avec motorola 912 comme MCU ,mask4L91N
c joint le dump du 912 4l91n
merci beaucoup
Type de fichier : rar uch andry 4l91n.rar (74 octets, 9 affichages)
rayad est déconnecté   Réponse avec citation
Vieux 12/01/2015, 12h07   #576
pif78
Avatar de pif78
Envoyé par rayad Voir le message
merci beaucoup
salut rayad ,
le dossier est vide ?...
T as oublié de le mettre dedans avant de compresser le dossier
The Following 2 Users Say Thank You to pif78 For This Useful Post:
angels59 (12/01/2015), Nizar-maoukil (12/01/2015)
Vieux 12/01/2015, 13h50   #577
rayad
Avatar de rayad
ahhhhh!!!!!desolé ,voila
Type de fichier : rar uch 4l91n andry ambato 22megane.rar (831 octets, 22 affichages)
Vieux 12/01/2015, 14h33   #578
carspeed
Avatar de carspeed
carspeed is a splendid one to beholdcarspeed is a splendid one to beholdcarspeed is a splendid one to beholdcarspeed is a splendid one to beholdcarspeed is a splendid one to beholdcarspeed is a splendid one to behold
Salut l'ami
Votre
Pin code : C6 2D 37 4B FF 23
VIN : VF1LMREVF1...........
carspeed est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to carspeed For This Useful Post:
newcar (05/02/2015), rayad (13/01/2015)
Vieux 12/01/2015, 15h21   #579
aza
Avatar de aza
confirmation carspeed !
pin code : C6 2D 37 4B FF 23
vin : VF1LMREB17R.......
ISK code: CE D7 14 77 D8 4B
The Following User Says Thank You to aza For This Useful Post:
rayad (13/01/2015)
Vieux 12/01/2015, 15h45   #580
pif78
Avatar de pif78
C6 2D 37 4B FF 23 encore une confirmation lol
rayad (13/01/2015)
Vieux 12/01/2015, 16h31   #581
soustourou
Par défaut dump307 2002
salut murat voici dump 307 2002 merci d'avance
Type de fichier : rar 307 ORIG2.rar (171,4 Ko, 22 affichages)
On a souvent besoin d'un plus petit que soi
Vieux 13/01/2015, 08h14   #582
rayad
Avatar de rayad
merci les gars .......tres gentil
bonne chance a vous tous
thanks
Vieux 13/01/2015, 14h14   #583
Nizar-maoukil
Par défaut post the eprom
t'a poster la flasher;on a besoin du dump eeprom pour extrair le code pin
regards
Vieux 13/01/2015, 16h03   #584
aza
Avatar de aza
Envoyé par zakaria sahara Voir le message
hy why always erase my post pin code polo 2010
essai...:( 00286 ) zakaria
salutions
Vieux 18/01/2015, 19h49   #585
layerdiv
Avatar de layerdiv
layerdiv is on a distinguished road
Par défaut pincode for magneti marelli polo 1.4 16v 2001 iaw 4mv
hi
I have a polo 1.4 16v 2001 iaw 4mv eprom 95080
someone can give me the pin code of this file
thank you very much
Type de fichier : bin ori eeprom 95080 polo 1.4 16v.bin (1,0 Ko, 5 affichages)
layerdiv est déconnecté   Réponse avec citation
Code Pin depuis fichier .Bin Nelss Transponder, code pin 12 13/10/2026 08h32
Renault Pin depuis le Vin Nelss Transponder, code pin 9 22/06/2010 01h24
echange Renault Pin depuis le Vin par PSA pindepuisle vin moniros Vente, Achat, Echange 1 29/12/2009 18h45
Tachosoft mileage calculator 17.3 Free ( Gratuit ) Amine-TE Tableau de bord (Dashboard) 0 29/11/2008 23h00
Fuseau horaire GMT +1. Il est actuellement 20h28.
