Vieux 22/01/2025, 10h35   #31
nicokartcross
Avatar de nicokartcross
Pouvoir de réputation: 8
nicokartcross will become famous soon enoughnicokartcross will become famous soon enough
Slt
essaye ce lien : mega.nz/folder/jjg3kCYC#ZpmTmmQ-Rnr9XTqIjYJDNw
video de l instal ici : youtube.com/watch?v=Cbhq0Vlpc2A
C est du 32bits .
cdt
nicokartcross est déconnecté   Réponse avec citation
Vieux 11/04/2026, 14h05   #32
Ralphe62
Avatar de Ralphe62
Ralphe62 has a little shameless behaviour in the past
Envoyé par Roturbo Voir le message
Hello.
New link and pass.
Regards
Bonjour, Je viens de m'inscrire en tant que donateur, mais le lien n'est plus valable. En exite-t-il un nouveau ?
---------- Post added at 13h05 ---------- Previous post was at 12h56 ----------
64bit drivers for Actia Passthru+ XS (1 gen yellow & blue interface).
Maybe the first release on the World Wide Web, the old VC1 from Actia
IS working as J2534 on 64bit Windows 7. :wink:
You are the only one to blame if something goes wrong, so first make backup of important data,
or test this instructions first inside a Virtual Machine or any testing PC.
Remember, i don´t have responsibility of any kind, any problem you solve it,
i have test it and it works, and it is free for you to test,, only IF YOU WANT.
Instructions (please follow the more detailed installation inside RAR file)..
No need to disable Anti_Virus, and i strong advise you to do a virus scan on this folder.
This modified drivers are only to work as PassThru under 64bit,
it will not work with Actia Multidiag software, because the interface
is not recognized, for Multi-Diag Actia-Connect use a 32bit OS.
1º install --I+ME-Actia-PassThru-XS-Driverpack-xx1--
2º install --I+ME-Actia-PassThru-XS-Driverpack-xx2--
Go to device manager and chose update drivers for Passthru+ XS,
chose ""Browse my computer for driver software""
Than click "NEXT" it will give you driver warning, press "Yes",,
it will open a red windows security about the publisher, just
click ""Install this driver software anyway""
It will confirm Updated Driver software success, next remove power from
the interface, power it up again, if asking again for drivers just repeat
one more time the process,, if you see the serial number on the driver name ,
power down, power up install driver,and is done.
If this software "I+ME-Actia-PassThru-XS-Driverpack-xx1" is not installed than
your interface will not be listed as a PassThru interface, so you must install it.
This way you will have the 1Gen interface (blue & yellow) listed as available
for any software working with passthru (under 64bit), just select it and start working.
Tested several times in Windows 7 64bit, communication confirmed with
Forscan, Xentry, etc.
Probably there is easy ways to do the same, but this was the fastest i have
discovered by myself, and works without problems.
Also i have Vas5054 working on 64Bit, but is on testing, the xentry
picture show it listed on the available Passthru interfaces (last picture).
You can download the Pictures-mega-link if this ones vanish (no pass),
for the Mega-link.rar PASSWORD you need to follow the next instructions.
First you press and than ,, next send PM with title
-64bit drivers for Actia Passthru+ XS-password-
And you will get BY PM the password for Megalink.
DO NOT ASK THE PASSWORD ON THE BOARD.
Password Pm= Thanks+Rep
ROTURBO.
Merci à vous pour le partage
Ralphe62 est déconnecté   Réponse avec citation
ACTIA XS PassThru+ original Shadows93 Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 17 07/05/2018 18h33
Probleme de driver ACTIA 2016 sous win 7 mindouza Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 17 01/05/2018 05h54
[BDM100] Drivers W7 64bit zouk86 Programmateur de composant (flasher) 0 01/10/2017 10h09
winols en 64bit luce46M57 Logiciel & autres documentations général 3 08/10/2014 13h38
driver actia multidiag 2010 bebert97490 Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 7 16/09/2014 14h51
Fuseau horaire GMT +1. Il est actuellement 08h15.
