Vieux 26/02/2016, 14h02   #31
yvespapou
Avatar de yvespapou
yvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond reputeyvespapou has a reputation beyond repute
Pour pas polluer le post un minimum d explication quand tu change la façon des mises a jours au départ tu envoyer 2 fichiers maintenant plus 1 si tu avait pris le temps de m expliquer je ne serai pas passer pour un con devant mon client merci
yvespapou est déconnecté   Réponse avec citation
Vieux 26/02/2016, 14h05   #32
gabigafu
Avatar de gabigafu
Pouvoir de réputation: 44
gabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond repute
excuse-moi, quand je ferai des mises a jour je vais t'expliquer
gabigafu est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to gabigafu For This Useful Post:
baccaraboss (25/08/2021), mecano41 (26/01/2019), toutougsmserver (26/11/2019)
Vieux 26/02/2016, 14h12   #33
yvespapou
Avatar de yvespapou
Merci pas de problème je reconnais avant tout que ton logiciel est très très bon merci encore à toi
Vieux 26/02/2016, 15h49   #34
lemoutelerouge
Avatar de lemoutelerouge
lemoutelerouge is a jewel in the roughlemoutelerouge is a jewel in the roughlemoutelerouge is a jewel in the roughlemoutelerouge is a jewel in the rough
bonjour a tous,
tous d'abord merci a gabi pour son assiduité à faire évolué se soft.
le retour sur investissement est très rapide, et la prise en main et assez facile malgré que je ne parle pas la langue de shakespeare.
"dommage que l'on n'ai pas d'équivalent pour les autres marques automobiles."
maintenant j'aimerai savoir si il est possible de faire évolué se soft sur des models comme kaleos?
lemoutelerouge est déconnecté   Réponse avec citation
Vieux 26/02/2016, 17h05   #35
yvespapou
Avatar de yvespapou
salut pour le codage de carte megane2 quel carte ont peux coder chinoise??? renault original????????? ou occasion????????????? merci
Vieux 26/02/2016, 17h14   #36
gabigafu
Avatar de gabigafu
il faut tout d'abord etre neuve, tu peux prendre une d'occasion et remplacer le chip, il faut que le chip soit prepare pour Renault
The Following User Says Thank You to gabigafu For This Useful Post:
Vieux 26/02/2016, 17h14   #37
pouettedu76
Avatar de pouettedu76
Pouvoir de réputation: 77
Envoyé par yvespapou Voir le message
Toutes sauf les occasion tant qu"ils sont vierge et prete a etre programmer ils vont marcher chinoise tester 3 fois avec clip et 1 fois avec Renolink et sa passe tous seule bonne fin de journée @+
Vieux 26/02/2016, 17h21   #38
Tidus97
Avatar de Tidus97
Pouvoir de réputation: 37
bonjour à tous! Juste une petite question, peut être certains l'ont déjà posé, est ce que l'application de gabi fait les mêmes choses que renault ecu tools? Pour la dae clio4, j'ai déjà la réponse, mais pour le reste. Merci
Vieux 26/02/2016, 17h24   #39
gabigafu
Avatar de gabigafu
En ce qui concerne les dae, oui. Efface le code immo des dae Clio3 et Megane3
Vieux 26/02/2016, 18h26   #40
yvespapou
Avatar de yvespapou
Envoyé par gabigafu Voir le message
si vous monter une dae apres avoir fait la manipulation pour l'immo de changer le vf manuellement avec renolink
Vieux 26/02/2016, 18h50   #41
pouettedu76
Bonsoir Yvespapou juste une question :
Sans changer le vf manuellement avec renolink la voiture ne demarra pas ? c'est bien sa ?
Et comment sa se passe il faut mettre celle d'ocasion puis la mettre vierge puis ensuite renommer le vf ? merci pour ta reponce d'avance
Je pose cette question comme je ne l'ai pas encore fait merci de votre comprehension
Vieux 26/02/2016, 18h57   #42
nastradini
Avatar de nastradini
nastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud ofnastradini has much to be proud of
aujourd'hui j'ai finalement acheté obd link sx,,,
Je crois que pour quelques jours devrait venir,,,
Je peux être une partie des utilisateurs de ce merveilleux programme
nastradini est déconnecté   Réponse avec citation
The Following User Says Thank You to nastradini For This Useful Post:
Vieux 26/02/2016, 19h07   #43
yvespapou
Avatar de yvespapou
non elle démarre sa ne gène pas alors tu branche celle d'occasion tu fait l'immo ensuite pour être sur tu débranche la batterie puis tu rebranche si elle démarre c'est bon l'immo a marché tu n'est pas obligé de changer le vf mais pour finir proprement ton travail tu va tu va dans dae avec renolink ensuite tu clic sur la voiture en haut de renolink pour lire et écrire le vf et tu suis la procédure
The Following User Says Thank You to yvespapou For This Useful Post:
Vieux 26/02/2016, 21h42   #44
mecanodiag93
Avatar de mecanodiag93
mecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant futuremecanodiag93 has a brilliant future
Moi je suis trés satisfait du RenOLinK
Nos amis pouette , gabi ils s'assure
Merci a vous tous
J'espère que les mise a jours ne cesserons pas
Note du soft : 9/10
Gabi : 10/10
Pouette 10/10
Envoyé de mon iPhone à l'aide de Tapatalk
ne fais pas à autrui ce que tu n'aimerais pas qu'on te fasse !!
mecanodiag93 est déconnecté   Réponse avec citation
The Following User Says Thank You to mecanodiag93 For This Useful Post:
Vieux 27/02/2016, 01h33   #45
stephane
Avatar de stephane
Pouvoir de réputation: 121
Héeee les gars vous êtes sérieux .......ont est en 2016 ....j entend parler que de megane2 ...laguna2 .. et pourquoi pas tractions av pendant qu ont y est....
Aidé gabigafu a développé sons logiciels pas a l enterrer
HO !!!!! Ont ais a l époque des megane3 voir 4 senic3 laguna3
Je vous rappelle que renault net nous baises sur c est véhicule aucun intérêt de travailler sur des véhicules aussi vieux .
Desolé de pété un câble ,d ailleur que je n ais pas ,mais ca me rend fout ce gaspillages de temps et d énergies pour un résultat aussi médiocre
Quelle dommage de gaspiller les talents de gabigafu
Ps : gabigafu tu pass sur du clio4 cool tu redessant sur du compteur de senic2.......heuuu qu'elle intérêt sachant que si tu le remplace c est fatalement parce que tu las réparé a ce moment las tu en as pour 5 mi utes pour reprogrammer l eprom !!! Donc pas d intérêt
De plus peut tu refaire les configurations système du compteur ? Via obd
ABS , LA LANGUE ,SURVEILLANCE DES PNEUS ,L ÉNERGIE ESS OU GO ......ECT...
Même si tu les prépare a l avance tu as une chance sur 7 de tombé sur las bonne configuration
Bon courage les gars..................... :0(
Stephane
The Following 4 Users Say Thank You to stephane For This Useful Post:
baccaraboss (25/08/2021), Jimbo (18/09/2018), taxi5114 (25/11/2016), tdipower11 (26/08/2017)
Fonctions cachées du Climatronic vw nany Systeme de climatisation 6 27/11/2014 22h06
fonctions digiprog3 TONY55 Tableau de bord (Dashboard) 3 16/09/2014 16h04
classement interfaces/softs/fonctions/marques Molil Electronique 4 28/07/2014 19h57
quels sont toutes les fonctions de l'abritus72 mustauto Outil de programmation 5 04/02/2013 12h50
Fuseau horaire GMT +1. Il est actuellement 21h59.
