#331 |
![]() Date d'inscription: février 2017
Pouvoir de réputation: 13 ![]() ![]() ![]() ![]() |
Dump Peugeot 3008 Blue hdi Bosch Edc17c60 (flash + eeprom )
Lecture AMT Bst Bench ********** ECU INFO ********** ECU: EDC17C60 SW: 1037548644 SW: 1037551118 ********** ********** ********** |
| The Following 2 Users Say Thank You to progautofiles For This Useful Post: | Fastdiag (29/04/2025), mahfoud lichani (24/03/2025) |
#332 |
tiens j'ai ça en full bdm
| The Following 3 Users Say Thank You to progautofiles For This Useful Post: |
#333 |
Dump Audi A4 B8 2.0 Tdi 143 cv Bosch Edc17cp14 (flash + eeprom)
Lecture AMT Bst Bench ********** ECU INFO ********** ECU: EDC17CP14 SW: 1037396484 SW: 1037392984 ********** ********** ********** |
#334 |
Dump Peugeot Bipper 1.4 Hdi Bosch edc16c34
Lecture AMT Bst Bench ********** ECU INFO ********** ECU: EDC16C34 SW: 1037386092 ********** ********** ********** |
| The Following User Says Thank You to progautofiles For This Useful Post: | Fastdiag (29/04/2025) |
#335 |
Peugeot Partner Bosch md1cs003
Lecture AMT Bst Bench ********** ECU INFO ********** SW: 10SW041331 SW: 10SW095287 ********** ********** ********** |
#336 |
Bonjour je mets a disposition le dump de mon véhicule dumper avec Kt200 v2
Driver: VOLKSWAGEN TC1796 - VAG EDC17 CP14 |
| The Following 3 Users Say Thank You to Mekkiveli For This Useful Post: |
#337 |
Driver:
VOLKSWAGEN TIGUAN -5N1- 2.0 TDI 110/140CV EDC17C46 *CAN DFOX Data: R4 2.0l TDI 12.02.10 EV_ECM20TDI01103L90601 WVGZZZ5NZAW085315 03L906018CD EDC17C46 9977 H20 |
| The Following 2 Users Say Thank You to Mekkiveli For This Useful Post: | Fastdiag (29/04/2025), mahfoud lichani (12/04/2025) |
#338 |
Bonjour, dump fait au Ktag d'un Ford C-Max 1.6 CDTI, calculateur EDC16C3.
| The Following 2 Users Say Thank You to Armagedon For This Useful Post: | Fastdiag (29/04/2025), mahfoud lichani (12/04/2025) |
#339 |
sur un 206 hdi 1.4l lu en bdm avec ktag
| The Following User Says Thank You to Tarek meca For This Useful Post: | Fastdiag (29/04/2025) |
#340 |
en fichiers séparés
#341 |
Pouvoir de réputation: 19 ![]() ![]() ![]() ![]() |
je cherche une flash ori pour une logan 1.5dci dcm1.2 85cv avec éléctrovanne turbo
année 2008
jedes Problem hat eine Lösung. |
#342 |
je n'ai que l'eeprom mais si ca peut servir
038 906 019 ns - 0984 - edc15+ et le fichier immo off aussi Merci |
#343 |
#344 |
Banned
VOICI UN ORI KESS V2 D'UNE 307 2L 110CV PH1 5P DECEMBRE 2000.
Google Drive: Sign-in BONNE REPROG A TOUS LOLO69423 |
#345 |
Je Vs partage le fichier full "PCM FLASH" d´une Golf VI GTD a boite automatique_1037561508
| The Following User Says Thank You to MadDiagSp For This Useful Post: | mahfoud lichani (19/06/2026) |
