Vieux 15/10/2018, 19h12   #16
bounechada abdel
Avatar de bounechada abdel
bounechada abdel will become famous soon enough
tu as verifier si ta poulie arbre a came est identique a l ancienne
bounechada abdel est déconnecté   Réponse avec citation
The Following User Says Thank You to bounechada abdel For This Useful Post:
nono93 (16/10/2018)
Vieux 15/10/2018, 19h51   #17
ducla
Avatar de ducla
ducla is just really niceducla is just really niceducla is just really niceducla is just really nice
As tu contrôlé toutes les masses du faisceau?
ducla est déconnecté   Réponse avec citation
The Following User Says Thank You to ducla For This Useful Post:
nono93 (16/10/2018)
Vieux 15/10/2018, 19h53   #18
RALPH
Avatar de RALPH
RALPH has much to be proud ofRALPH has much to be proud ofRALPH has much to be proud ofRALPH has much to be proud ofRALPH has much to be proud ofRALPH has much to be proud ofRALPH has much to be proud ofRALPH has much to be proud of
contrôle a l oscillo ton PMH et CAMES.
tu a rebrancher le débitmètre donc tu a un default en moins ?
RALPH est déconnecté   Réponse avec citation
The Following User Says Thank You to RALPH For This Useful Post:
nono93 (16/10/2018)
Vieux 15/10/2018, 23h10   #19
sadna
Avatar de sadna
Pouvoir de réputation: 36
est ce qu'il y a du carburant dans le reservoir ? :^\
te reste a tester une masse sur le calculateur.
nono93 (16/10/2018)
Vieux 16/10/2018, 03h50   #20
rapou30
Avatar de rapou30
rapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud ofrapou30 has much to be proud of
Bonsoir, verifiez que la cible derriere la poulie de vilebrequin est identique a l'origine et que le reglage est conforme.
Le piment c'est comme l'autoroute , ca se paye a la sortie
rapou30 est déconnecté   Réponse avec citation
The Following User Says Thank You to rapou30 For This Useful Post:
nono93 (16/10/2018)
Vieux 16/10/2018, 07h56   #21
nono93
Avatar de nono93
nono93 is a jewel in the roughnono93 is a jewel in the roughnono93 is a jewel in the roughnono93 is a jewel in the rough
Slt l ami tu et sure qui a la synchro tu n'a aucun paramètre en temp réel avec les 2 calculateur les default sont identique..
Ps sur les 1.4 psa et bosch et siemens y a jamais eu de pompe de gavage..
Oui je suis sur mais comme j'ai dit le 2em calculateur je n'est pas adapter ecu juste branche comme sa
---------- Post added at 07h48 ---------- Previous post was at 07h46 ----------
Envoyé par sl60 Voir le message
hello
il faut que tu règle ton problème de synchro si tu n'a pas les trs/mm tu na pas de pmh donc pas de démarrage quid de la cible si tu est sur de ton calage et de ta distri
Oui sur pour le calage de la distribution
---------- Post added at 07h50 ---------- Previous post was at 07h48 ----------
Envoyé par bounechada abdel Voir le message
Ont m'avais déja parler de la poulie arbre a came j'ai regarder celle de l'ancien et tu nouveau et d'un autre il sont tous les trois identiques
---------- Post added at 07h53 ---------- Previous post was at 07h50 ----------
Envoyé par ducla Voir le message
Oui j'ai vérifier les masses et j'ai également brancher avec des câble de démarrage le calculo a la masse de la voiture
---------- Post added at 07h54 ---------- Previous post was at 07h53 ----------
Envoyé par rapou30 Voir le message
De quel réglage tu parle ?
---------- Post added at 07h56 ---------- Previous post was at 07h54 ----------
Envoyé par RALPH Voir le message
Non le debitmetre es toujours débrancher tout comme le ventilateur et les cardans
nono93 est déconnecté   Réponse avec citation
Vieux 16/10/2018, 08h08   #22
RALPH
Avatar de RALPH
rebranche est voit, puis fait le reste si tu a un oscillo
nono93 (16/10/2018)
Vieux 16/10/2018, 08h12   #23
nono93
Avatar de nono93
Non je n'est pas oscilo
Vieux 16/10/2018, 08h40   #24
Jcm05
Avatar de Jcm05
Jcm05 is on a distinguished road
Je m'écarte peut être un peu du sujet mais pour avoir eu les mêmes symptômes sur le même moteur et avoir galéré pas mal je vous fais part de mon expérience.
Dans mon cas c'était le boitier de papillon d'air qui était HS, aucun défaut au diag mais l'air ne rentrait pas pas dans le moteur et donc pas de démarrage.
Le débit d'air à la diagbox doit être supérieur à 250mg/l.
A vérifier, il suffit de le manœuvrer manuellement en position ouverture et de le débrancher. Le mien se fermait mais ne s'ouvrait pas.
Jcm05 est déconnecté   Réponse avec citation
Vieux 16/10/2018, 11h19   #25
sadna
Avatar de sadna
Envoyé par Jcm05 Voir le message
tu parles de quel voiture ?
y a pas de boitier papillon sur hdi.
nono93 (16/10/2018)
Vieux 19/10/2018, 20h44   #26
mindouza
Avatar de mindouza
mindouza is a name known to allmindouza is a name known to allmindouza is a name known to allmindouza is a name known to allmindouza is a name known to allmindouza is a name known to all
regarde d’abords ton calage et puis la pression de gasoil.
n'applaudissez jamais a l'injustice humaine
mindouza est déconnecté   Réponse avec citation
Vieux 20/10/2018, 11h48   #27
crucial performance
Avatar de crucial performance
crucial performance is on a distinguished road
que disent les mesure paramètre , regarde t'es paramètres en temps réel stp
si tu n'as pas de synchro pas de démarrage !!!
crucial performance est déconnecté   Réponse avec citation
Vieux 20/10/2018, 12h02   #28
zefirin
Avatar de zefirin
zefirin is a name known to allzefirin is a name known to allzefirin is a name known to allzefirin is a name known to allzefirin is a name known to allzefirin is a name known to all
Lorsque tu actionnes la poire, le carburant arrive t il ?
Les flexibles à carburant sont ils d'origine ?
Qu'en est il du filtre à gazole ?
zefirin est déconnecté   Réponse avec citation
Vieux 27/10/2018, 19h20   #29
Fougerit
Avatar de Fougerit
Fougerit is on a distinguished road
Bonjour, déjà appaire ton calculateur moteur avec la BSI et les clef histoire d'avoir ton antidémarrage en état de marche! Ensuite contrôle ton capteur de régime moteur au niveau de la poulie de vilo car en remplaçant le moteur il est possible qu'il est prit un mauvais coup ou alors le faisceau abimé.
Vérifie bien ton capteur d'arbre à cames également.
Dans tout les cas si tu na pas de synchro moteur il ne démarrera jamais.
Sur certain 1.4HDI il y a bien un papillon sur le dessus du moteur pour favorisé le recyclage des gaz d'échappement.
Fougerit est déconnecté   Réponse avec citation
demarrage HDI fredb70 PSA Group Peugeot, Citroën 173 07/05/2017 10h28
207 1.4 hdi pb demarrage zaouibachir PSA Group Peugeot, Citroën 3 06/04/2017 03h40
Pas de démarrage après changement kit démarrage hadil Fiat, Alfaromeo, Lancia, Ferrari 17 06/07/2016 20h29
bmw demarrage zaouibachir BMW, Mini, Rolls-Royce 2 08/03/2014 16h29
kit demarrage 508 hdi beonce Vente, Achat, Echange 2 09/09/2012 13h17
Fuseau horaire GMT +1. Il est actuellement 16h59.
