Vieux 08/06/2014, 22h33   #16
Nizar-maoukil
Avatar de Nizar-maoukil
Nizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud of
winols peut recalculer le checksum
les outile de flashage paut aussi recalculer les cheksums pendant l'ecriture comme fgtech kesse
dans le cas ou le chek et NOK il faut le recalculer
regards
Mercedes esl repair programing and renew
bmw E90 and E60 esl off ( car runs without esl )
regards
Nizar-maoukil est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Nizar-maoukil For This Useful Post:
jeanalitre (15/11/2018), rahmani2008 (08/06/2014)
Vieux 08/06/2014, 23h11   #17
rahmani2008
Avatar de rahmani2008
rahmani2008 is a jewel in the roughrahmani2008 is a jewel in the roughrahmani2008 is a jewel in the roughrahmani2008 is a jewel in the rough
Envoyé par Nizar-maoukil Voir le message
regards
salut et merci pour la reponse
dans le cas ou le chek et NOK il faut le recalculer " d'accord mais comment???.
rahmani2008 est déconnecté   Réponse avec citation
Vieux 09/06/2014, 02h04   #18
Nizar-maoukil
salur rahmani
voici comment coriger le checksum avec winols
Correcting checksums is very easy because this is often done by additional plug-ins. These must be purchased separately but for this they also do all the work needed automatically.
Start the checksum dialog with the menu item "Edit" / "Checksum" (Hotkey F2). Click on "Search". If you own the right checksum module, it will automatically be applied and the checksum will be calculated and (if you want that) always be corrected.
If you do not have the matching module, you can let EVC check your project for free and without any commitments. Click on "Search checksum online". The project will be compressed and uploaded to the EVC server (Internet connection required). A few seconds later you will receive an answer, telling you which checksum module will work for your data.
Important: Some checksum modules require an unmodified original version. That means, that you must have loaded the original data from the car as original version into the WinOLS project. Otherwise it may happen that the checksum is not recognized or not calculated correctly.
best regards
regards
The Following 5 Users Say Thank You to Nizar-maoukil For This Useful Post:
hugo431 (30/06/2014), jeanalitre (15/11/2018), lenoob (16/06/2014), MOURAD SPCMAX (09/06/2014), pp08 (21/12/2020)
demande explication boot mode tony2552 Pinout calculateurs et bootmode 7 10/01/2014 09h27
video d'explication fap prodlt Tutoriels 0 25/12/2013 00h54
explication esi tronic 2013Q2 ucforstill Autocom, Delphi, Actia, Bosch, SPC, BrainBee, Autel 6 29/11/2013 12h24
Winols explication suite selouan Chiptuning 11 22/09/2013 16h45
winols explication selouan Chiptuning 2 21/05/2013 11h35
Fuseau horaire GMT +1. Il est actuellement 19h37.
