Vieux 01/12/2013, 13h41   #16
shaft
Avatar de shaft
shaft will become famous soon enough
Par défaut yes!
yes, yes man with AC
shaft est déconnecté   Réponse avec citation
The Following User Says Thank You to shaft For This Useful Post:
juju64 (01/12/2013)
Vieux 01/12/2013, 13h44   #17
juju64
Avatar de juju64
Pouvoir de réputation: 22
juju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to beholdjuju64 is a splendid one to behold
It´s the same of scenic ?
juju64 est déconnecté   Réponse avec citation
Vieux 01/12/2013, 13h47   #18
h'mida13
Avatar de h'mida13
h'mida13 is a jewel in the roughh'mida13 is a jewel in the roughh'mida13 is a jewel in the roughh'mida13 is a jewel in the rough
avec un emulateur c'est plus simple non??
h'mida13 est déconnecté   Réponse avec citation
The Following User Says Thank You to h'mida13 For This Useful Post:
foulques (01/12/2013)
Vieux 01/12/2013, 13h51   #19
shaft
Avatar de shaft
idid not understand explained more?
Vieux 01/12/2013, 14h57   #20
foulques
Avatar de foulques
foulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud offoulques has much to be proud of
j'essai cette semaine et vous tiens au courant,la methode avec l'emulateur est elle plus compliquée?
foulques est déconnecté   Réponse avec citation
Vieux 01/12/2013, 15h04   #21
smt
Avatar de smt
smt is just really nicesmt is just really nicesmt is just really nicesmt is just really nicesmt is just really nice
poste ton dump j te ferais un off dapres le dump ori
smt est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to smt For This Useful Post:
foulques (01/12/2013), reda75 (02/12/2013)
Vieux 01/12/2013, 15h38   #22
nacerweb
Avatar de nacerweb
nacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud ofnacerweb has much to be proud of
en utilisant un emulateur on a un resultat 100% ok ,cette semaine j 'ai demarrer 3 vehicules ecu sirius32 ça marche impeccable.
nacerweb est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to nacerweb For This Useful Post:
foulques (01/12/2013), juju64 (01/12/2013)
Vieux 01/12/2013, 16h10   #23
smt
Avatar de smt
G une solution 100% ok est tester sans mettre un emulateur et tout les options reste en marche(clim)
The Following 3 Users Say Thank You to smt For This Useful Post:
fk67 (17/11/2023), foulques (01/12/2013), juju64 (01/12/2013)
Vieux 01/12/2013, 16h26   #24
foulques
Avatar de foulques
il faut un emulateur apres l'immo off je suppose
Vieux 01/12/2013, 16h28   #25
juju64
Avatar de juju64
salut nacerweb tu procède comment pour l'émulateur, tu coupe la ligne immo et tu l'installe ou il faut modifier aussi le dump ?
Vieux 01/12/2013, 16h40   #26
smt
Avatar de smt
lisez bien mon poste(solution sans emulateur)
Vieux 01/12/2013, 21h08   #27
nacerweb
Avatar de nacerweb
Envoyé par juju64 Voir le message
biensur si tu installe un emulateur il faut bien modifier le flash
foulques (02/12/2013), juju64 (01/12/2013)
Vieux 03/12/2013, 22h37   #28
SOTISEN
Avatar de SOTISEN
SOTISEN will become famous soon enoughSOTISEN will become famous soon enough
hello l ami teste ce dump c est supert off tester par moi 100 pour 100 offf
le voila votre dump off teste
Type de fichier : rar sirus32_unlock tested work.rar (91,6 Ko, 84 affichages)
Dernière modification par cedrsan ; 04/02/2014 à 10h37.
SOTISEN est déconnecté   Réponse avec citation
The Following User Says Thank You to SOTISEN For This Useful Post:
foulques (04/12/2013)
Vieux 04/02/2014, 23h23   #29
cedmtech
Avatar de cedmtech
cedmtech will become famous soon enough
salut a tous
j'ai vu qu'il fallait schunter le pin 23 et 43
et ne pas souder la 43 j'aurai voulu savoir pourquoi
est il necesaire de le faire
car mon probleme c'est qu'a chaque fois que je soude l'eprom
et que je monte le calculo l'auto tourne mais apres quelque minutes elle s'arrete
et plus moyen de la redemarrer.
merci pour vos reponses.
cedmtech est déconnecté   Réponse avec citation
Vieux 05/02/2014, 12h56   #30
salut tu doit avoir autre chose, l'immo n'éteint pas le moteur !
immo off sirius 32 damien1234 Immobilizer dumps/solutions 12 12/12/2015 19h13
Sirius 32 immo off julien74 Immobilizer dumps/solutions 2 08/07/2013 10h16
Immo Off Sirius 23 jeronimo Immobilizer dumps/solutions 6 17/04/2013 21h50
immo off sirius 32 raptor Immobilizer dumps/solutions 16 13/03/2013 16h23
Fuseau horaire GMT +1. Il est actuellement 14h59.
