Vieux 05/03/2019, 12h15   #2656
gabigafu
Avatar de gabigafu
Pouvoir de réputation: 44
gabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond reputegabigafu has a reputation beyond repute
Voir les boitiers ecm et tableau de bord.
gabigafu est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to gabigafu For This Useful Post:
autodiagauto (05/03/2019), klif26 (05/03/2019), Pelican (05/03/2019), revo (05/03/2019), roilion007 (06/03/2019)
Vieux 05/03/2019, 23h34   #2657
FETEK
Avatar de FETEK
FETEK has a spectacular aura aboutFETEK has a spectacular aura aboutFETEK has a spectacular aura about
Bon retour Gaby. Je savais que tu reviendrais. Ça devait te demanger toutes ces renaults en panne sur le bord de la route.....
FETEK est déconnecté   Réponse avec citation
Vieux 05/03/2019, 23h47   #2658
stephane
Avatar de stephane
Pouvoir de réputation: 121
Salutations Julien tu vas dans tableau de bord » config général 1 » start and stop et tu choisi without SSCU
The Following 12 Users Say Thank You to stephane For This Useful Post:
electronico (06/03/2019), fenril68 (06/03/2019), jah83 (06/03/2019), kilm (03/04/2021), komorovskij (06/03/2019), oran13 (05/03/2019), Pelican (06/03/2019), prinzo57 (06/03/2019), roilion007 (06/03/2019), vv58 (06/03/2019), Y.B tec (06/03/2019), youcef_trik (06/03/2019)
Vieux 06/03/2019, 07h00   #2659
jah83
Avatar de jah83
Pouvoir de réputation: 245
Ça a le mérite d être précis !
stephane (06/03/2019)
Vieux 06/03/2019, 09h26   #2660
stephane
Avatar de stephane
Ont essaie jha ....ont essaie .....
The Following User Says Thank You to stephane For This Useful Post:
jah83 (06/03/2019)
Vieux 06/03/2019, 09h41   #2661
roilion007
Avatar de roilion007
roilion007 has much to be proud ofroilion007 has much to be proud ofroilion007 has much to be proud ofroilion007 has much to be proud ofroilion007 has much to be proud ofroilion007 has much to be proud ofroilion007 has much to be proud ofroilion007 has much to be proud ofroilion007 has much to be proud of
Smile Rpe3
Salem
Bon retour monsieur gabigafu
Et cette fois tu seras très fort
roilion007 est connecté maintenant   Réponse avec citation
The Following User Says Thank You to roilion007 For This Useful Post:
gabigafu (06/03/2019)
Vieux 06/03/2019, 18h38   #2662
bkprog13
Avatar de bkprog13
aujourd’hui sur clio 2 impossible de faire une clé, avec la versio 1.49 j’arrive a me connecter et avoir pin et isk mais codage clé impossible.
avec la version 1.67 et 1.69 impossible de se connecter dans le module keys.
une solution ?
---------- Post added at 18h38 ---------- Previous post was at 18h36 ----------
le tout avec ou sans le conctact et je précise que plus de clé valide.
une solution ?
Vieux 06/03/2019, 18h44   #2663
BILAUTO
Avatar de BILAUTO
Pouvoir de réputation: 59
Slt GABY et bon retour l'artiste
dis moi sur Renault Clio 2 Campus en version 1.65 ça fonctionne.
En tout cas merci pour ton développement
Bosse sur la Clio 4 et tu vas vendre ton soft comme une petite baguette.....
The Following User Says Thank You to BILAUTO For This Useful Post:
bkprog13 (06/03/2019)
Vieux 06/03/2019, 18h46   #2664
stephane
Avatar de stephane
salutation bkprog quel année ta clio2
Vieux 06/03/2019, 18h49   #2665
BILAUTO
Avatar de BILAUTO
clio 2 campus entre 2006 et 2008
Vieux 06/03/2019, 18h56   #2666
bkprog13
Avatar de bkprog13
année 2004 la clio 2 avec compteur digital sur jauge essence et température
Vieux 06/03/2019, 19h05   #2667
stephane
Avatar de stephane
humm....Etranger ca doigt fonctionner tu a essaye comme la mentionner bilauto en passant part campus
a tu penser a modifier le baurat de lecture en changeant de version
si oui il faut que tu passe part l après vente directement dans l uch
il est reconnue en x65
The Following 4 Users Say Thank You to stephane For This Useful Post:
bkprog13 (06/03/2019), jah83 (06/03/2019), kilm (03/04/2021), revo (06/03/2019)
Vieux 06/03/2019, 19h25   #2668
bkprog13
Avatar de bkprog13
oui j’ai bien changer la baudrat car sinon l’interface se connecte pas au logiciel en bas à gauche.
j’ai essayé toutes les versions dans keys même clio 3 et modus mdr mais même résultat il me met message erreur en rouge en anglais condition non satisfaisante. avec 1.67 et 1.69 c’est directement cannot connect.
demain j’essaye en APV, si tu peux me dire la manip merci stephane
edit : c’est bon je viens de voir que manip détaillé dans le soft
Dernière modification par bkprog13 ; 06/03/2019 à 19h29.
The Following User Says Thank You to bkprog13 For This Useful Post:
Vieux 06/03/2019, 19h44   #2669
tony60
Avatar de tony60
Pouvoir de réputation: 102
Essaye sans contact pour obtenir le pin
Vieux 06/03/2019, 19h47   #2670
bkprog13
Avatar de bkprog13
le pin et isk je l’obtient bien sans contact avec la version 1.49 mais ensuite je vais pas plus loin...
Fonctions cachées du Climatronic vw nany Systeme de climatisation 6 27/11/2014 22h06
fonctions digiprog3 TONY55 Tableau de bord (Dashboard) 3 16/09/2014 16h04
classement interfaces/softs/fonctions/marques Molil Electronique 4 28/07/2014 19h57
quels sont toutes les fonctions de l'abritus72 mustauto Outil de programmation 5 04/02/2013 12h50
Fuseau horaire GMT +1. Il est actuellement 19h57.
