Vieux 19/09/2018, 14h22   #2281
profrenault
Avatar de profrenault
profrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant futureprofrenault has a brilliant future
oui je confirme que si la meme technique (deja essayer sur clio 4 phase 1
---------- Post added at 13h22 ---------- Previous post was at 13h17 ----------
La vrais vie est dans le partage expérience. Clip/DDT2000/VAG COM /FGTECH OFFICIEL/
profrenault est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to profrenault For This Useful Post:
ggvaniou (19/09/2018), ishams2002 (19/09/2018), kilm (19/09/2018), pouettedu76 (19/09/2018), progdebutant (14/02/2019)
Vieux 19/09/2018, 15h44   #2282
davycdz
Avatar de davycdz
davycdz has a spectacular aura aboutdavycdz has a spectacular aura aboutdavycdz has a spectacular aura about
Salut les gars, quelqu'un a déjà programmé une carte de clio 4 avec Renolink ?
N'OUBLIEZ PAS LE PETIT BOUTON THANKS EN BAS À DROITE
davycdz est déconnecté   Réponse avec citation
Vieux 19/09/2018, 15h55   #2283
techtronic1
Avatar de techtronic1
Envoyé par davycdz Voir le message
slt pas pour l instant
The Following 5 Users Say Thank You to techtronic1 For This Useful Post:
davycdz (19/09/2018), ggvaniou (19/09/2018), klif26 (19/09/2018), Pelican (19/09/2018), pouettedu76 (19/09/2018)
Vieux 19/09/2018, 16h53   #2284
davycdz
Avatar de davycdz
Ha , dommage, merci beaucoup
Vieux 21/09/2018, 11h44   #2285
mecano13
Avatar de mecano13
mecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud ofmecano13 has much to be proud of
Salut comment supprime l antidemarrage avec Reno link sur une clio 2 1.5 dci 2001
mecano13 est déconnecté   Réponse avec citation
Vieux 21/09/2018, 11h56   #2286
fufounet
Avatar de fufounet
Pouvoir de réputation: 41
tu peux pas
The Following User Says Thank You to fufounet For This Useful Post:
mecano13 (21/09/2018)
Vieux 21/09/2018, 11h56   #2287
techtronic1
Envoyé par mecano13 Voir le message
slt c simple tu peut pas Immo off avec emu
Vieux 21/09/2018, 12h21   #2288
mecano13
Avatar de mecano13
Salut après pour les reste ses pas mal j ai fait dae sur un modus ses impec
Vieux 21/09/2018, 13h01   #2289
louay
Avatar de louay
tu peux pas, la seule solution virgin avec pose d'un émulateur
The Following 4 Users Say Thank You to louay For This Useful Post:
freddy5923 (20/10/2018), ggvaniou (21/09/2018), mecano13 (21/09/2018), prinzo57 (21/09/2018)
Vieux 21/09/2018, 19h45   #2290
Topal
Avatar de Topal
Topal is a name known to allTopal is a name known to allTopal is a name known to allTopal is a name known to allTopal is a name known to allTopal is a name known to all
Salut,les gars
j'ai voulus coder des cles sur un master II en utilisant le menu Key de Renolink et impossible
selection uch master 2 OK
read pin OK
connect OK
learn key OK
mais des que je mettais le contact il ne voulais pas, il se deconnectais automatiquement
,je suis donc passé pas la recherche de l'uch et apres apprentissage cles, et la ok pas de probleme
Pat
Topal est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to Topal For This Useful Post:
DIAGSYSTEM25 (21/09/2018), E46 (23/09/2018), ggvaniou (22/09/2018), mahfoud lichani (21/09/2018), pouettedu76 (22/09/2018)
Vieux 23/09/2018, 12h29   #2291
mahfoud lichani
Avatar de mahfoud lichani
est ce que "ecu à remplacer" suite à choc, en précisant que les "airbags" n'ont pas éclaté empêche le démarrage sur modus de 2008?
est ce que renolink peut y remédier?
ecu bosch: 0285001509
MERCI
BONNE JOURNÉE
---------- Post added at 10h29 ---------- Previous post was at 10h28 ----------
MERCI
BONNE JOURNÉE
Vieux 23/09/2018, 12h37   #2292
LouisLeSinge
Avatar de LouisLeSinge
LouisLeSinge is a jewel in the roughLouisLeSinge is a jewel in the roughLouisLeSinge is a jewel in the rough
Non, en principe il faut aller dans le calculateur d'injection et lancer la commande d'effacement des défauts, même s'il n'y en a aucun.
Cdt,
LouisLeSinge est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to LouisLeSinge For This Useful Post:
Formator (23/09/2018), freddy5923 (20/10/2018), kilm (23/09/2018), progdebutant (14/02/2019)
Vieux 23/09/2018, 13h06   #2293
Formator
Avatar de Formator
Pouvoir de réputation: 72
Envoyé par LouisLeSinge Voir le message
Cdt,
Exact, mais en mode réparation via RZ001
freddy5923 (20/10/2018), progdebutant (14/02/2019)
Vieux 23/09/2018, 13h21   #2294
LouisLeSinge
Re,
En quel autre mode sinon?
Cdt,
The Following User Says Thank You to LouisLeSinge For This Useful Post:
Vieux 25/09/2018, 14h48   #2295
Formator
Avatar de Formator
Re,
Cdt,
Avec clip, tu peux effacer les défauts avec avec les 2 modes : Diagnostic et réparation.
Mais en rapport à ce problème, souvent seul le mode réparation fonctionne.
freddy5923 (20/10/2018), LouisLeSinge (25/09/2018)
Fonctions cachées du Climatronic vw nany Systeme de climatisation 6 27/11/2014 22h06
fonctions digiprog3 TONY55 Tableau de bord (Dashboard) 3 16/09/2014 16h04
classement interfaces/softs/fonctions/marques Molil Electronique 4 28/07/2014 19h57
quels sont toutes les fonctions de l'abritus72 mustauto Outil de programmation 5 04/02/2013 12h50
Fuseau horaire GMT +1. Il est actuellement 16h43.
