Vieux 04/08/2021, 14h45   #1
Aleksey-MS
Avatar de Aleksey-MS
Pouvoir de réputation: 46
Aleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond reputeAleksey-MS has a reputation beyond repute
Par défaut BMW SP-Daten 69.0 - Méga
BMW SP Daten - micrologiciel propriétaire pour le codage et la programmation des unités de commande électroniques pour voitures et motos BMW. Il est possible de mettre à jour le firmware à l'aide des programmes WinKFP, NCS Expert, INPA inclus dans le package BMW Standard Tools.
Type de fichier : txt BMW SP-Daten v69.0.txt (54 octets, 100 affichages)
Dernière modification par Aleksey-MS ; 19/10/2021 à 11h19.
Aleksey-MS est déconnecté   Réponse avec citation
The Following 10 Users Say Thank You to Aleksey-MS For This Useful Post:
ABDESLAM (21/01/2022), boukrama (21/10/2021), calixo22 (12/09/2021), fayssal2017 (05/08/2021), MecaTech (08/04/2025), rocky251 (09/03/2024), sandy976 (24/02/2024), speedy_bou (27/08/2021), THEPATKILLER1979 (15/11/2021), vortex (19/05/2022)
Vieux 19/10/2021, 11h19   #2
Aleksey-MS
Ajout d'une nouvelle version BMW SP-Daten 69.0 - Mega
I will install diagnostic/auto repair programs, and select diagnostic/chip tuning equipment.
The Following User Says Thank You to Aleksey-MS For This Useful Post:
Vieux 19/05/2022, 07h45   #3
Aleksey-MS
Added Torrent link
Type de fichier : txt BMW SP-Daten v69.0.txt (215 octets, 27 affichages)
The Following 2 Users Say Thank You to Aleksey-MS For This Useful Post:
MecaTech (08/04/2025), vortex (19/05/2022)
Vieux 06/02/2023, 13h40   #4
Aleksey-MS
Added BMW SP-Daten 71.0
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
Type de fichier : txt BMW SP-Daten.txt (137 octets, 33 affichages)
The Following 3 Users Say Thank You to Aleksey-MS For This Useful Post:
djilimpines (16/03/2023), KIKOU92 (06/08/2023), MecaTech (08/04/2025)
Vieux 06/08/2023, 20h55   #5
KIKOU92
Avatar de KIKOU92
KIKOU92 is on a distinguished road
bonjout
tu aurais lMP pour telecharger le SP daten
KIKOU92 est déconnecté   Réponse avec citation
Vieux 18/02/2024, 12h08   #6
Aleksey-MS
The link was updated
Type de fichier : txt BMW SP-Daten.txt (21 octets, 23 affichages)
MecaTech (08/04/2025), vwseb (19/02/2024)
Vieux 10/12/2024, 13h11   #7
Aleksey-MS
Type de fichier : txt BMW SP Daten.txt (46 octets, 14 affichages)
Vieux 19/12/2025, 14h13   #8
Aleksey-MS
Added
BMW SP-Daten v73
karl6 (09/02/2026)
Vieux 04/03/2026, 22h49   #9
Aleksey-MS
Arrow
BMW SP-Daten 74
BMW SP-Daten is a configuration data and firmware package for working with ECUs in BMW E, R, and F series vehicles.
Why use SP-Daten?
Coding: Add new functions or disable unnecessary ones (e.g., lamp polling).
Programming: Update ECU firmware versions to more stable ones.
Diagnostics: Correctly read parameters of new modules.
Retrofitting: Correctly program new physical components into the system.
Need it? Push buttons Rate+Thanks, PM for pass.
Type de fichier : txt BMW SP-Daten new.txt (34 octets, 3 affichages)
Vieux 04/03/2026, 22h50   #10
Aleksey-MS
What's new in SP-Daten v74?
Includes the latest software bug fixes for the latest E-series models (e.g., late E70, E90).
Interpretation files (.ipo and .prg) have been updated, minimizing "API-0014: RESULT NOT FOUND" errors during diagnostics.
Added data for correct operation with new revisions of parts that have been released as replacements for originals in recent years.
Vieux 28/03/2026, 23h29   #11
Aleksey-MS
Lightbulb
Envoyé par Aleksey-MS Voir le message
BMW SP-Daten 74
Why use SP-Daten?
Need it? Push button Thanks, PM for pass | or by email right now.
Vieux 20/07/2026, 21h11   #12
Aleksey-MS
Par défaut BMW SP-Daten 75
What inside:
- SP-Daten 75
BMW SP-Daten is a comprehensive data package used for coding, programming, diagnostics, and retrofitting BMW vehicles, primarily E-Series and R-Series models. It contains the ECU data, module definitions, firmware references, and configuration files required by BMW Standard Tools such as NCS Expert, WinKFP, Tool32, and INPA.
Why use SP-Daten?
Coding
- Enable or disable vehicle functions
- Configure replacement modules
- Restore factory coding
- Perform retrofit coding
- Modify vehicle order (VO) options
Programming & Flashing
- Update ECU software
- Flash control units with WinKFP
- Recover modules after failed programming
- Match replacement ECUs to the vehicle
- Update modules to newer software versions
Diagnostics
- Improve compatibility with newer ECU revisions
- Correct module identification
- Access advanced ECU functions
- Read parameters and execute diagnostic jobs
Retrofitting
- Add factory options and accessories
- Install upgraded modules
- Code newly installed components
- Program replacement control units
Compatible Software
- NCS Expert
- WinKFP
- Tool32
- INPA
- EDIABAS
- BMW Coding Tool
- NCSDummy
Supported Vehicles
SP-Daten is mainly intended for BMW E-Series, MINI R-Series, and selected older BMW platforms, including:
- E46, E60, E70, E71
- E81, E82, E87, E88
- E90, E91, E92, E93
- MINI R50–R61
- Other supported E-Series chassis
SP-Daten vs PSdZData
- SP-Daten = E-Series and BMW Standard Tools
- PSdZData = F-Series, G-Series and E-Sys
For BMW E-Series vehicles, SP-Daten remains an essential database for professional coding, ECU programming, diagnostics, and retrofit work.
sp daten E70 shredder95 BMW, Mini, Rolls-Royce 12 30/05/2021 11h36
Sp daten e84 ggvaniou BMW, Mini, Rolls-Royce 2 14/10/2019 19h09
sp daten yann3 BMW, Mini, Rolls-Royce 0 01/10/2018 17h03
SP-Daten V60.1 kdo75 GT1, OPS, SSS, ICOM 0 21/09/2017 07h36
SP Daten 50.2 Gini GT1, OPS, SSS, ICOM 15 13/10/2014 09h56
Fuseau horaire GMT +1. Il est actuellement 20h01.
