Vieux 27/05/2023, 21h40   #1
julie.long
Avatar de julie.long
Pouvoir de réputation: 26
julie.long has a brilliant futurejulie.long has a brilliant futurejulie.long has a brilliant futurejulie.long has a brilliant futurejulie.long has a brilliant futurejulie.long has a brilliant futurejulie.long has a brilliant futurejulie.long has a brilliant futurejulie.long has a brilliant futurejulie.long has a brilliant futurejulie.long has a brilliant future
Par défaut Diagbox 9.85_Free
Diagbox 9.85_Free
https://mega.nz/folder/HtNxlaSA#LDLMvm8wk6IHZgdCOClGTw
:loc k1:
---------- Post added at 21h37 ---------- Previous post was at 21h36 ----------
---------- Post added at 21h40 ---------- Previous post was at 21h37 ----------
pas de clic thank's , pas de clic sur réputations, pas d'aide !
julie.long est déconnecté   Réponse avec citation
The Following 45 Users Say Thank You to julie.long For This Useful Post:
aigle459 (28/05/2023), Antoine73 (27/05/2023), attefco (06/07/2023), autodiagauto (28/05/2023), aziz0101 (10/10/2024), baccara25 (28/05/2023), bej 974 (10/07/2023), bladi (28/05/2023), claude81 (15/06/2023), curtis50 (29/05/2023), Dav (31/05/2023), diag auto 62 (20/08/2023), diago2001 (13/08/2023), DOUDOU (29/05/2023), eCU25 (27/08/2024), Evasion_Td12 (23/02/2024), falout (02/06/2023), figeac (28/05/2023), garibek (28/05/2023), hakim087 (28/05/2023), hamlili08 (06/12/2024), inconnu (15/10/2023), kaki02 (30/05/2023), kis2a (28/05/2023), leborgne (27/01/2024), mahfoud lichani (28/05/2023), MecaSolid93 (18/06/2023), michel13 (14/08/2023), mimi cra casse (25/01/2024), Minimox (31/05/2023), Molil (27/05/2023), msiliman69 (04/10/2023), rahmani2008 (31/05/2023), samii1955 (17/08/2023), stef56100 (28/05/2023), thierry du58 (29/05/2023), tomtom59 (29/08/2024), tonton34 (15/05/2026), transitforum (29/05/2023), vortex (29/05/2023), Xam78 (25/08/2024), yakoub (27/02/2024), Yalpha (25/08/2024), yanp55 (01/06/2023)
Vieux 28/05/2023, 09h47   #2
kis2a
Avatar de kis2a
merci , tester , mais ne fonctionne pas chez moi
Vieux 28/05/2023, 09h52   #3
Pouvoir de réputation: 113
T es sur quel OS ?
Il y avait pas d autre version dbox avant dessus ?
kis2a (28/05/2023)
Vieux 28/05/2023, 09h56   #4
kis2a
Avatar de kis2a
windows 7 , je sais plus si avais test d'autre ou pas lol
Vieux 28/05/2023, 17h21   #5
@julielong
Peux tu nous faire un retour utilisateur de cette version
Merci d avance :-)
Vieux 28/05/2023, 20h58   #6
julie.long
lances en administrateur petit padawan..................
The Following User Says Thank You to julie.long For This Useful Post:
vortex (28/05/2023)
Vieux 28/05/2023, 21h05   #7
kis2a
Avatar de kis2a
Envoyé par julie.long Voir le message
ces déjà fais
---------- Post added at 21h05 ---------- Previous post was at 21h03 ----------
must be run as administrator "
Vieux 28/05/2023, 22h00   #8
vortex
Avatar de vortex
vortex has a brilliant futurevortex has a brilliant futurevortex has a brilliant futurevortex has a brilliant futurevortex has a brilliant futurevortex has a brilliant futurevortex has a brilliant futurevortex has a brilliant futurevortex has a brilliant futurevortex has a brilliant futurevortex has a brilliant future
Slt je vois sur ta photo 9.96 alors que la version est normalement en 9.85.
vortex est déconnecté   Réponse avec citation
The Following User Says Thank You to vortex For This Useful Post:
kis2a (28/05/2023)
Vieux 29/05/2023, 07h53   #9
julie.long
Envoyé par vortex Voir le message
mdr..............j'avais pas vu...........donc je ne sais pas de quoi il parle.
---------- Post added at 07h53 ---------- Previous post was at 07h51 ----------
pas cette version lol
The Following 2 Users Say Thank You to julie.long For This Useful Post:
peugeot_307cc (29/05/2023), vortex (29/05/2023)
Vieux 29/05/2023, 15h00   #10
kis2a
Avatar de kis2a
dois avoir des reste d'une vielle install , vais faire du nettoyage et re-test ça
vortex (29/05/2023)
Vieux 29/05/2023, 15h38   #11
boukrama
Avatar de boukrama
boukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud ofboukrama has much to be proud of
salut fonctionne sans probleme testé il ya 15 jours il faut utiliser diagbox tool la premier version avec changement de langue il faut vérifier que tous et vert
et apres l installation tu change la langue vers le FR
---------- Post added at 15h36 ---------- Previous post was at 15h34 ----------
je remercie mon frère Mr rorry pour tous les logiciel qui a fourni a notre forum que en utilise toujours pour trouvé les solution
---------- Post added at 15h38 ---------- Previous post was at 15h36 ----------
je remercie mon frère Mr Rorry pour tous les logiciel qui a fourni a notre forum que en utilise toujours pour trouvé les solutions
boukrama est déconnecté   Réponse avec citation
The Following 10 Users Say Thank You to boukrama For This Useful Post:
amar (27/01/2024), autodiagauto (29/05/2023), chatgris08 (04/08/2023), curtis50 (14/08/2023), fils (02/06/2023), juju94 (01/03/2024), julie.long (30/05/2023), peugeot_307cc (29/05/2023), tonton34 (20/07/2023), vortex (29/05/2023)
Vieux 29/05/2023, 21h31   #12
maitresox
Avatar de maitresox
Pouvoir de réputation: 69
maitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond reputemaitresox has a reputation beyond repute
Salut l'ami,
C'est la version 9.84 et non 9.85 de Rorry sans licence.
Version sans licence qu'il a diffusée ici même sans s'en rendre compte. Il avait oublié de mettre son système de licence dedans. Pas grand monde ne l'a vu passer car il faisait des mises à jour quotidienne des liens avec ses améliorations.
Petit bug du journal des défauts sinon RAS
Bye
Maitresox
Dernière modification par maitresox ; 29/05/2023 à 21h35.
maitresox est déconnecté   Réponse avec citation
The Following 6 Users Say Thank You to maitresox For This Useful Post:
amar (27/01/2024), autodiagauto (29/05/2023), DIAGAUTO33 (29/05/2023), julie.long (30/05/2023), sasa (30/05/2023), transitforum (30/05/2023)
Vieux 30/05/2023, 09h37   #13
kis2a
Avatar de kis2a
il fonctionne bien sous 32bits ?
tout nettoyer , installe ok , mais lors du lancement du logiciel , il reste sur la fenêtre et ça mouline sans arrêt puis -> launcher ne repond pas
Vieux 30/05/2023, 11h01   #14
boukrama
Avatar de boukrama
oui il fonctionne sans problème sous 32bit regarde ou niveau de ton pc c il est pas infecté
Vieux 30/05/2023, 18h09   #15
julie.long
Envoyé par maitresox Voir le message
Salut l'ami,
Bye
Maitresox
Un contact Chinois me l'a envoyé..............mdr.
The Following 3 Users Say Thank You to julie.long For This Useful Post:
maitresox (31/05/2023), transitforum (30/05/2023), Xam78 (25/08/2024)
[TUTO] Mise à jour DiagBox v7 vers Diagbox v8 roony75 LEXIA, PP2000, DiagBox 89 08/07/2020 22h35
diagbox 7.66 to 7.74 jardini LEXIA, PP2000, DiagBox 3 08/10/2017 19h58
diagbox momo78100 Vente, Achat, Echange 14 04/10/2017 23h39
Lexia, diagbox... Vin Lu par diagbox mais pas de communication avec les calculateurs julien34560 LEXIA, PP2000, DiagBox 24 13/12/2015 10h42
Pbm Diagbox==>BSI elpozo LEXIA, PP2000, DiagBox 3 20/02/2015 07h45
Fuseau horaire GMT +1. Il est actuellement 19h57.
